mhamilton Posted August 21, 2006 Share Posted August 21, 2006 Looking to upgrade tires on OB with 17x7 rims. Since neither the Pzero and the Conti Extreme come in the stock size for an OB (225/55/17) what size should I move to ? 225/45/17 or 235/45/17 The 235 will put a little more rubber on the ground be a slightly better match for the speedo - but will it be too much sidewall overhang for 7" stock rims? Another alternative is Avon 235/50/17. Or Bridgestone RD960 AS 225/50/17 (expensive) Advice please. Driving in california. Rain, not much snow. Link to comment Share on other sites More sharing options...
LarryCrowell Posted August 23, 2006 Share Posted August 23, 2006 Tire Diameters: 225/55 = 26.74" 225/50 = 25.86" 225/45 = 24.97" 235/50 = 26.25" 235/45 = 25.33" A quick review of specs at TireRack shows the 235s needing a 7.5" rim mimimum. Doesn't sound like the 235s are a good idea. The other 225s will introduce at least a 3% speedo error. Why not just stay with stock size summer tires? Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted August 23, 2006 Share Posted August 23, 2006 I got Toyo Proxes in the stock size and I like them. Link to comment Share on other sites More sharing options...
captainmorgan Posted August 23, 2006 Share Posted August 23, 2006 Along similar lines, Iwas thiking about replacing my stock wheels (winter now) with a set of 18x7.5 rota's or something cheap. Its nearly impossible to find tires in 225/50/18. I think only Blizzak's come in that size for $180 a tire! Back on track, if you can find them in that size, Falken 512 are a great all season and have nice stiff sidewalls, and makes for a great "higher" performance tire over stock. Link to comment Share on other sites More sharing options...
urfsin Posted August 23, 2006 Share Posted August 23, 2006 I would go with the Avons, I went on the Tire Rack website and they look like they would be good A/S tires. When my Potenzas wear donwn, that's what I am going to get. I am in Cali too, so I gotta be ready for some rain and some snow for the winter snowboarding trips to Mammoth or Big Bear. Slide It Sideways Link to comment Share on other sites More sharing options...
brett s Posted August 24, 2006 Share Posted August 24, 2006 Different tires vary in width & diameter even for the same nominal size, keep that in mind The stock 225/55/17 RE-92's are 26.9" diameter, the Pzero's in 235/55/17 are very close at 27.1" - they'll work fine if that's what you decide on. I'm thinking about the Goodyear Eagle ResponsEdge when I'm ready for tires, looks like they fit what need pretty well. Link to comment Share on other sites More sharing options...
mhamilton Posted August 24, 2006 Author Share Posted August 24, 2006 Well I am reall nervous about putting a 235 tire on the 7" rim The Pzero nero (with the OE Mustang tread ... wonder what that looks like) is the ONLY 235 I have seen that allows a 7" rim. I bet that it is really not a good idea. Too much sidewall overhang will make for poor cornering. I think I have to go to 225/45 if I want the PZero. The Speedo error is somethign I can live with. Link to comment Share on other sites More sharing options...
brett s Posted August 24, 2006 Share Posted August 24, 2006 Look closer - they list the allowable rim width as 7-8.5", 7.5" was the width of the rim they took the section width measurement on. Edit - the above was at Tire Rack's site, Pirelli says 6.5-8.5" Link to comment Share on other sites More sharing options...
bgsntth Posted August 24, 2006 Share Posted August 24, 2006 They are good in cold weather, not snow; but my Yokohama Advan S.T.'s have phenomenal dry/wet grip and hydroplane resistance. I would put them at about the same level of grip as SO3's. They have a reinforced side-wall and outer-tread especially for heavy, high-ground clearance SUV's and Bently's. Negates the bobbing and front tire-folding understeer. Link to comment Share on other sites More sharing options...
Hanger Posted August 25, 2006 Share Posted August 25, 2006 I live in Socal, i got the Fuzion ZRi they're pretty good and cheap too, look them up ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
