GrizFyrFyter Posted August 27, 2011 Share Posted August 27, 2011 1. AC doesn't work, possible broken hose. 2. Oil leak, might be valve gasket or drain plug. Last owner pressure washed the engine compartment. 3. Abs light on. Told it's a wheel speed sensor. 4. Air bag light on.... 5. Check engine light. Haven't checked codes yet. Sent from my R1 Link to comment Share on other sites More sharing options...
Legacy Wagon Posted August 28, 2011 Share Posted August 28, 2011 1: Could be a lot of things unfortunately :/ 2: I'm sure you'll see once you start driving it further if it's valve cover gaskets or the plug. Just gotta wait it out. Fortunately they did pressure wash it so now you'll be able to tell exactly where it's coming from 3: That's possible. I believe they plug into the hub. It may be unplugged, missing, frayed. I would just check around the hubs. 4: Remove light bulb from cluster. 5: That's something I'd definitely check out. Hopefully it's something stupid. Link to comment Share on other sites More sharing options...
GrizFyrFyter Posted August 28, 2011 Author Share Posted August 28, 2011 AC was an o-ring. Someone put the wrong one in. I replaced it (and now have 239 spare o-rings :/) and added 20oz of r-134a but still isn't blowing cold. The compressor now kicks on though. Engine light comes and goes Air bag light turned off. I am pretty sure the oil leak is at the drain plug. Sent from my R1 Link to comment Share on other sites More sharing options...
Legacy Wagon Posted August 29, 2011 Share Posted August 29, 2011 Is it leaking into the passenger compartment? Yeah...probably the knock sensor or something. You'll probably just have to try and catch it when it's on. Have the plugs ready or something. That's weird :/ I wonder what happened. Probably the crush washer been used too many times. If it's not there it may be the front or rear main seal also. Link to comment Share on other sites More sharing options...
GrizFyrFyter Posted August 29, 2011 Author Share Posted August 29, 2011 It doesn't leak into the passenger compartment. I think I fixed the leak. I'm just going to take it to a shop. Sent from my R1 Link to comment Share on other sites More sharing options...
xXChaosXx Posted August 29, 2011 Share Posted August 29, 2011 oil leak= o ring on plug i think, I have that too, ABS light, ABS unit might be unplugged.. Airbag, sooo common may have previously been triggered Link to comment Share on other sites More sharing options...
GrizFyrFyter Posted September 16, 2011 Author Share Posted September 16, 2011 Well, engine light is a knock sensor on bank 1. Great.... Seller still hadn't smogged it, time to go to court. Sent from my R1 Link to comment Share on other sites More sharing options...
