NORULZleggy Posted August 27, 2015 Share Posted August 27, 2015 Is there an easy way to get to the upstream 02 sensor? I am going to replace the one on my 08 Legacy and 06 Outback. It looks like a pain to get to. I attempted tonight but stopped due to the fact I need the car for work and did not want to break or bend something. this cant be that hard. Hell I pulled the motor on this thing. Just chime in. Link to comment Share on other sites More sharing options...
compsurge Posted August 27, 2015 Share Posted August 27, 2015 On the turbo cars you can get it from the wheel well. Is there a reason for replacing it? Link to comment Share on other sites More sharing options...
dookie Posted August 27, 2015 Share Posted August 27, 2015 (this is the NA forum...) Link to comment Share on other sites More sharing options...
NORULZleggy Posted August 27, 2015 Author Share Posted August 27, 2015 Ahaah thanks dookie. Yes my car is 08 2.5i. There is no reason for replacement. I have a nice car fund that I just save money in and want to spend some cash on the car. The car has 142K mile's on it. I have pulled the motor and replaced the HG's, water pump, and everything you could think of with OEM Subaru parts. I replaced the sensor before the cat two months ago cause the car was throwing codes all the time. After the new sensor, it runs very well. I am wanting to replace the upstream because I found some very nice clearance 02's (that I researched before I bought to make sure it was not junk) from rockauto for 46 buck.These were originally 93 buck. Hell if they go bad oh well I will buy two more. They look like the 100 dollar quality one and the company has a good rep. Link to comment Share on other sites More sharing options...
compsurge Posted August 27, 2015 Share Posted August 27, 2015 I am well aware this is the NA forum. If you look for where it is located, that would tell you how to get at it... I looked at the diagrams and it should be accessible from the wheel well. O2 sensors are typically around $40 for a universal fitment Bosch or Denso that is the same sensor. It seems like you just want to spend money on a replacement that may or may not be needed for peace of mind. Link to comment Share on other sites More sharing options...
whitetiger Posted August 27, 2015 Share Posted August 27, 2015 if the sensor is not bad, there is no need to waste money on a replacement. Link to comment Share on other sites More sharing options...
NORULZleggy Posted August 27, 2015 Author Share Posted August 27, 2015 I understand the do not replace this and that. To me its not a waste of money. I have the parts. Everyone treats there cars different. I want to replace it since I replaced the other one. That's just me. I know were it's located and the one you talking about by the wheels well is the LGT or WRX. The rear on the cat was easy to replace. I had an 04 STI and know a good deal about the location. On the 2.5I it's pretty much right in front of the oil filter cause I can see the filter. I will post a picture of the location. I was thinking I need the tall 02 socket. I have the harbor freight one that did the job. I am just looking to get leverage in the location. Link to comment Share on other sites More sharing options...
apexi Posted August 28, 2015 Share Posted August 28, 2015 I thought of this thread when I was replacing my plugs tonight, and took a few pictures from above with the ram air piece removed, and whole air box removed. If it were me, I'd probably try to remove it from above with the ram air out of the way. I've never replaced either of my oxygen sensors, but that looks like the way I'd try. Here's a picture I took a few years ago from below, can't really see it there. http://legacygt.com/forums/attachment.php?attachmentid=195015&d=1414179093 And I can't remember how much of the sensor you can see from the oil filter area, shown below from another older picture. But it looks like it might be annoying to access with the oil filter there. http://legacygt.com/forums/attachment.php?attachmentid=186822&d=1404487490 *Come to think of it, I think you'll have to remove the ram air anyways to unplug the sensor. So another reason to try from up top first. Link to comment Share on other sites More sharing options...
NORULZleggy Posted August 28, 2015 Author Share Posted August 28, 2015 I thought of this thread when I was replacing my plugs tonight, and took a few pictures from above with the ram air piece removed, and whole air box removed. If it were me, I'd probably try to remove it from above with the ram air out of the way. I've never replaced either of my oxygen sensors, but that looks like the way I'd try. Here's a picture I took a few years ago from below, can't really see it there. http://legacygt.com/forums/attachment.php?attachmentid=195015&d=1414179093 And I can't remember how much of the sensor you can see from the oil filter area, shown below from another older picture. But it looks like it might be annoying to access with the oil filter there. http://legacygt.com/forums/attachment.php?attachmentid=186822&d=1404487490 *Come to think of it, I think you'll have to remove the ram air anyways to unplug the sensor. So another reason to try from up top first. Yes, that is the exact sensor I am talking about. The one in front of the oil filter. Yes you do have to remove the ram air. It is annoying. I am going to try from the top again and use a long 02 Sensor. I will make a how to for the 2.5i people. I have a shelf full of new stuff I am adding. Guess I am bored. Link to comment Share on other sites More sharing options...
scottmcphee Posted September 6, 2015 Share Posted September 6, 2015 Well, after replacing both O2 sensors I'm still throwing P0139 code.... send your bin of extra parts my way. MAYBE one of them will shut my OBD2 up! I MISS cruise control with the damn blinky light and Check Engine. Link to comment Share on other sites More sharing options...
compsurge Posted September 7, 2015 Share Posted September 7, 2015 Well, after replacing both O2 sensors I'm still throwing P0139 code.... send your bin of extra parts my way. MAYBE one of them will shut my OBD2 up! I MISS cruise control with the damn blinky light and Check Engine. The oxygen sensor is faultyThe wiring to the sensor is broken / frayedThere is an exhaust leak Read more at: http://www.obd-codes.com/p0139 Copyright OBD-Codes.com Have you tried investigating the other two possibilities? Link to comment Share on other sites More sharing options...
apexi Posted September 7, 2015 Share Posted September 7, 2015 ^ I agree. While an exhaust leak may not make a lot of sense at first, I'm reading the amount of back pressure in the exhaust (too little?) could throw that code. Having an exhaust leak could alter the back pressure and f things up. Link to comment Share on other sites More sharing options...
NORULZleggy Posted September 8, 2015 Author Share Posted September 8, 2015 scott, I can send you my old one lol. Link to comment Share on other sites More sharing options...
SubOperator Posted November 10, 2015 Share Posted November 10, 2015 Have you managed to write a how-to? 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K 2007 B9 Tribeca Limited DGM - 258K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
GEE-OTTO Posted November 12, 2015 Share Posted November 12, 2015 Have you checked the harness? Trace that to its terminus and ensure there are no issues, sometimes things get caught/cut/nicked while working in and around the engine bay. Also is the sensor in tight? Both of them? All piping connected snugly? I would stick to DENSO sensors they seem to never cause issues. Ive used them as replacements on both my LGT and 2.5i. Link to comment Share on other sites More sharing options...
NORULZleggy Posted November 13, 2015 Author Share Posted November 13, 2015 I am going to do it tomorrow, Including another hub on my Outback, and full JL Audio install. I will have a write up. Link to comment Share on other sites More sharing options...
