Condor Posted April 28, 2014 Share Posted April 28, 2014 so noticed this today, after a slow (generally from a stop) turn to straight and normal acceleration im getting this weird knock from what sounds like the left rear wheel. goes away once over 20mph or so. originally i thought i had a nail in the tire or stone, but after taking the wheel off it wasnt that. thats pretty much as far as ive gotten (ran out of daylight....and lazy tonight:rolleyes:) just looking for things to check for when i jack it up tomorrow. thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted April 28, 2014 Share Posted April 28, 2014 sway bar end links. Then check the bushings for large cracks in the rubber ? Have you had any work done under there in the past few month's ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Condor Posted April 28, 2014 Author Share Posted April 28, 2014 only thing thats been done in the rear were wheel bearings. im headed out now to see if i can figure it out. Link to comment Share on other sites More sharing options...
Condor Posted April 28, 2014 Author Share Posted April 28, 2014 figured it out pretty quick. one of my mufflers rusted off a couple weeks ago and had a piece welded in to connect it. when they werent overly straight my OCD self used hose clamps to pull the one side over. it also lifted the mid Y pipe up and was just nicking the rear CV joint. not damage that i could see. took it for a quick drive and seems to be gone. Link to comment Share on other sites More sharing options...
