lilbrudder Posted November 1, 2008 Share Posted November 1, 2008 Can this cable be use to Read/Flash the ECU? I've tried to read a couple times and I keep getting "Interface Close" error. Has anyone got this cable to read/write the ROM? Link to comment Share on other sites More sharing options...
Jon in CT Posted November 1, 2008 Share Posted November 1, 2008 Try using version 1.29a of EcuFlash, instead. http://freon.shackspace.com/car/ecu%20and%20tuning/openecu/ecuflash_setup129a.exe Link to comment Share on other sites More sharing options...
qikslvr Posted November 1, 2008 Share Posted November 1, 2008 Yup, use the software listed below and it will work. I have used mine to pull the ROM image off my ECU before and it worked fine. Just make sure you have the correct drivers installed and the COM settings are configured as directed in my "Using the Autonostics Cable to Log" thread and it should see the ECU and copy the image just fine. Good Luck and let us know how it's going. I was the first person to get this cable to work and have just a little working knowledge of it;); so feel free to ask questions and let us know what's up. Let's kick this pig! Link to comment Share on other sites More sharing options...
lilbrudder Posted November 2, 2008 Author Share Posted November 2, 2008 I tried that software, I got another error message but basically saying the same thing. It seemed be loading really slow. You got it to work, so I'm going to uninstall everything and try reinstalling it. Are the com setting in the Ecuflash program or on my pc? Are these the only drivers i need? http://autonostics.com/pages.php?pageid=3 Link to comment Share on other sites More sharing options...
qikslvr Posted November 2, 2008 Share Posted November 2, 2008 Those should be the drivers. I see that you've been to my thread. The "BAUD" settings you need to change will be in windows. Once you get the driver and software installed; you need to go to "Windows Device Manager" in there you need to look for the sub-list of ports(includes LPT and COM ports) in there you will need to find the COM port that was assigned to your cable. When you find your cable; right click on it and go to properties. Once you get to the properties tab; you will need to change the BAUD rate from 9600 to 4800. This will stabilize the communications and the software should see the car and lock in on it. After that the logging software and ECUFlash should both work. As stated before; I've used successfully muptiple times. Let's kick this pig! Link to comment Share on other sites More sharing options...
lilbrudder Posted November 3, 2008 Author Share Posted November 3, 2008 oh, excellent, i found where you are talking about. didn't get to try the cable again yet but will do next chance i get and keep ya posted. thanx for the help. Link to comment Share on other sites More sharing options...
lilbrudder Posted November 3, 2008 Author Share Posted November 3, 2008 Wait, I don't think those drivers auto installed? what program did you se to open the driver file? if i can data logg with the cable than the drivers are installed right? Link to comment Share on other sites More sharing options...
qikslvr Posted November 3, 2008 Share Posted November 3, 2008 If the drivers are installed and you can log then they are installed properly. The cable usually pops up and COM3 or COM4. If the cable has already been plugged and you have been throught the hardware install wizard then they should arleady be there. Then it's just a matter of going into device manger and the properties for the COM Port that the cable was assigned to and setting the BAUD rate to 4800. If it works to log; it should work to flash. Let's kick this pig! Link to comment Share on other sites More sharing options...
lilbrudder Posted November 4, 2008 Author Share Posted November 4, 2008 Ok, cool I didn't remember doing an install for them but i was installing and uninstalling lots of software, like you said if i'm logging it's G2G. Thanx, i'll give it another go tomarrow hopefully. Link to comment Share on other sites More sharing options...
lilbrudder Posted November 7, 2008 Author Share Posted November 7, 2008 Well I have been trying to get it going all morning but still haven't got it to read or write. I changed the buad rate and reinstalled all the drivers/programs, I'm not sure where to go from here. There is no problem logging, but i keep getting this when i try to read the ECU: [00:08:09.443] unable to open OpenPort device [ Serial ]. [00:08:09.443] unable to connect to vehicle interface. [00:08:13.459] unable to open OpenPort device [ Serial ]. [00:08:13.459] unable to connect to vehicle interface. Any thoughts? I want this to work so I don't mind trying things, please throw those ideas out there(even simple things i may have over looked). Link to comment Share on other sites More sharing options...
qikslvr Posted November 9, 2008 Share Posted November 9, 2008 I use ECUflash version 134.1435. What version are you using? Go to help and then about to find the version number. Let's kick this pig! Link to comment Share on other sites More sharing options...
