eastmentCTD600 Posted November 11, 2011 Share Posted November 11, 2011 '07 LGT, 5eat I have a vibration that I believe is coming from the rear driveshaft (not CV shafts). I placed the car on 4 jackstands, removed wheels and brake rotors, ran the car in gear and inspected the driveshaft while running. The shaft had a visible wobble (I will measure run-out and report later). The car has a fairly strong vibration that is cyclical (indicative of a driveshaft problem). I even used the iPhone with the iSeismometer app to make sure I wasn't crazy. The phone has accelerometers, the app can be used to measure vibration and provide FFT of frequency. The vibration is at driveshaft speed. Looking for: 1.) how many have had to replace/rebuild their rear shaft? 2.) any good shops that do this work in Colorado? 3.) Prices on new and/or rebuilt two piece shaft Notes: The stock shaft has the U-Joint peened into the drvieshaft and flange, so it is not easily serviceable (machining is required to remove the U-joint). Link to comment Share on other sites More sharing options...
whitetiger Posted November 11, 2011 Share Posted November 11, 2011 its easiest just to replace the whole shaft. removing it is easy. you can do it yourself. drop the exhaust, 4 bolts on the rear diff flange and 2 bolts for the u-joint. then just pull it out of the trans. you should be able to find a used one. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 11, 2011 Share Posted November 11, 2011 Make that 4 nut's with lock washers on the rear end of the drive shaft. After the exhaust is lowered, you may need to remove the heat shield, FYI I left the heat shield out on my DD the 05 wagon. The bolts tend to rust and break off. You say you have jack stands so this should be a job you can do. Do a web search for a used drive shaft or contact Fred Beans Subaru for a good price. I found this site, http://www.wholesaleimportparts.com/Subaru_Legacy_Driveshaft_2007.php 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
eastmentCTD600 Posted November 11, 2011 Author Share Posted November 11, 2011 Make that 4 nut's with lock washers on the rear end of the drive shaft. After the exhaust is lowered, you may need to remove the heat shield, FYI I left the heat shield out on my DD the 05 wagon. The bolts tend to rust and break off. You say you have jack stands so this should be a job you can do. Do a web search for a used drive shaft or contact Fred Beans Subaru for a good price. I found this site, http://www.wholesaleimportparts.com/Subaru_Legacy_Driveshaft_2007.php Thanks, I'll check 'em out. I will certainly do the job myself, just wanted to know if this is a common problem, 64k on the car I wouldn't expect the d-shaft to have these issues. I called a driveline shop in Denver after some searching , they can re-build with new U-Joints, balance, straighten, for $235 (Rocky Mountain Driveline). THey handle Subaru stuff all the time so I hope they will do a good job. Link to comment Share on other sites More sharing options...
bmx045 Posted November 11, 2011 Share Posted November 11, 2011 no this is not a common problem, at all. perhaps the car traveled over something and bottomed out and the object hit the shaft? Link to comment Share on other sites More sharing options...
Max Capacity Posted November 11, 2011 Share Posted November 11, 2011 235 sounds like a good deal, I guess you'll be there on Monday... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
eastmentCTD600 Posted November 12, 2011 Author Share Posted November 12, 2011 Found the problem, at 64k mi the front u-joint is SHOT, really notchy. The rear is not very healthy either. The shop will check straightness and replace both U-joints. Link to comment Share on other sites More sharing options...
ThatGuy818 Posted June 5, 2013 Share Posted June 5, 2013 Had vibration at low speeds that progressively got worse. Jacked it up and noticed a bit of play but nothing to alarming didnt think it was the cause. After having it inspected by a couple different shops, I finally accepted that the problem was in fact the drive shaft. Found a company online that specializes in driveshafts and seem to have a pretty good reputation on these forums. Sense I wasnt to willing to buy a new one for the dealers crazy price! or a used one off some car that had been junked or something, I decided to give them a shot. Happy to report I was extremely happy with the way things turned out, got a brand NEW driveshaft for about $460.00, had it installed the after receiving it. Considering what I was gonna pay to have it installed, needless to say I wanted it to work. One of my fears of buying a used one was having it fail shortly after install and having to pay again to have it re installed. 5K miles later and still have a happy Subaru and my wallet is still happy too. Anybody needing a driveshaft should check these guys out! SUBARU DRIVESHAFT Link to comment Share on other sites More sharing options...
