Jordan Posted February 26, 2009 Share Posted February 26, 2009 In the fact vs. fiction article in the latest import tuner issue they dyno test a miata first with the cat, then they gutted it and it lost 2-3 whp over the intact cat. The theory is that the rough edges create turbulence that actually increases backpressure. Link to comment Share on other sites More sharing options...
Reuben Posted February 27, 2009 Share Posted February 27, 2009 This is why you don't do stupid little mods like that, and actually go out and by a proper exhaust. Link to comment Share on other sites More sharing options...
rtbrjason Posted February 27, 2009 Share Posted February 27, 2009 In the fact vs. fiction article in the latest import tuner issue they dyno test a miata first with the cat, then they gutted it and it lost 2-3 whp over the intact cat. The theory is that the rough edges create turbulence that actually increases backpressure. I doubt that it had anything to do with the gutting. You could run the car on the dyno 5 times and see a 2-3whp variance or more. Also, a Miata is not a LGT. Removing the cat in the Miata will have much less effect (if any without tuning) than removing the cat right after the turbo in the LGT. Link to comment Share on other sites More sharing options...
05GT Guru Posted February 27, 2009 Share Posted February 27, 2009 I doubt that it had anything to do with the gutting. You could run the car on the dyno 5 times and see a 2-3whp variance or more. Also, a Miata is not a LGT. Removing the cat in the Miata will have much less effect (if any without tuning) than removing the cat right after the turbo in the LGT. Exactly lol, 2 to 3whp lol are you serious. I get that in between dyno runs with the same car on the same day changing nothing at all. Link to comment Share on other sites More sharing options...
ProjectPechkin Posted February 27, 2009 Share Posted February 27, 2009 Stupidy also raise back pressure Fact Link to comment Share on other sites More sharing options...
rao Posted February 27, 2009 Share Posted February 27, 2009 Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
02BlkRex Posted February 27, 2009 Share Posted February 27, 2009 Stupidy also raise back pressure Fact So does Stupidity. Link to comment Share on other sites More sharing options...
05GT Guru Posted February 27, 2009 Share Posted February 27, 2009 Stupidy also raise back pressure Fact Link to comment Share on other sites More sharing options...
DukeTrout Posted February 27, 2009 Share Posted February 27, 2009 So maybe we should put prunes in the intake, to decrease backpressure? Ich bin echt viel netter, wenn ich nuechtern bin. Echt! Link to comment Share on other sites More sharing options...
Rika Posted February 27, 2009 Share Posted February 27, 2009 baaa Gut them! Link to comment Share on other sites More sharing options...
SuperCleanLGT Posted February 27, 2009 Share Posted February 27, 2009 Like others have sort of said, in N/A cars you need to keep some back pressure to have a good power/tq curve. On a turbo car the turbo creates enough backpressure. This allows you to gut/remove the cats and get a good gain ( with a proper tune). Link to comment Share on other sites More sharing options...
GTTuner Posted February 27, 2009 Share Posted February 27, 2009 Ahhhh screw it, run open header FTW. Link to comment Share on other sites More sharing options...
JoeFromPA Posted February 27, 2009 Share Posted February 27, 2009 What about if I gut the cats using a sawzall? Seriously, that was a stupid test. Link to comment Share on other sites More sharing options...
Rika Posted February 27, 2009 Share Posted February 27, 2009 Like others have sort of said, in N/A cars you need to keep some back pressure to have a good power/tq curve. On a turbo car the turbo creates enough backpressure. This allows you to gut/remove the cats and get a good gain ( with a proper tune). Till you get boost spike Link to comment Share on other sites More sharing options...
Jordan Posted February 28, 2009 Author Share Posted February 28, 2009 Yeah you guys are right, import tuner has no idea what they are talking about and im sure they didnt average the dyno runs to equal 2-3whp they just went click click boom and got two readings back to back. I mean they definetley have no experience runing a dyno right? Oh and p.s the only reason I posted this is so smart asses like you can stop telling people its ok to run stg 2 with a gutted cat. Oh and I am surely stupid because I cant spell the word stupidity correctly Oh wait that was you trying to call me stupid by molesting the english language, damn im wrong on all acounts. Link to comment Share on other sites More sharing options...
