kleggo Posted November 24, 2010 Share Posted November 24, 2010 Hi Car is a stock 06 LL Beanie. While driving yesterday radio reception went to about 2% of typical. FM reception = dramatically worse AM reception = none i assume most likely cause is failed antenna to radio connection? hope to check using this post as a guide to remove radio plastic http://legacygt.com/forums/showthread.php/antenna-connection-radioi-77730.html?t=77730&highlight=antenna Does my car have a "signal amplifier" between window glass antenna and head unit? If connection above is good, then amplifier may be dead? ooh, just found this post,sounds pretty close to same issue as mine. http://legacygt.com/forums/showthread.php/why-did-my-06-wagons-radio-reception-go-away-todayi-47795.html?t=47795&page=1 Now I need to find the amplifier. Thanks Craig Link to comment Share on other sites More sharing options...
ssbtech Posted November 26, 2010 Share Posted November 26, 2010 The antenna amp is behind the plastic trim above the wagon's rear liftgate glass. IIRC you need to remove the beige trim that runs up the sides of the glass to remove the piece at the top. Link to comment Share on other sites More sharing options...
kleggo Posted November 29, 2010 Author Share Posted November 29, 2010 The antenna amp is behind the plastic trim above the wagon's rear liftgate glass. IIRC you need to remove the beige trim that runs up the sides of the glass to remove the piece at the top. thanks for taking the time to reply. i also saw a post on another forum describing where it is not uncommon for the wire to chafe and fail where it passes through the tailgate grommet. cheers craig Link to comment Share on other sites More sharing options...
