Tehnation Posted February 24, 2014 Share Posted February 24, 2014 I just installed a BNR turbo, and it looks like the stem is leaking at the turbo to stem seal. Is there a copper gasket available or should I be using some kind of sealant? I have removed it a couple times re tightened and it still leaks. Is this common? The bnr came with a paper gasket but I don't think its thick enough. Link to comment Share on other sites More sharing options...
KRM Posted February 24, 2014 Share Posted February 24, 2014 have you tried calling or emailing brian at bnr for a fix? hes pretty good with keeping customers happy with his turbos Link to comment Share on other sites More sharing options...
Tehnation Posted February 24, 2014 Author Share Posted February 24, 2014 He said I would have to resurface the stem, its probably warped. Link to comment Share on other sites More sharing options...
FJuan Posted February 24, 2014 Share Posted February 24, 2014 You could try using a little gasket sealer on the paper gasket itself. Just put a very light coat on both sides and let it dry for a few mins before installing it. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
JmP6889928 Posted February 24, 2014 Share Posted February 24, 2014 Get a Subaru OE gasket. It's a bit thicker and it also has a graphite coating on it that helps to fill in small scratches and imperfections. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 24, 2014 Share Posted February 24, 2014 Get a Subaru OE gasket. It's a bit thicker and it also has a graphite coating on it that helps to fill in small scratches and imperfections.  Wow, there's a great idea. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted February 24, 2014 Author Share Posted February 24, 2014 Ive pulled the turbo twice now in an attempt to fix. Its getting quite annoying at this point. I'm going to sand it down and replace with oem gasket. I just figured the gasket from bnr would be as good if not better than oem, guess I will find out when I pickup the new gasket. Link to comment Share on other sites More sharing options...
Tehnation Posted February 24, 2014 Author Share Posted February 24, 2014 Part number???? Link to comment Share on other sites More sharing options...
Tehnation Posted February 24, 2014 Author Share Posted February 24, 2014 15196aa000 Link to comment Share on other sites More sharing options...
Tehnation Posted February 25, 2014 Author Share Posted February 25, 2014 ..... After pulling the turbo so many times, I keep contemplating upgrading to a 20g..... god I haven't even got the car on the road and I want to upgrade! What do you guys think?? 20g vs 18g? Link to comment Share on other sites More sharing options...
FJuan Posted February 25, 2014 Share Posted February 25, 2014 Have you upgraded the fuel pump and injectors? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Tehnation Posted February 25, 2014 Author Share Posted February 25, 2014 http://legacygt.com/forums/showthread.php/18g-should-go-20gi-221547.html 1000cc dw ev14 top feeds and dw65c. Link to comment Share on other sites More sharing options...
FJuan Posted February 25, 2014 Share Posted February 25, 2014 Go for it, it sounds like you're going to regret it if you don't. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
dellguy3700 Posted February 25, 2014 Share Posted February 25, 2014 Go for it, it sounds like you're going to regret it if you don't. Great point. Link to comment Share on other sites More sharing options...
Tehnation Posted February 25, 2014 Author Share Posted February 25, 2014 I think it has to be done..... the subaru gods have spoken! Link to comment Share on other sites More sharing options...
Tehnation Posted February 25, 2014 Author Share Posted February 25, 2014 ...... buuuuut after talking with bnr, I will stick with the 18g. Link to comment Share on other sites More sharing options...
FJuan Posted February 25, 2014 Share Posted February 25, 2014 Try sleeping on it first, you may change your mind again in the morning. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Tehnation Posted February 25, 2014 Author Share Posted February 25, 2014 They had a valid point, I can't really knock it without trying it.... So I will use it , see how it works, and if I don't like it, I'll either sell it and get a 20g, or hopefully work something out with bnr. They said try it out, and if you feel you need more give them a call back. I can't really argue with that. Link to comment Share on other sites More sharing options...
