kamishki Posted September 27, 2011 Share Posted September 27, 2011 I want to check out a circuit and I have a question regarding how the fuses are labeled in the manual. The one I am interested in is listed as FB-35 F/B FUSE NO. 18 (IG) Now...I derive from this that the fuse is located in the Fuse Box in the dash, and that it is labeled as NO. 18 on the box. Is it true the FB-35 denotes the wire/connector that comes into the box? and what is (IG) Thanks in advance! Link to comment Share on other sites More sharing options...
rao Posted September 27, 2011 Share Posted September 27, 2011 IG = Ignition. That fuse is powered when the key is in the Ignition and Start positions Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
