NORULZleggy Posted May 14, 2012 Share Posted May 14, 2012 I am getting up clost to 100K mark, I want to do the Timing belt, Water pump, and Tensors (sorry Spelling sucks). I need to know if the the legacy GT Gates kit with the water pump will work or is it different. I did look in the 2.5I FAQ and saw nothing about it. So is there a seperate Gates kit or not? Thanks Link to comment Share on other sites More sharing options...
GloNDark Posted May 14, 2012 Share Posted May 14, 2012 The GT is a DOHC and the NA motors are SOHC. I just ordered my kit for my 06 there is a specific kit for our cars. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted May 16, 2012 Share Posted May 16, 2012 I am getting up clost to 100K mark, I want to do the Timing belt, Water pump, and Tensors (sorry Spelling sucks). I need to know if the the legacy GT Gates kit with the water pump will work or is it different. I did look in the 2.5I FAQ and saw nothing about it. So is there a seperate Gates kit or not? Thanks Here I just did this and you should follow the same path : Just ordered a basic front engine reseal and Timing kit from http://www.RockAuto.com GATES Part # K050344 Alternator and Power Steering $10.56 GATES Part # K040332 Air Conditioning $10.72 FEL-PRO Part # TCS46009 Crankshaft Front Seal Set $7.35 FEL-PRO Part # TCS46008 Camshaft Front Seal Set $5.59 TIMKEN Part # 710236 Oil Pump Seal $4.72 GATES Part # TCKWP307A 6 Components $198.79 With shipping I paid $237.79 The dealer wanted 2.5x MORE for the same parts. Will do the whole job on the weekend the parts hit my doorstep should be fun! Link to comment Share on other sites More sharing options...
GloNDark Posted May 16, 2012 Share Posted May 16, 2012 Here I just did this and you should follow the same path : Now that should be a sticky!! Nice parts list. Link to comment Share on other sites More sharing options...
SCHM1AN Posted May 16, 2012 Share Posted May 16, 2012 Just FYI, there is a thread out there on how to replace the timing belt, etc. That should save you a few bucks in labor if you can DIY Link to comment Share on other sites More sharing options...
cmbezln Posted May 29, 2012 Share Posted May 29, 2012 Get ready for head gaskets! Link to comment Share on other sites More sharing options...
c-lo Posted May 29, 2012 Share Posted May 29, 2012 ^ is this a problem for the NA's? I'm at 199,400 on my GT and this hasn't been an issue for me. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted May 29, 2012 I Donated Share Posted May 29, 2012 Skip the cam seals. Not worth it unless you're taking the pulleys off for some other reason. Also skip the oil pump seal, and the accessory belts are easy enough to change sometime else that you should only do them if they're in bad shape. And I'm assuming the Gates kit includes the water pump. c-lo, I have seen reports of HG issues on higher-mileage EJ253s. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted May 30, 2012 Share Posted May 30, 2012 Skip the cam seals. Not worth it unless you're taking the pulleys off for some other reason. Also skip the oil pump seal, and the accessory belts are easy enough to change sometime else that you should only do them if they're in bad shape. And I'm assuming the Gates kit includes the water pump. c-lo, I have seen reports of HG issues on higher-mileage EJ253s. So when the cams seals start weeping at 122k he will have to pay the same labor to get them fixed??? Don't skip the cams seals the shop doing the work can get the gear off and seals installed and the seals are $5 great insurance against touching the front engine for another 100K Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted May 30, 2012 I Donated Share Posted May 30, 2012 I mean, I guess if you are having the work done for you, but it's too easy to screw things up getting the cam gears off if you're doing it yourself. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted May 30, 2012 Share Posted May 30, 2012 I mean, I guess if you are having the work done for you, but it's too easy to screw things up getting the cam gears off if you're doing it yourself. very true i tapped one in crooked on the RS once and while trying to fix it (after driving and dumping oil all inside the timing cover ) I cracked the gear. Link to comment Share on other sites More sharing options...
cmbezln Posted May 30, 2012 Share Posted May 30, 2012 ^ is this a problem for the NA's? I'm at 199,400 on my GT and this hasn't been an issue for me. It's a problem with subbies across the board according to the 40-year mechanic I used to work with. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted May 30, 2012 I Donated Share Posted May 30, 2012 very true i tapped one in crooked on the RS once and while trying to fix it (after driving and dumping oil all inside the timing cover ) I cracked the gear. As I said, Not worth it unless you're taking the pulleys off for some other reason. Basically, you created a problem that wasn't there before by replacing the seal, and then created yet another problem (that cost money) trying to fix that problem. The chances of the seal starting to leak were low enough that you probably would never have incurred those problems otherwise. Link to comment Share on other sites More sharing options...
