GTTuner Posted August 21, 2013 Share Posted August 21, 2013 I may have been dreaming but did I see someone on here had installed a TOB/slave similar to this: http://static.1aautoimages.com/partimage/CSC/1ACSC00004/large.JPG Link to comment Share on other sites More sharing options...
GTTuner Posted August 22, 2013 Author Share Posted August 22, 2013 Hoping someone can do me a favor. I am going to install one of these in my car. There are several companies that make universal hydraulic TOB's I need to know the OD and the length of the snout on the 5 speed. If anyone has a trans out and can measure for me I would really be grateful. Link to comment Share on other sites More sharing options...
GTTuner Posted August 23, 2013 Author Share Posted August 23, 2013 Ok thanks for the help guys:rolleyes: , it seems there is someone out there using this http://www.tiltonracing.com/sites/default/files/editor_uploads/files/Tilton2012%20-%20HRB%20-%209000%20Series.pdf in a late model 5 speed WRX trans. Once I get some details together I'm going to start some research and development with a local machine shop. At this moment if anyone has a 5 speed that has failed, even with a damaged snout I would be interested in buying it just for R&D purposes. PM me if you have something. read this; http://www.shoptalkforums.com/viewtopic.php?f=19&t=142658 Link to comment Share on other sites More sharing options...
Underdog Posted August 23, 2013 Share Posted August 23, 2013 Interested. I will have an engine out of a customers car early next week and can take some measurements for you. I would be interested in trying one in my car. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted August 23, 2013 Moderators Share Posted August 23, 2013 What's the benefit here? "WHY" are you trying to do this? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
GTTuner Posted August 23, 2013 Author Share Posted August 23, 2013 What's the benefit here? "WHY" are you trying to do this? WHY NOT? Where the hell have you been? Damn TOB failures on these cars is of epic proportions. It is the cheapest, crappiest design of any car I have ever owned. At this point what do we have to loose? I'm pulling my trans for the fifth time because of a noisy, failing TOB. I've owned manual trans cars all my life and never have I has so many problems with a clutch than in this car. If it wasn't for the clutch I would say this is the most reliable car I have ever owned. Period. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted August 23, 2013 Moderators Share Posted August 23, 2013 WHY NOT? Where the hell have you been? Damn TOB failures on these cars is of epic proportions. It is the cheapest, crappiest design of any car I have ever owned. At this point what do we have to loose? I'm pulling my trans for the fifth time because of a noisy, failing TOB. I've owned manual trans cars all my life and never have I has so many problems with a clutch than in this car. If it wasn't for the clutch I would say this is the most reliable car I have ever owned. Period. Reliability, got it. I just didn't know what the goal was here--makes sense from that perspective. I have to pull my trans again shortly as well, interested in what you come up with here. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Max Capacity Posted August 23, 2013 Share Posted August 23, 2013 WHY NOT? Where the hell have you been? Damn TOB failures on these cars is of epic proportions. It is the cheapest, crappiest design of any car I have ever owned. At this point what do we have to loose? I'm pulling my trans for the fifth time because of a noisy, failing TOB. I've owned manual trans cars all my life and never have I has so many problems with a clutch than in this car. If it wasn't for the clutch I would say this is the most reliable car I have ever owned. Period. NA NA I have you beat, the wagons tranny's been out 8 times. But not one time for a TOB. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GTTuner Posted August 23, 2013 Author Share Posted August 23, 2013 Reliability, got it. I just didn't know what the goal was here--makes sense from that perspective. I have to pull my trans again shortly as well, interested in what you come up with here. Will keep you posted. NA NA I have you beat, the wagons tranny's been out 8 times. But not one time for a TOB. :lol: Now you jinxed yourself! By the way Max, would you believe me if I told you my car doesn't use oil? 66K since my rebuild and she is using 1/8 of a quart every 3-3500 miles. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 24, 2013 Share Posted August 24, 2013 1/8 of a qt is not bad, not like a Honda but that's pretty good. My wagon has 21K on the ej257 and uses about 1/2 qt in 7000 mile oil change on the Amsoil 5w-40. The Spec B uses about a 1/8 qt in that time, it has 51.6K, just did the oil change today. It had 6700 miles the last oil. Actually I'm running the TSK3 TOB with on sleeve, I did grease the snout and had the Tech grease the snout when he put the tranny back in a couple weeks back. Not sure you saw the inside of my tranny and the broken main shaft, you can see the snout here. http://i185.photobucket.com/albums/x40/92Si/DSCN5295_zps3025c9b3.jpg 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Underdog Posted September 11, 2013 Share Posted September 11, 2013 Paul - I have that 5-speed wagon sitting in the shop with the engine out for machining & rebuild. Do you need me to snag any dimensions? The Crimson Dynamo Link to comment Share on other sites More sharing options...
Th3Franz Posted September 11, 2013 Share Posted September 11, 2013 What do you think of the new ACT monoloc? I'm installing mine with my 6-speed swap. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Strizzy Posted September 11, 2013 Share Posted September 11, 2013 I just got my new ACT sb10-hdr6 installed. It came with the monoloc. I'll be hitting the track this weekend, so I'll see how it holds up. My bad luck build Link to comment Share on other sites More sharing options...
Underdog Posted September 11, 2013 Share Posted September 11, 2013 Looks great for pull-type clutches. Haven't installed one yet, so I look forward to Strizzy's feedback. Doesn't help the craptastic 5MT push-type TOB problem though. Granted, the TSK3 kit and a return spring does a pretty good job. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Th3Franz Posted September 12, 2013 Share Posted September 12, 2013 I just got my new ACT sb10-hdr6 installed. It came with the monoloc. I'll be hitting the track this weekend, so I'll see how it holds up. ooh 6 puck. Run some drag slicks and cut sub 1.6 60' What axles are you running? stock? -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
GTTuner Posted September 12, 2013 Author Share Posted September 12, 2013 Yes please!!!!!! Outside diameter and overall length of the snout! Link to comment Share on other sites More sharing options...
Underdog Posted September 13, 2013 Share Posted September 13, 2013 5MT quill dimensions: Outside diameter = 1.30" Length = 1.84" For reference, TSK3 sleeve dimensions: Inside diameter = 1.296" - 1.298" Outside diameter = 1.37" Length = 1.86" The Crimson Dynamo Link to comment Share on other sites More sharing options...
SBT Posted May 8, 2014 Share Posted May 8, 2014 So Paul - any update on this? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
