Doing a timing belt change. Hit a bit of a snag
So I am in the middle of a timing belt change and I have two issues. One minor the other hopefully minor.
The kit I got has the wrong tensioner. No biggie I can just do the pully.
The other issue, I had the timing marks lined up, went in the back yard to put the tensioner in a vice, and came back to find the driver side timing mark at 6 o clock instead of 12 o clock. Which way should I turn the driver side cam pully to properly align it?
Now that I go and look at it again, the crank pulley doesn't have a visible notch on it either, just a red mark that is pointed at about 2 o clock. I guess I would be fine turning the driver side cam pulley clockwise until it is straight up, installing everything, and rotating the engine until I can see the notch on the crank pulley. Does that sound like a valid plan? The last thing I want is bent valves.
http://i.imgur.com/QCAaaaP.jpg
When I had done a timing belt on my 97 gt the belt itself had marks on it that corresponded to the marks on the pulleys. Just a thought.
Even if you aren't completely sure crank the motor by hand on the crank pulley bolt. Make sure it goes through a full revolution. Should do that anyways. This way if something is wrong you'll feel it and not have the starter still trying to crank after it hits something.
That is my other plan. I just went and looked again and while there isn't a notch on the crank pulley I can see or feel, the red mark on the pulley lines up with the notch on the CPS housing and the arrow on the pulley is pointed at 3 o clock, where it should be. So, while I don't know exactly how the cam turned It shouldn't be far off.
That being said, the rest of the process went relatively smooth. Crank bolt came right out, crank pulley wasn't too much of a bear either. However, I am covered in PS fluid from the leaky pump. Just a few rusty bolts on the cam covers and the radiator fans.
Seems like you have it figured out.
Don't look for the notch on the crank pulley.
Look for the hash mark on the crank sprocket. When it is lined up, the key way will be at 6 o'clock.
See the sticky for FSM.
O.
I had a slight problem with terminology. I was referring to the markings on the cam sprocket not the crank pulley. I went an looked, felt, and took pictures of the cam sprocket. There are no markings other than the orange dash and a small arrow. Nothing on any of the bump outs for the CPS as noted in the FSM. The orange dash lines up almost perfectly at 44 teeth from the orange mark on the passenger side cam pulley.
when the crank is right,
the key way is in the 6 o'clock position.
and the small triangle, if there is one, is point at 3 oclock.
on the cams, the arrow on the spoke is pointing at 1.5 o'clock.
halfway between 12 and 3.
http://legacygt.com/forums/data:image/jpeg;base64,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
images?q=tbn:ANd9GcRj9ha0B5Qy1-RI401ugQC16kXz_tLg9P7gPSw9f2rPzUmWAhBQWQ
images?q=tbn:ANd9GcT8GSWtAHl-aZ_E5HlakNHBGzOMVOWIXkQPnXT0C5OfW4gEnMho
when the crank is in the correct timing alignment position,
ALL pistons are at mid-stroke,
halfway between top and bottom.
there is no way for the valves to hit the pistons.
but if you incorrectly put #1 at TDC as all other car makers require,
then you could cause damage by turning the cams.