TravisS Posted February 28, 2009 Share Posted February 28, 2009 Do you still think test results on a small displacement n/a engine are comparable to our engine? I'm sure their test is perfectly valid... for a Miata. Link to comment Share on other sites More sharing options...
sicklyscott Posted February 28, 2009 Share Posted February 28, 2009 Like others have sort of said, in N/A cars you need to keep some back pressure to have a good power/tq curve. On a turbo car the turbo creates enough backpressure. This allows you to gut/remove the cats and get a good gain ( with a proper tune). Exactly my response. Quite honestly I'm a bit disappointed in that magazine for the reasoning they gave. If a true car person, who we all assume the writer is, gave that problem much thought they would have realized the above thinking. It's almost a face palm moment. Link to comment Share on other sites More sharing options...
Jordan Posted February 28, 2009 Author Share Posted February 28, 2009 Well i guess they assumed it was universal for everyapplication that uneven course surfaces will created unwanted turbulence, the degree of which is obviosley variable, however I would expect it to be amplified with more pressure being thrown at it. But agian you guys are the experts not them, thats why they have a magazine and your posting on a forum;) Link to comment Share on other sites More sharing options...
rtbrjason Posted February 28, 2009 Share Posted February 28, 2009 Well i guess they assumed it was universal for everyapplication that uneven course surfaces will created unwanted turbulence, the degree of which is obviosley variable, however I would expect it to be amplified with more pressure being thrown at it. But agian you guys are the experts not them, thats why they have a magazine and your posting on a forum;) I've removed my cat and can say with certainty that there was a considerable power increase. My car has been logged extensively through stock, stage 1 and stage 2 configurations, and the most noticeable power increase was after removing the cat directly after the turbo. I did leave the final cat in place. Link to comment Share on other sites More sharing options...
lawl Posted February 28, 2009 Share Posted February 28, 2009 i thought on an N/A car you want backpressure. it makes sense that it lost power, because it lost backpressure. http://br.answers.yahoo.com/question/index?qid=20070804195122AAwIiUT not that yahoo answers is the bastion of truth and justice, but naturally aspirated engines work differently. if its designed to work with some backpressure and you remove a component sometimes you get the undesired effect.. car for sale. PM me! Link to comment Share on other sites More sharing options...
Rbpowerd240 Posted February 28, 2009 Share Posted February 28, 2009 http://www.tercelreference.com/tercel_info/turbo_exhaust_theory/turbo_exhaust_theory.html N/A cars: As most of you know, the design of turbo exhaust systems runs counter to exhaust design for n/a vehicles. N/A cars utilize exhaust velocity (not backpressure) in the collector to aid in scavenging other cylinders during the blowdown process. It just so happens that to get the appropriate velocity, you have to squeeze down the diameter of the discharge of the collector (aka the exhaust), which also induces backpressure. The backpressure is an undesirable byproduct of the desire to have a certain degree of exhaust velocity. Go too big, and you lose velocity and its associated beneficial scavenging effect. Too small and the backpressure skyrockets, more than offsetting any gain made by scavenging. There is a happy medium here. For turbo cars, you throw all that out the window. You want the exhaust velocity to be high upstream of the turbine (i.e. in the header). You'll notice that primaries of turbo headers are smaller diameter than those of an n/a car of two-thirds the horsepower. The idea is to get the exhaust velocity up quickly, to get the turbo spooling as early as possible. Here, getting the boost up early is a much more effective way to torque than playing with tuned primary lengths and scavenging. The scavenging effects are small compared to what you'd get if you just got boost sooner instead. You have a turbo; you want boost. Just don't go so small on the header's primary diameter that you choke off the high end. Downstream of the turbine (aka the turboback exhaust), you want the least backpressure possible. No ifs, ands, or buts. Stick a Hoover on the tailpipe if you can. The general rule of "larger is better" (to the point of diminishing returns) of turboback exhausts is valid. Here, the idea is to minimize the pressure downstream of the turbine in order to make the most effective use of the pressure that is being generated upstream of the turbine. Remember, a turbine operates via a pressure ratio. For a given turbine inlet pressure, you will get the highest pressure ratio across the turbine when you have the lowest possible discharge pressure. This means the turbine is able to do the most amount of work possible (i.e. drive the compressor and make boost) with the available inlet pressure. *not sure how reputable it is* But this makes a really good point for turbo charged cars. Having anything (ie cat) that will hender getting the exhaust gases out fast will have an affect on power, tq, and boost response. Link to comment Share on other sites More sharing options...
Merc6 Posted March 1, 2009 Share Posted March 1, 2009 So who here is going 4 inches? [ame=http://www.youtube.com/watch?v=WOSk7qj7oJk]YouTube - 2005 WRX STi 4" Straight Pipe[/ame] 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
