987687 Posted January 16, 2013 Share Posted January 16, 2013 He used the AXLES for towing it out? WTF that's so dumb. Makes me mad just reading it Link to comment Share on other sites More sharing options...
kjurkic Posted January 17, 2013 Share Posted January 17, 2013 He used the AXLES for towing it out? WTF that's so dumb. Makes me mad just reading it Sorry, brain damage on my part - meant to say he hooked on lower control arms. Thats how they got bent. He DID say he hooked on the axles though. Scary that he wouldn't know difference. K Link to comment Share on other sites More sharing options...
sti_044 Posted January 17, 2013 Share Posted January 17, 2013 axle, control arm.... same thing Link to comment Share on other sites More sharing options...
LONO100 Posted January 17, 2013 Share Posted January 17, 2013 here's my 97 GT wagon. had to do some minor things to it like a full tune up, radiator flush, i restored the headlights, did some interior mods like installing new visors, repalcing a power window motor and regulator, new wiper blades, i refinished the roof rack and painted that ugly gray cladding black. http://i1229.photobucket.com/albums/ee480/LONO101/20130113_170231.jpg Link to comment Share on other sites More sharing options...
oclvframe Posted January 17, 2013 Share Posted January 17, 2013 here's my 97 GT wagon. had to do some minor things to it like a full tune up, radiator flush, i restored the headlights, did some interior mods like installing new visors, repalcing a power window motor and regulator, new wiper blades, i refinished the roof rack and painted that ugly gray cladding black. http://i1229.photobucket.com/albums/ee480/LONO101/20130113_170231.jpg Very Nice! It's super clean! -r Link to comment Share on other sites More sharing options...
LONO100 Posted January 17, 2013 Share Posted January 17, 2013 Thanks, i want to keep it looking stock with a few upgrades underneath. An msd coil pack, and amsoil air filter, some new pullies, and a suspension upgrade though i havent quite figured out which rpute im going to go on that. Ill post more pics when i get a chance. Link to comment Share on other sites More sharing options...
987687 Posted January 17, 2013 Share Posted January 17, 2013 An msd coil pack, and amsoil air filter, some new pullies Don't waste your money. If you want to improve these cars, better tires, better suspension, better brakes. You'll be amazed what an improvement good tires make. Until you can outdrive your suspension on proper tires, you don't need new suspension. Unless of course it's completely blown. Don't get stupid coilovers just because they have a fancy name and they're red, they'll make it handle like crap unless you spend over $1000. Cheap coilovers suck. GR2 struts are pretty good especially if it's a daily driver and still needs to be comfortable. Link to comment Share on other sites More sharing options...
05LGTLtd Posted January 17, 2013 Share Posted January 17, 2013 ^ yep Pull your plugs and see what they look like. Use a meter to check plug wires. Replace those with OEM as necessary. New air filter, clean MAF and throttle body. Clean up all the ground leads you can find. Pull codes and make sure nothing is stored as well. I always like to get back to zero before spending money on mods. All I need now is a hill holder and a center passing light... Link to comment Share on other sites More sharing options...
LONO100 Posted January 17, 2013 Share Posted January 17, 2013 I wasn't going to go coilovers, I'm just looking to replace the struts because the fronts are completely blown, and the rears aren't far behind. The car has 145k on it and I think they are the same struts that came out of the factory. I was looking into Monroe sensatracs. The tires on the car are nearly brand new kuhmos, not the greatest tires but they are good for a year or two. One of the reasons I scooped this puppy up for 2k. The engine runs solid but feels tired, I changed out the plugs, the wires tested perfect and look like they were a recent replacement, and I can tell I'm not getting a great spark. The coil in it now looks to be a cheap aftermarket replacement. Not looking to do anything big, just upgrades where its needed. Its our commuter car/grocery getter, I by no means intend to race it out! Link to comment Share on other sites More sharing options...
LONO100 Posted January 17, 2013 Share Posted January 17, 2013 ^ yep Pull your plugs and see what they look like. Use a meter to check plug wires. Replace those with OEM as necessary. New air filter, clean MAF and throttle body. Clean up all the ground leads you can find. Pull codes and make sure nothing is stored as well. I always like to get back to zero before spending money on mods. already switched the plugs, tested the wires (all above 10.4) oil change, it has new belts, cleaned the maf and throttle body, it has a new air filter but its a cheapie, flushed the radiator, replaced and resealed rear diff, checked for leaks and the only one I found was the leak in the rear diff, the battery looks old, but tests consistently at 12 and the alternator is charging properly. Just putting upgrades where its needed. Thanks for the tips fellas, my main goal is to get this thing running at optimal and give it a little pep so it can get us up the mountain to Tahoe during snowboarding season. Link to comment Share on other sites More sharing options...
