channoff Posted May 11, 2013 Share Posted May 11, 2013 I was under full boost on uphill onramp and i thought my transmission exploded. Turned the radio down and realized it sounds more like the exhaust is gone. I blew an uppipe gasket on my old WRX and it sounds a lot like that, maybe worse. Also, cruise light is blink and no CELs. Searched and searched and I can't find anything here that is similar. Lots of headaches and $$$ with the 4 months I've owned this car. Any ideas? Maybe a step-by-step list that I should check? I limped it home 2 miles and car ran fine, but did I mention it's LOUD. Help! Link to comment Share on other sites More sharing options...
wurkenman Posted May 11, 2013 Share Posted May 11, 2013 Best thing to do is jack it up and look. Let us know what you do , or DON'T find. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
channoff Posted May 11, 2013 Author Share Posted May 11, 2013 Best thing to do is jack it up and look. Let us know what you do , or DON'T find. Stay tuned.... Just hoping it is vacuum or exhaust related and not something ridiculously expensive. Link to comment Share on other sites More sharing options...
channoff Posted May 11, 2013 Author Share Posted May 11, 2013 Very good news after my initial panic. The O2 sensor popped out of my manifold. What would be the easiest way to fix this? Doesn't look like it will just press in. http://i1320.photobucket.com/albums/u528/Chance_Noffsinger/IMG_3954_zps8fbfe72b.jpg Link to comment Share on other sites More sharing options...
channoff Posted May 11, 2013 Author Share Posted May 11, 2013 After further examining photo, those threads are damaged on sensor. Weld it or buy a new sensor? Link to comment Share on other sites More sharing options...
wurkenman Posted May 11, 2013 Share Posted May 11, 2013 Yup O2 sensor is toast. Looks like the threads in the mani are still ok. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
channoff Posted May 11, 2013 Author Share Posted May 11, 2013 Agreed. I am just going to order a new sensor for $130. Guessing it was cross threaded and was like this when I bought it a few months ago. It also might be the culprit for the small exhaust leak I have been hearing. Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted May 11, 2013 Share Posted May 11, 2013 ^my guess someone that worked on it before you bought it, left it loose and it finally worked its way out. definatly dont put that back, you will damage the threads in manifold Link to comment Share on other sites More sharing options...
channoff Posted May 11, 2013 Author Share Posted May 11, 2013 ^my guess someone that worked on it before you bought it, left it loose and it finally worked its way out. definatly dont put that back, you will damage the threads in manifold Already took it off the car. Can anyone verify that the correct part # for 05 LGT is 22641AA32A? If so, looks like local dealer has it for about $150ish. Link to comment Share on other sites More sharing options...
MAP Posted May 12, 2013 Share Posted May 12, 2013 Rockauto.com has a much more reasonable price for the denso sensors if you can wait for it to arrive. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 13, 2013 Share Posted May 13, 2013 You may want to call around to the local auto parts stores. The prices very by some can get you one in a few hours. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
channoff Posted May 13, 2013 Author Share Posted May 13, 2013 I bought the Denso version on Amazon for $101. Should be here tomorrow. Link to comment Share on other sites More sharing options...
