Nedrex Posted June 17, 2012 Share Posted June 17, 2012 So I'm planning on installing the FMS cat back next weekend and am trying to get everything I need gaskets and adapters wise. My question is, what is the best way to go from the stock downpipe to the 3" FMS mid pipe? I've seen the grimmspeed adapter to go from 3" dp to stock mid, but nothing to go the other way around. Will a simple 3" flat gasket do the trick or do I need something more involved? Any tips are greatly appreciated, thanks!! Link to comment Share on other sites More sharing options...
Nedrex Posted June 17, 2012 Author Share Posted June 17, 2012 Nevermind, I found the avo adapter flange: http://www.avoturboworld.com/avoshop/catback-adapter-flange-p-163.html Link to comment Share on other sites More sharing options...
angeltalin Posted June 17, 2012 Share Posted June 17, 2012 you can also search, this has been covered millions of times or PM vendors they will help you StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
Nedrex Posted June 18, 2012 Author Share Posted June 18, 2012 Yes yes, I am guilty of not searching enough before posting.... My bad! Link to comment Share on other sites More sharing options...
