OGHK87Jay Posted November 27, 2012 Share Posted November 27, 2012 I need to find out whats a good replacement axle for my 08 gt Link to comment Share on other sites More sharing options...
mwiener2 Posted November 27, 2012 Share Posted November 27, 2012 $60 auto parts store My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Max Capacity Posted November 27, 2012 Share Posted November 27, 2012 The 2nd axle I got was from Autopart International (206320) and was the correct one. Got that from a PM that someone sent me after they were given the wrong axle from the auto parts store. I posted that p/n back when I replaced one Autopart Int is where Advance Auto Parts got my axle from. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
OGHK87Jay Posted November 27, 2012 Author Share Posted November 27, 2012 would this be it? http://subaru-car-parts.macautoparts.net/CV-Shafts-8224/5694650-2008-2009-Subaru-Outback/ProductInfo.aspx I couldn't find it on advanced autoparts Link to comment Share on other sites More sharing options...
Max Capacity Posted November 27, 2012 Share Posted November 27, 2012 Yes, if you look down in the print, you see the 206320 p/n listed 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
CraigSternberg Posted November 28, 2012 Share Posted November 28, 2012 The 2nd axle I got was from Autopart International (206320) and was the correct one. Got that from a PM that someone sent me after they were given the wrong axle from the auto parts store. I posted that p/n back when I replaced one Autopart Int is where Advance Auto Parts got my axle from. That was me 206320 is the correct one. Advance's computer is WRONG. Their system pulls up a 206319 which is not the same as our axles. They got it from Autopart International. Was $85 Do yourself a favor and pick up the $8 axle oil seal from the dealer also and replace it when you do the seal. They are different part numbers for the driver/passenger sides. I learned the hard way. Damaged the spring in the seal either on removal or install and had to redo the job again two days later with the new seal because I was dribbling tranny fluid. Simple piece of mind to change the seal at the same time and it's painless. Link to comment Share on other sites More sharing options...
06legsleeper Posted November 28, 2012 Share Posted November 28, 2012 i got mine from napa 81 bucks.. Link to comment Share on other sites More sharing options...
OGHK87Jay Posted November 28, 2012 Author Share Posted November 28, 2012 Yea I put in the order for it will swap out this weekend thanks for the help and tips guys. I'm just going to swap out both left and right Link to comment Share on other sites More sharing options...
Bbc84 Posted November 28, 2012 Share Posted November 28, 2012 I put a GSP axle from Advanced Auto in my LGT wagon, and im thinking its causing alot of vibration at a stop. if you search for GSP Subaru other forums are reporting similar issues. I plan on trying raxles or finding a used OEM axle. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 28, 2012 Share Posted November 28, 2012 I put a GSP axle from Advanced Auto in my LGT wagon, and im thinking its causing alot of vibration at a stop. if you search for GSP Subaru other forums are reporting similar issues. I plan on trying raxles or finding a used OEM axle. Can you tell us the p/n on that axle you got ? The one I used was (206320) 100% new parts, not a re-man. No issues after over 2 years. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
mwiener2 Posted November 28, 2012 Share Posted November 28, 2012 The axle causes a vibration at a stop? Remans tend to be better than new aftermarket axles. Remans are freshened up OEM axles so all the dimensions are correct. New axles aren't always built to OEM quality and are not always identical in dimensions to OEM ones. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Max Capacity Posted November 28, 2012 Share Posted November 28, 2012 The axle causes a vibration at a stop? Remans tend to be better than new aftermarket axles. Remans are freshened up OEM axles so all the dimensions are correct. New axles aren't always built to OEM quality and are not always identical in dimensions to OEM ones. I guess you have never done a axle on a honda civic and used a re-man one. With the Free life time replacement. I have changed as many as 4 before I got a good one. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
mwiener2 Posted November 28, 2012 Share Posted November 28, 2012 This isn't a honda forum My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Max Capacity Posted November 28, 2012 Share Posted November 28, 2012 Oh. lol 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
zachste Posted November 28, 2012 Share Posted November 28, 2012 The axle causes a vibration at a stop? Remans tend to be better than new aftermarket axles. Remans are freshened up OEM axles so all the dimensions are correct. New axles aren't always built to OEM quality and are not always identical in dimensions to OEM ones. yes shitty aftermarket axles can cause all kinds of vibrations in all kinds of different cars. Remans are not always better, as the parts are re-ground and can cause varying lengths in the axle causing some issues. I had a torn boot on my passenger. My buddy who owns a shop insisted I just replaced the axle bc they're so cheap. So I had him order one for me. The cheap shitty axle (don't remember brand), caused all kinds of horrendous vibrations while in drive/gear at a stop, as soon as it was installed. Took that garbage axle out and replaced with a not so garbage empi axle for the same price. No vibrations with this one yet. When this one goes I'll just throw my oem axle back in with a fresh boot. If I had more time before needing to replace it, I would've gone with a Raxle from Marty. He only uses new parts and oem shafts. Always received a fantastic product from them, and they're awesome to deal with as well. Link to comment Share on other sites More sharing options...
