Zac88 Posted March 15, 2013 Share Posted March 15, 2013 Is it worth the upgrade? Also I have been reading that the JDM SpecB's actually have the whole rear diff carrier and subframe made out of aluminium. Can anyone confirm this or has done the conversion? Link to comment Share on other sites More sharing options...
scoobyscoodle Posted March 15, 2013 Share Posted March 15, 2013 My usdm spec.B has a cast rear diff carrier, steel subframe though. If you had a bunch of suspension mods already, you would likely notice the difference in unsprung weight, but it's not going to be night and day. For the price of the lca/rear trailing arm, I really don't think it's worth it on a lgt. Link to comment Share on other sites More sharing options...
Underdog Posted March 15, 2013 Share Posted March 15, 2013 I don't know too many people who have done the conversion, but I have. Let me dig up the weight differences for you, but know that it is a very small return on investment. The academic difference alone was enough for me, and the aesthetic difference is a bonus. The subframe did not change between the GT and Spec.B. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Underdog Posted March 15, 2013 Share Posted March 15, 2013 Here are the weights for the suspension pieces. I replaced the rear "forward" (camber) and "rear" (toe) links with the Whiteline adjustable control arms, which are probably slightly heavier than stock. The differential cradle is maybe a pound or two lighter than the steel version, but being entirely sprung weight, makes vanishingly little difference. I did notice a subtle improvement in handling, especially with the addition of the trailing arms. The car felt more "nimble". As an OEM parts dealer, I can provide pricing on these for you, if you are interested. Front Control Arms: Steel 7.5lbs - Stamped and Welded Construction Aluminum 6.5lbs - Cast/Forged Construction Rear Trailing Arms: Steel 17.8lbs - Cast Construction Aluminum 11.2lbs - Cast/Forged Construction Upper Lateral Links: Steel 4.9lbs - Cast Construction Aluminum 3.3lbs - Cast Construction The Crimson Dynamo Link to comment Share on other sites More sharing options...
Zac88 Posted March 15, 2013 Author Share Posted March 15, 2013 Thanks for the info guys! So im looking at a 20lbs difference. I have jdm specb rev a struts and springs with 06 specb rims going on soon so im just trying for a full spec b package. Link to comment Share on other sites More sharing options...
Underdog Posted March 15, 2013 Share Posted March 15, 2013 Yeah, just under 20lb difference. For the cash though you could be well on your way to a 6MT+R180 swap, which is going to be leaps and bounds more bad ass and tangible than the aluminum arm swap. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Nrw Posted March 15, 2013 Share Posted March 15, 2013 I toyed with grabbing specB FLCA's when I replaced my bushings but as Underdog mentioned they're pretty costly and deemed it wasn't worth it to me. Link to comment Share on other sites More sharing options...
Zac88 Posted March 16, 2013 Author Share Posted March 16, 2013 Yeah, just under 20lb difference. For the cash though you could be well on your way to a 6MT+R180 swap, which is going to be leaps and bounds more bad ass and tangible than the aluminum arm swap. I'll never do a 6spd swap although I do wish I had DCCD. I am looking into a front LSD though. Link to comment Share on other sites More sharing options...
Underdog Posted March 16, 2013 Share Posted March 16, 2013 I picked mine up from Rallispec back in November. I was concerned that parts for the V5/V6 JDM STI will start becoming more scarce now that it has been 10+ years since production. They were able to provide it very quickly and without trouble. You can get 5MT DCCD if you watch the JDM auction pages. The Crimson Dynamo Link to comment Share on other sites More sharing options...
FX35B4 Posted March 16, 2013 Share Posted March 16, 2013 Just did it few weeks ago... and I can tell the difference. http://i261.photobucket.com/albums/ii56/fx35bl5/89FDB4C8-3D67-47B1-BB7F-306DC52FF77A-4136-00000BEFC898639A.jpg Maybe harder bushings make difference too. Link to comment Share on other sites More sharing options...
TheBlackPearl Posted March 17, 2013 Share Posted March 17, 2013 Pricey bling unless the actual geometry is different I always thought. But if my pockets were quite a bit derper, I mean deeper, I would say hell yeah. Self proclaimed PNW Craiglist find of the day Champion, April 2014. Link to comment Share on other sites More sharing options...
Zac88 Posted March 18, 2013 Author Share Posted March 18, 2013 I picked mine up from Rallispec back in November. I was concerned that parts for the V5/V6 JDM STI will start becoming more scarce now that it has been 10+ years since production. They were able to provide it very quickly and without trouble. You can get 5MT DCCD if you watch the JDM auction pages. theres a bunch of JDM part outs here in Canada. can I steal any 5spd front lsd and use my 4.11 ring on it? Link to comment Share on other sites More sharing options...
boxkita Posted March 18, 2013 Share Posted March 18, 2013 Just did it few weeks ago... and I can tell the difference. http://i261.photobucket.com/albums/ii56/fx35bl5/89FDB4C8-3D67-47B1-BB7F-306DC52FF77A-4136-00000BEFC898639A.jpg Maybe harder bushings make difference too. As DD, this statement would be false. As the track monster this car is, this would be true. Swapping out a heavy wheel for a light wheel plus lighter weight tires will have more effect for less money. When I did my car, I looked at doing this mod. For purely aesthetic reasons, I wish I had done it. Then again, had I had that kind of money I'd be on AST 5300's instead of cheap c/o. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
rapture Posted March 25, 2013 Share Posted March 25, 2013 i did the fronts with bushing upgrades as well def noticed a diff. did the rear lat. links too but jeez those trailing arms are pricey! Link to comment Share on other sites More sharing options...
