rvlmtfnk Posted January 25, 2007 Share Posted January 25, 2007 i went to cochran subaru down in monroeville, pa, and they told me that they charge $200+tax to install brake pads and to machine the rotors. they say they only install brake pads after machining the rotors. sounds like a lot of money, but obviously i don't know the going rates... should i just bring it to pep-boys and have them install it ($99), or do you think i should just bite the bullet and get the dealership to install it. they seem friendly and much more professional than pep-boys though. Link to comment Share on other sites More sharing options...
gianspi Posted January 25, 2007 Share Posted January 25, 2007 How about a local vendor/tuning shop? Probably cheaper than the dealership and they have some positive feedback here. enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
RochNY91TSI Posted January 25, 2007 Share Posted January 25, 2007 Or you could spend 20 bucks to buy a jack and a 14mm wrench and do it yourself Link to comment Share on other sites More sharing options...
whitetiger Posted January 25, 2007 Share Posted January 25, 2007 ^+1 although how will he resurface his rotors? was it 200 just for front pads and rotors or was it for front and rear? $200 is actually a prety good shop price for a 4-wheel brake job with rotor resurfacing. usually a shop will charge 2 hrs of labor each for front and rear making it 4 hrs total for a 4 wheel brake job. Link to comment Share on other sites More sharing options...
hovied Posted January 25, 2007 Share Posted January 25, 2007 Sounds about right to me.... Figure Subaru brake pads retail for $120ish then talk on labor, yup about right. Be glad you dont own an STI, OEM pads our outrageously priced. ______________ tHe HoV Link to comment Share on other sites More sharing options...
iyalla Posted January 25, 2007 Share Posted January 25, 2007 I agree thats a pretty good price for OEM service and parts. Link to comment Share on other sites More sharing options...
BigJack Posted January 25, 2007 Share Posted January 25, 2007 I just do the pads myself and hit the discs with some sandpaper to scrath them up. You should only really need them cut if they are gouged or warped. Link to comment Share on other sites More sharing options...
hovied Posted January 25, 2007 Share Posted January 25, 2007 Sure do PepBoys cheap semi metallic pads and have them put them on, once they squeal(sp) like a pig destined for bacon you'll wish you had the dealership or yourself do them. Still, you could ask." is that the best price you can do it for?", sometimes they will lower their price. But then again your avatar show's you have GC05's so you must be a "baller" so a simple $200 bones is chicken feed! ______________ tHe HoV Link to comment Share on other sites More sharing options...
one69chev Posted January 25, 2007 Share Posted January 25, 2007 why not just do them yourself. buy the pads from your preferred supplier, lube the slides, clean the rotors and bam---new pads..... Link to comment Share on other sites More sharing options...
hovied Posted January 25, 2007 Share Posted January 25, 2007 why not just do them yourself. buy the pads from your preferred supplier, lube the slides, clean the rotors and bam---new pads..... BAM! ______________ tHe HoV Link to comment Share on other sites More sharing options...
RochNY91TSI Posted January 25, 2007 Share Posted January 25, 2007 ^+1 although how will he resurface his rotors? It's not always necessary to resurface. The fact that the place he's taking them wants to resurface either means that they've run into problems in the past from not doing so, or that they'd like to pad their prices. As was said above, unless you've got some bad grooves cut into your rotors, you don't always need to resurface them. all that said, yeah 200 bucks for 4 wheels plus resurfacing isn't a bad price at all... though I'd still rather do them myself. On the other hand, the OP only mentioned 200 as an *install* price, not install plus parts. Link to comment Share on other sites More sharing options...
Waxiboy Posted January 25, 2007 Share Posted January 25, 2007 Pep Boys resurfaceing is $8/rotor BAM! Link to comment Share on other sites More sharing options...
one69chev Posted January 25, 2007 Share Posted January 25, 2007 ya just gotta love the: Link to comment Share on other sites More sharing options...
whitetiger Posted January 25, 2007 Share Posted January 25, 2007 http://francey.org/templates/emeril/emeril2.gif Link to comment Share on other sites More sharing options...
rvlmtfnk Posted January 26, 2007 Author Share Posted January 26, 2007 well i went back to the dealership to get everything done today because the blizzardy weather + bad brakes = BAD. so i just bit the bullet. apparently the cause of the problem was that my rotors were warped. so they machined all four rotors, and while they were at that, i told them to install new brake pads since they were almost gone anyway. $220 for labor ($110 each for front and rear), $95 for front pads, $85 for rear pads. so total came out to be $410+tax. i gotta say i was very impressed with the service dept at #1 Cochran Subaru. brought the car in, 15 minutes later they tell me what's wrong, and 50 minutes later all the rotors were machined and the brake pads were on. i think they got a few guys to work on the car so that they could get off work by 5pm. but in any case, very prompt service. i would recommend them for sure. Link to comment Share on other sites More sharing options...
docsmile71 Posted January 26, 2007 Share Posted January 26, 2007 Did you know that brakes are covered under warranty? Or is your car out of warranty? I paid about $800-900 to get all four brake pads and rotors done (OEM parts). New pads and rotors including labor. This was at an independent shop before I knew that Subaru covered brakes under warranty. Link to comment Share on other sites More sharing options...
rvlmtfnk Posted January 26, 2007 Author Share Posted January 26, 2007 i'm out of the 3/36 warranty, and the gold plan extended warranty i have doesn't cover brakes... they told me new rotors would have been an addtional $360 for all four, but i guess they wouldn't have had to machine the old ones, so labor would have been less. Link to comment Share on other sites More sharing options...
TCL28 Posted January 29, 2007 Share Posted January 29, 2007 Where exactly in the 3/36,000 warranty are the brakes cited as being covered? Link to comment Share on other sites More sharing options...
one69chev Posted January 29, 2007 Share Posted January 29, 2007 normally, pads are covered for 12k miles or 12 mos because most manufacturers consider them a wear item. now if the material cracks or comes apart, then they might consider that a defect covered after 12k, but i'm not sure about subies.... any ideas... Link to comment Share on other sites More sharing options...
Wales Garage Posted January 30, 2007 Share Posted January 30, 2007 it would have been $685 at my shop with akebono pro-ceramic pads Link to comment Share on other sites More sharing options...
BLACKonBLACK Limited Posted January 31, 2007 Share Posted January 31, 2007 I paid $305 for the installation of all the brake pads, all the SS lines, bleed and installation of a RSB with endlinks. not a bad price but i should have done the job myself. Link to comment Share on other sites More sharing options...
HieroGLFX Posted January 31, 2007 Share Posted January 31, 2007 Did you know that brakes are covered under warranty? Wiper blades are also covered. This is according to the service advisor at a local dealership. Link to comment Share on other sites More sharing options...
Nachowang Posted January 31, 2007 Share Posted January 31, 2007 Wiper blades are also covered. This is according to the service advisor at a local dealership. ^^Indeed, I got mine replaced under warranty... Link to comment Share on other sites More sharing options...
Legacy18E Posted January 31, 2007 Share Posted January 31, 2007 I agree, $200 is good price for resurface and oem pads. Check if they flush your lines with new fluid as well. I have done several brake jobs on other vehicles and alot of times if you don't turn your rotors, the new pads won't seat properley and you will end up warping your rotors beyond repair...Of course it depends on your driving style...But for somone that does not have the time to do it themself $200 for the whole deal is a good price from the dealership. I Link to comment Share on other sites More sharing options...
rvlmtfnk Posted January 31, 2007 Author Share Posted January 31, 2007 just to clarify, it was $220 for LABOR, and add another $190 for brake pads. does that still make it a good deal? Link to comment Share on other sites More sharing options...
