z28dreams Posted July 22, 2014 Share Posted July 22, 2014 Hey all, I live in an apartment, so have no garage, or room to keep a full sized jack/etc. In the past I've done oil changes at friends' garages, but it's starting to be a hassle since I'm commuting a lot more for work. How easily can you change the oil in an LGT without jacking up the car? I only have an emergency spare tire jack, and no jack stands, so it would be a bit of a PITA. I don't really want to buy all that stuff either, because I have a tiny apartment and nowhere to store extra junk. Any cheater/simpler ways to change oil? (With standard oil I might just pay someone else to do it since it's cheap with a coupon, but synthetic is damn expensive - like $50 instead of $25 on my own). Link to comment Share on other sites More sharing options...
K2e2vin Posted July 22, 2014 Share Posted July 22, 2014 Link to comment Share on other sites More sharing options...
K2e2vin Posted July 22, 2014 Share Posted July 22, 2014 I've also parked it where one side of the car is on a steep-enough hill and the other side on flat ground; which gave me just enough room. Link to comment Share on other sites More sharing options...
Drift Motion Posted July 22, 2014 Share Posted July 22, 2014 you can buy a ramp and drive the car up the ramp but don't get under the car with just a scissor jack...or any jack for that matter Link to comment Share on other sites More sharing options...
bluesuby Posted July 22, 2014 Share Posted July 22, 2014 I'm not the smallest guy in the world (6'3" and 230) but I have no trouble pulling the drain plug and getting to the filter with the car on the ground, level ground, in my driveway. Link to comment Share on other sites More sharing options...
FJuan Posted July 22, 2014 Share Posted July 22, 2014 On a stock springs, it should be fairly easy to reach down and take the plug out. Make sure the oil pan is directly in path of the oil before pulling the plug. I'm sure the landlords wouldn't like oil every where. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Wheelbuilder_25 Posted July 23, 2014 Share Posted July 23, 2014 I've got 4 pieces of 2x8 with a beveled edge I drive up on to get just enough room to not burn myself. It also give enough clearance to not need to buy a new floor jack. They store really easy. Link to comment Share on other sites More sharing options...
Vic3 Posted July 23, 2014 Share Posted July 23, 2014 I guess this is probably the only advantage of owning the obxt over the legacy. I was able to change my oil in like 10 minutes without having to Jack the car up. Link to comment Share on other sites More sharing options...
Akasa Posted July 23, 2014 Share Posted July 23, 2014 you can buy a ramp and drive the car up the ramp but don't get under the car with just a scissor jack...or any jack for that matter Ramps. No need to jack up the car, you just drive up them. I understand you don't have much space, but seriously - you can get ones that stack together, and they take up so little space. I've been using ramps to change my oil for a long time. (Except on my Tacoma, I could just walk under that thing ) Link to comment Share on other sites More sharing options...
DonnyJagaru Posted July 25, 2014 Share Posted July 25, 2014 I made a set of mini-ramps for just this sort of thing. Each are three pieces of 2x8 lumber in a "step" config. I put a small piece of wood at the end of the top step so I don't overshoot. I can send dimensions if interested. Link to comment Share on other sites More sharing options...
Scotty Posted July 26, 2014 Share Posted July 26, 2014 I used to change my oil on the ground, but now that my suspension has sagged, can't get my oil pan underneath. I usually just raise the right side of the car by an inch. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 28, 2014 Share Posted July 28, 2014 i made a set of mini-ramps for just this sort of thing. Each are three pieces of 2x8 lumber in a "step" config. I put a small piece of wood at the end of the top step so i don't overshoot. I can send dimensions if interested. x2 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
soloz2 Posted August 4, 2014 Share Posted August 4, 2014 I made some ramps out of 2x12. I'll get 3" of lift just using them, but they connect with a set of rhino ramps if I need more. Sent from my SAMSUNG-SGH-I747 using Tapatalk Current: 16 Crosstrek Premium w/ Eyesight & 05 Outback XT 5MT Past Subies: 14 FXT Premium, 14 WRX hatch, 06 Legacy 2.5i SE 5MT, 98 Outback wagon Link to comment Share on other sites More sharing options...