987687 Posted January 17, 2013 Share Posted January 17, 2013 I'd go with the kyb GR2 struts. They're basically an upgraded OEM replacement strut that ride and handle well. Link to comment Share on other sites More sharing options...
05LGTLtd Posted January 17, 2013 Share Posted January 17, 2013 ... and I can tell I'm not getting a great spark. The coil in it now looks to be a cheap aftermarket replacement. Not looking to do anything big, just upgrades where its needed. Its our commuter car/grocery getter, I by no means intend to race it out! I'd still clean up grounds if you have not already. Also contact cleaner on the coil connections and re-test the spark. Then you might decide what if any new coil would be best at that point. Sounds like you on the right track! Good luck with the "new" subaru! I've always liked the "snowfakes". All I need now is a hill holder and a center passing light... Link to comment Share on other sites More sharing options...
LONO100 Posted January 18, 2013 Share Posted January 18, 2013 Ill take your advice on the grounds and give them a once over this weekend. Ive been teaching my gf how to drive stick in it. The shifter was kinda mushy, and after all the lessons, its even mushier! Im gonna replace the shifter bushing to see if that helps the spongy feeling. Link to comment Share on other sites More sharing options...
97wagon Posted January 18, 2013 Share Posted January 18, 2013 So many great wagons! Where did yous all find the hoods or are they custom made? Link to comment Share on other sites More sharing options...
shwagon Posted February 2, 2013 Share Posted February 2, 2013 (edited) My 94 L http://i.imgur.com/vaKSa0O.jpg http://i.imgur.com/6tGhTHd.jpg All clean haha http://i.imgur.com/xVn2Nk4.jpg Edited February 2, 2013 by shwagon Link to comment Share on other sites More sharing options...
Niterider03 Posted February 5, 2013 Share Posted February 5, 2013 she will be dropped another inch and a half on thursday Your car looks awesome. What brand of coilovers are you on? Link to comment Share on other sites More sharing options...
djlive06 Posted February 6, 2013 Share Posted February 6, 2013 custom 08 wrx/sti suspension with 08 wrx sti sport struts Link to comment Share on other sites More sharing options...
djlive06 Posted February 15, 2013 Share Posted February 15, 2013 new pics from a meet not to long ago. she is getting dropped another inch to an inch and a half on monday and will be at her final sitting height then pretty pumpep Link to comment Share on other sites More sharing options...
987687 Posted February 15, 2013 Share Posted February 15, 2013 My wagon actually has functional purposes http://i190.photobucket.com/albums/z314/987687/purpy/IMG_4676_zpsa6d402dd.jpg Link to comment Share on other sites More sharing options...
djlive06 Posted February 21, 2013 Share Posted February 21, 2013 teaser pics of my new low lol dropped another 2 inches...her final resting place clearence? aint no body got time for that! \ and one shitty cellphone pic Link to comment Share on other sites More sharing options...
kenny_fatlace Posted February 22, 2013 Share Posted February 22, 2013 Took some updated pictures tonight and have not submitted to this thread yet so here it is: http://farm9.staticflickr.com/8507/8497461008_56a74c28b2_o.jpg http://farm9.staticflickr.com/8110/8496357669_48cae64f75_b.jpg Here is a link to images from the past year of the build: http://legacygt.com/forums/showthread.php/my-first-subaru-and-intro-190813.html Link to comment Share on other sites More sharing options...
Dragon-Wagon Posted February 22, 2013 Share Posted February 22, 2013 Welcome to the family Kenny. That is one fresh wagon you have, and I'm very jealous of the rhd. Link to comment Share on other sites More sharing options...
djlive06 Posted February 22, 2013 Share Posted February 22, 2013 shes not clean by any stretch of the imagination lol but shes my daily https://sphotos-b.xx.fbcdn.net/hphotos-snc6/285393_10200172358044493_307421560_n.jpg Link to comment Share on other sites More sharing options...
djlive06 Posted February 22, 2013 Share Posted February 22, 2013 shes not clean by any stretch of the imagination but shes my daily Link to comment Share on other sites More sharing options...
KeyLimePi3 Posted February 23, 2013 Share Posted February 23, 2013 http://i853.photobucket.com/albums/ab97/herald_c/F3813309-388E-4D43-8E42-B8084D91A9E9-89-00000000A7DCA3BD.jpg If you're wondering about the hood scoop: http://i853.photobucket.com/albums/ab97/herald_c/9DEAE897-79D4-41C5-855F-942BD81D5B08-6250-000008FDF6EC1D82.jpg Link to comment Share on other sites More sharing options...
