vomplegacy Posted January 5, 2013 Share Posted January 5, 2013 looking for some info on brakes for the 2005 2.5i legacy. im not looking into getting into an arguement over why im doing this, basically i have an offer from a major brake company to build me 1 off brakes front and rear for my car for free in return for services i am going to provide to them, so its all a bling factor. so what i have gathered from extensive threads and randomness is: the 2.5i can be easily converted to lgt in the front with having to just get new brackets, calipers, rotors, and lgt lines, the rear is a little mod. but can be done with minor grinding. my question is can anyone help me out with links or info on part numbers, measurements, or verifications of this. i want to pick up a caliper bracket and bring them one so they can see it and work from there. im rocking the oem 17" rims which i believe are a +55 offset but can look up to make sure, bolt pattern is 5X100. just making sure to cover my bases here so i dont pick up the wrong stuff for them to work from as they will not have my car right away. i also have no problem stepping up to 18's. any info would be much appreciated. kartboy looks to have bbk brackets available that i might be able to pull specs from as well. Link to comment Share on other sites More sharing options...
kred Posted January 5, 2013 Share Posted January 5, 2013 Is your legacy a limited or non-limited? If it's a non-limited, then I have a deal for you if you're interested. http://legacygt.com/forums/showthread.php/fs-me-new-cross-drilled-brake-rotors-pads-f-r-192843.html?t=192843&highlight=kred Link to comment Share on other sites More sharing options...
vomplegacy Posted January 5, 2013 Author Share Posted January 5, 2013 thats cool, but im talking about 6 piston calipers in front a 4 in rear, with pads and rotors from this manufacturer. Link to comment Share on other sites More sharing options...
bomberlegacy Posted January 5, 2013 Share Posted January 5, 2013 LGT brakes bolt right on, no modification needed. Need calipers lines rotors pads. I swapped it all to mine and it was super simple. As long as your new brakes fit inside the 17" wheel, you should be fine. '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
