dwolson2 Posted July 8, 2011 Share Posted July 8, 2011 I have a set of megan racing coilovers, and am trying to get a smoother ride. I have the regular springs on them. After searching and reading and searching more, has anyone put the upgraded springs on(10K) and found the ride to be more harsh? I am finding that when I go over bumps I hear a loud clunk that sounds like my sidewall on my tire is a 30 series. Before I get the "tighten down the strut nut, your camber plates are loose" I am using factory top hats. The bumps that cause this problem are usually sharp bumps, like that of tar that has rippled up or a bad approach to train tracks. Normal bumps, like on the free way don't give me problems nor do those same bumps at lower speeds. The idea is to get a low spring rate helper spring to make my ride more like stock(and like kw's) I know the kw's have better valving, but how? It doesn't bounce after i hit a bump, o I don't "think" I am under dampening, but I am at full soft. Anyone that can give me some useful information (not the "you should have bought KW's...) would be appreciated. I know I didn't get the best set of coilovers, but I would think that it should be possible to improve the ride. Just using the factory front top hats increased the ride quality night and day, so I think there should be room to improve. Also, my preload is hand tight plus a half turn, then locked. Thanks! Link to comment Share on other sites More sharing options...
Bolksey85 Posted July 8, 2011 Share Posted July 8, 2011 You'll want to go down in spring rate, not up. An 8k spring is fairly stiff for our cars to begin with so going to a 10 will only make it worse. Link to comment Share on other sites More sharing options...
rao Posted July 8, 2011 Share Posted July 8, 2011 Wimp! Stiffer springs are better. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
dwolson2 Posted July 8, 2011 Author Share Posted July 8, 2011 Thats what I thought, but I have seen people post that the spring rate doesn't change the ride and that its only dampening. I don't want to go to a 10K, but if someone has and compare it to the stock MR spring, you could assume that going down in spring rate would have the opposite effect. Link to comment Share on other sites More sharing options...
dwolson2 Posted July 8, 2011 Author Share Posted July 8, 2011 Wimp! Stiffer springs are better. I'll let my wife know, she is the one who has the problem with it. :lol: Link to comment Share on other sites More sharing options...
sheppo9 Posted July 11, 2011 Share Posted July 11, 2011 Lower spring rate = softer. What size tires do you have? Link to comment Share on other sites More sharing options...
dwolson2 Posted July 11, 2011 Author Share Posted July 11, 2011 225/40R18 I don't think I can go wider that 225, since my current rims are not wide enough. I have a set in the garage that I am going to see if I can mount wider tires. I know I can go to a 45 series, which would help with comfort, but I would be changing my odometer. I may go 215/45R18, which would only increase it by a bit... who knows... Link to comment Share on other sites More sharing options...
dwolson2 Posted July 14, 2011 Author Share Posted July 14, 2011 7.5 inch rims in the garage, cant go wider than 225 unless I want a 245/45 which would put my odometer way off... Link to comment Share on other sites More sharing options...