babybluelgt Posted November 28, 2012 Share Posted November 28, 2012 Your best bet is to go to advance auto and asking them to order from autopart international. I work for API and have installed those axles on numerous cars and never had an issue with fitment or performance. Link to comment Share on other sites More sharing options...
06legsleeper Posted November 28, 2012 Share Posted November 28, 2012 same here, i installed mine went right in, no issues at all fitment was spot on . i installed front passanger axle, new front rotors and pads. all from napa and everything was a great fit think all that was 300 bucks for everything .... Link to comment Share on other sites More sharing options...
mwiener2 Posted November 29, 2012 Share Posted November 29, 2012 So you guys are saying the bad axles cause vibrations.... at a stop? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
06legsleeper Posted November 29, 2012 Share Posted November 29, 2012 it shouldnt cause one at a stand still .... ive never heard of that. and i been workin on cars over 15 yrs so .. a drive shaft will..... not a axle Link to comment Share on other sites More sharing options...
zachste Posted November 29, 2012 Share Posted November 29, 2012 So you guys are saying the bad axles cause vibrations.... at a stop? I think it's mostly experienced in automatic cars. Never had a vibration while in drive at a stop. Put in cheap aftermarket axle, only thing changed, and the cabin/steering wheel vibrated like crazy. Take out and replace with different axle and vibration ceased. This is also been known to happen with vw's (where I've spent most of my car days), and apparently hondas as well. Link to comment Share on other sites More sharing options...
Bbc84 Posted November 29, 2012 Share Posted November 29, 2012 Can you tell us the p/n on that axle you got ? The one I used was (206320) 100% new parts, not a re-man. No issues after over 2 years. The GSP from Advanced Auto went into my 5EAT LGT front passenger side. Part# NCV66002 SKU# 10051717 It was 100% new axle Made in China. Entire car vibrates at a stop. I guess I cant prove it until I swap the axle out again, but so far I found that if i turn the steering wheel when at a stop there will be some sweet spots where the vibration will stop or get alot worst. Another trick I found was to roll forward 1-2" and then stop again and all vibration would be gone. Some links I found after searching around: http://www.subaruoutback.org/forums/66-problems-maintenance/20043-vibration-while-stopped-drive-following-axle-replacement-3.html http://www.subaruoutback.org/forums/66-problems-maintenance/39615-vibration-under-load-stop-what-do.html http://www.subaruoutback.org/forums/66-problems-maintenance/37399-vibration-idle-after-replacing-front-axles-solved-4.html Link to comment Share on other sites More sharing options...
mwiener2 Posted November 29, 2012 Share Posted November 29, 2012 I'm still not seeing how an axle is causing a vibration when it's not moving. The links Bbc84 has posted do show a common vibration issue, but no common solution. Some of the "explanations" for why a Chinese axle can cause a vibration at a stop are complete bull crap. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
zachste Posted November 30, 2012 Share Posted November 30, 2012 I don't have an "explanation" to satisfy you, but I can tell you this. Car has zero vibations, while moving or sitting still. Take out oem axle, put in cheap chinese axle. Vibrations like crazy while at a stop, slight vibrations in wheel at 80 mph. Next day replace cheap chinese axle with higher quality axle, and zero vibrations sitting/moving. The only variable ever changed was the axle. Link to comment Share on other sites More sharing options...
O.C.D. Posted November 30, 2012 Share Posted November 30, 2012 I don't have an "explanation" to satisfy you, but I can tell you this. Car has zero vibations, while moving or sitting still. Take out oem axle, put in cheap chinese axle. Vibrations like crazy while at a stop, slight vibrations in wheel at 80 mph. Next day replace cheap chinese axle with higher quality axle, and zero vibrations sitting/moving. The only variable ever changed was the axle. Harmonic imbalance? That would be about all I can think of for a non-moving part at a standstill? Link to comment Share on other sites More sharing options...
mwiener2 Posted November 30, 2012 Share Posted November 30, 2012 I'm thinking borked install. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