lilbrudder Posted November 9, 2008 Author Share Posted November 9, 2008 i'm using the version Jon posted above... Version 1.0 StartHTML:0000000105 EndHTML:0000000626 StartFragment:0000000513 EndFragment:0000000590 Version 1.29.906 Link to comment Share on other sites More sharing options...
qikslvr Posted November 10, 2008 Share Posted November 10, 2008 See if you can find the version I have. If not I can probably e-mail it to you. Look at the other thread too. I posted a quick rundown of how to re-install and configure the cable. Let's kick this pig! Link to comment Share on other sites More sharing options...
lilbrudder Posted November 10, 2008 Author Share Posted November 10, 2008 i saw the other thread, great walk through. tried it right after i saw it, same prob still. is that the newest version you are running? Link to comment Share on other sites More sharing options...
qikslvr Posted November 12, 2008 Share Posted November 12, 2008 Nope mine is from like January of this year. I'll see if I can find the install file and I'll pm you for your e-mail. If the instructions I gave didn't work, it may be another bad cable. We had a couple of them up and running in minutes on different laptops and different cars. Let's kick this pig! Link to comment Share on other sites More sharing options...
lilbrudder Posted November 25, 2008 Author Share Posted November 25, 2008 thanx qik, that ecutec version is alot faster but i still can't get it to read. this is the error i get: [14:17:22.833] SSM2 init [14:17:23.394] SSM2 init [14:17:23.844] SSM2 init [14:17:24.295] SSM2 init [14:17:24.775] SSM2 init [14:17:25.226] SSM2 init [14:17:25.707] SSM2 init [14:17:26.178] SSM2 init [14:17:26.658] SSM2 init [14:17:27.139] SSM2 init [14:17:27.750] kernel get version [14:17:28.631] interface close [14:17:28.681] interface close are you using USB 2.0? i think 'm running on 1.1 with this lappy, not sure if it matters. Link to comment Share on other sites More sharing options...
qikslvr Posted November 26, 2008 Share Posted November 26, 2008 USB version shouldn't matter. I used a USB mouse cable for an extension and it still worked. Are you connecting the Green Dignostics plugs in the passenger side floorwell when try to connect to with ECUflash? Let's kick this pig! Link to comment Share on other sites More sharing options...
lilbrudder Posted November 27, 2008 Author Share Posted November 27, 2008 WTF??? passenger side?? i've been connecting a single wire green plug located in my fuse box! i got to check on this in the morning Link to comment Share on other sites More sharing options...
qikslvr Posted December 2, 2008 Share Posted December 2, 2008 Ya, the "TEST CONNECTORS" are two green plugs that are located in the passenger side floor area. They are tucked under the carpet all the way at the top of the carpet about in the middle behind the glove box. You need to have them connected and have the key in the "ON" position to be able to read or flash the ecu. This may help just a little. Let's kick this pig! Link to comment Share on other sites More sharing options...
lilbrudder Posted December 2, 2008 Author Share Posted December 2, 2008 any way to tell if have the right ones? Link to comment Share on other sites More sharing options...
qikslvr Posted December 3, 2008 Share Posted December 3, 2008 Yup. They should be tucked away in their own little pocket under the top of the carpet and they should connect to each other. Once connected and the key is turned forward; your odometer will display "ER HC". This means that the car is in diagnositcs mode. Let's kick this pig! Link to comment Share on other sites More sharing options...
lilbrudder Posted January 14, 2009 Author Share Posted January 14, 2009 Hey qikslvr, I finally found the the other wires and flashed mickeyd stageI. The wires on the passenger side look identical to the ones i found on the drivers side and they both display the same ER HC message when connected, which is wierd but good to know now. With the right wires connected the process was fast, smooth, and fflawless. Thanks for your patients and saving me litteraly hundreds of dollars, the car feels amazing. Link to comment Share on other sites More sharing options...
SBT Posted January 15, 2009 Share Posted January 15, 2009 I ordered this cable the week before Christmas and it's still not here and no response from the vendor. Not happy:mad: - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Spec B Posted January 16, 2009 Share Posted January 16, 2009 Me too, ordered it from autonostic...hen I got sick of waiting and ordered an ebay one, then I got sick of waiting and bought a used Tactrix cable..should come in soon. I am going to dispute the autonostic purchase..the ebay one I will keep. Link to comment Share on other sites More sharing options...
