WetLegacy Posted November 15, 2016 Share Posted November 15, 2016 Hello all, i'm about to hit the 120,000 mile mark in my 09 2.5i se. When the car is at operating temperature I can smell a faint oil smell coming from the engine bay. I crawled under (not lowered) to inspect and saw a very small amount of oil on the oil pan. There is no oil in the coolant, and aside from the slight smell, there are no other symptoms. I figure its time to replace the head gasket seeing that everyone here has had to do it much earlier in their vehicle's life. Is there any suggestions you all have? Thank you! p.s. timing belt was replaced at 100,000, clutch assembly at 90,000, and radiator at 60,000 Link to comment Share on other sites More sharing options...
JJr Posted November 16, 2016 Share Posted November 16, 2016 Not sure about the 09 2.5i, but my 05 GT leaks a bit from the passenger valve cover, quite normal on the 05, hopefully someone with more knowledge will confirm, GL Link to comment Share on other sites More sharing options...
apexi Posted November 16, 2016 Share Posted November 16, 2016 I'd check your cv axle boots, and see if the passenger side boot flung any grease onto the heatshield directly below it. I wouldn't assume headgaskets, unless you see evidence of a leak where the head gaskets are. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted November 16, 2016 Share Posted November 16, 2016 Take it to a reputable shop and have them check it out. It wouldn't hurt to have them show you so you know for sure. It can be many different things, none of which any of us can tell you exactly where it's coming from especially without pictures. Link to comment Share on other sites More sharing options...
Acerguy Posted November 17, 2016 Share Posted November 17, 2016 X2 on checking the passenger side CV boot. Link to comment Share on other sites More sharing options...
ehsnils Posted November 17, 2016 Share Posted November 17, 2016 X2 on checking the passenger side CV boot. I agree, that or the valve cover seal. It's often the inner boot/joint that suffers because it's close to the exhaust and ages faster. Therefore it's always a good idea to check that joint if you have joint noise. Link to comment Share on other sites More sharing options...
subie bob Posted November 17, 2016 Share Posted November 17, 2016 My 05 gt leaks from the passenger side valve cover right on the exhaust i would check that and the cv joint on that side Link to comment Share on other sites More sharing options...
aac0036 Posted November 18, 2016 Share Posted November 18, 2016 Check around the valve covers which are the outermost seam away from the engine block, head gasket are further in. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
WetLegacy Posted December 11, 2016 Author Share Posted December 11, 2016 Well after closer inspection it was the valve cover gasket.. So after saving a bit of cash and parking the car for about three weeks, I took it in to get the gaskets replaced thinking it would be a $2,300 job from a certain certified Subaru dealer. I got a much better quote from a much closer Subaru dealership (fairway) which was for ALL gaskets replaced, and thermostat replacement. I walked out the door for $1,386. Thank you for everyones input. I will keep an eye on the CV Boot. Link to comment Share on other sites More sharing options...
JJr Posted December 11, 2016 Share Posted December 11, 2016 Damn, what gaskets did they replace for $1386, find a independent and stay away from the dealership if you can! Link to comment Share on other sites More sharing options...
apexi Posted December 11, 2016 Share Posted December 11, 2016 It's funny, I was actually going to say $1386 for both head gaskets is a pretty good deal. *I had just woke up and read wetlegacys post wrong. $1386 for both valve cover gaskets is pretty steep... 3 dealers in CT all quoted me around $540 for both sides.. Link to comment Share on other sites More sharing options...
honduhunter Posted December 11, 2016 Share Posted December 11, 2016 glad it wasnt the head gasket. what all did they replace? just both valve cover gaskets and thermostat? Link to comment Share on other sites More sharing options...
JJr Posted December 11, 2016 Share Posted December 11, 2016 My independent quoted me $200 for the passenger side, that was 2 years ago.I've been smelling the oil for 5 years. Strangely enough I'm never down between OCI's. Both inner axle boots were replaced last year, $450 Link to comment Share on other sites More sharing options...
WetLegacy Posted December 12, 2016 Author Share Posted December 12, 2016 http://i.imgur.com/0whVS8m.jpg Here is the receipt, they replaced ALL gaskets. Link to comment Share on other sites More sharing options...
apexi Posted December 12, 2016 Share Posted December 12, 2016 Looks like they did both head gaskets, both valve cover gaskets, and all 4 spark plug tube seals. I think you got a good deal, but maybe I'm wrong. Link to comment Share on other sites More sharing options...
pseank Posted December 12, 2016 Share Posted December 12, 2016 Smoking deal for both head gaskets Sent from my XT1254 using Tapatalk Link to comment Share on other sites More sharing options...
