serkan Posted April 25, 2013 Share Posted April 25, 2013 I saw a grounding point on the passenger side bottom of the frame and the strap was ripped from rotting. I cannot see where the other end was connected since it doesn't exist anymore. Is that a ground strap going from exhaust manifold to car frame ? If so is it on both sides or only passenger side. Thanks Link to comment Share on other sites More sharing options...
BoozeRS05 Posted April 25, 2013 Share Posted April 25, 2013 Ground straps are on both sides, and they connect from frame to exhaust manifold. Both of mine have rotted through. On one side I electrical taped the ends together for now, and on the other side I just clamped the loose end between the heat shields on the manifold. I'll replace both soon. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
chato Posted April 25, 2013 Share Posted April 25, 2013 Attaches to the manifold heat shield, don't believe there is one in the same location on driver's side IIRC Link to comment Share on other sites More sharing options...
serkan Posted April 25, 2013 Author Share Posted April 25, 2013 Ok thanks a lot. I will take care of them next time I go under the car. Link to comment Share on other sites More sharing options...
Burock Posted April 25, 2013 Share Posted April 25, 2013 Mine rotted through as well on the passenger side. 7 years of New England winters was a pretty good run though. How anyone expected a bare copper mesh wire not to fall apart in Snow country is beyond me.. Link to comment Share on other sites More sharing options...
Nolmers06LGT Posted April 25, 2013 Share Posted April 25, 2013 If I'm not mistaken, I thought they went from the body to the bottom of the heads, both driver and passenger side? Mine are toast- I've got new straps sitting on the shelf waiting to go in. Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted April 25, 2013 Share Posted April 25, 2013 I think some are on head and some are on exhaust manifold. I think pass side is to manifold and drivers is to head Link to comment Share on other sites More sharing options...
Nolmers06LGT Posted April 25, 2013 Share Posted April 25, 2013 I think some are on head and some are on exhaust manifold. I think pass side is to manifold and drivers is to head That makes sense.. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted April 25, 2013 Moderators Share Posted April 25, 2013 My ground straps are in great shape, I don't know why you guys are having such problems... "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Nolmers06LGT Posted April 25, 2013 Share Posted April 25, 2013 My ground straps are in great shape, I don't know why you guys are having such problems... I have a wealth of problems... The ground straps are minuscule compared to the other issues I'm having. BMB, too bad you don't live closer- I'd like to take that SMFW off your hands. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted April 25, 2013 Moderators Share Posted April 25, 2013 I have a wealth of problems... The ground straps are minuscule compared to the other issues I'm having. BMB, too bad you don't live closer- I'd like to take that SMFW off your hands. I'd like you to take it off my hands too! It's just too heavy to ship "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Nolmers06LGT Posted April 25, 2013 Share Posted April 25, 2013 I'd like you to take it off my hands too! It's just too heavy to ship Understood. Honestly, I don't want to have to pull my FW, I just want to eliminate possible reasons why my TOB would go.. again. Sorry to threadjack- It's all I can think about right now. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 25, 2013 Share Posted April 25, 2013 I think they go to the heads, I remember cleaning mine and putting them on when the short block was installed. I think there is only one on the drivers side front bottom of the head. Not sure I have pictures, I'll check. Found these but none of the bottom one (s). http://i185.photobucket.com/albums/x40/92Si/DSCN4705_zps2a4d6923.jpg http://i185.photobucket.com/albums/x40/92Si/DSCN4706_zps6f11e68a.jpg 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JmP6889928 Posted April 25, 2013 Share Posted April 25, 2013 Make your own out of a piece of Monster Cable speaker wire. Find the largest gauge you can-12 if possible and just put ends on it and heat shrink them to the connectors. If you can't find 12 gauge, make a double out of 14. It's nothing but a flexible connection. I've made my own on cars for years that way and they never go bad because of the shield and heat shrink. Link to comment Share on other sites More sharing options...
Nolmers06LGT Posted April 25, 2013 Share Posted April 25, 2013 Or you could splurge and spend the $3 it costs at a parts store.. Link to comment Share on other sites More sharing options...
JmP6889928 Posted April 26, 2013 Share Posted April 26, 2013 Or you could splurge and spend the $3 it costs at a parts store.. And have it corrode like the OE one. Link to comment Share on other sites More sharing options...
Charged Posted April 26, 2013 Share Posted April 26, 2013 Anyone have a part number handy? I noticed my pass side one has rotted off as well. Link to comment Share on other sites More sharing options...
QToo Posted April 30, 2013 Share Posted April 30, 2013 Is this an issue if one or both of the ground straps are torn? I just cut and reconnected the driver side but the other is completely gone. Will this lead to electrical interference or engine codes? Link to comment Share on other sites More sharing options...
Nolmers06LGT Posted April 30, 2013 Share Posted April 30, 2013 Is this an issue if one or both of the ground straps are torn? I just cut and reconnected the driver side but the other is completely gone. Will this lead to electrical interference or engine codes? I've been told that it takes a lot of ground issues before you'll notice any electrical problems. I'd suggest taking care of it eventually, but it won't be a problem unless you have multiple other grounding issues. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 30, 2013 Share Posted April 30, 2013 Anyone have a part number handy? I noticed my pass side one has rotted off as well. Make your own out of a piece of Monster Cable speaker wire. Find the largest gauge you can-12 if possible and just put ends on it and heat shrink them to the connectors. If you can't find 12 gauge, make a double out of 14. It's nothing but a flexible connection. I've made my own on cars for years that way and they never go bad because of the shield and heat shrink. Do that ^ any good piece of wire with a crimp on end will work. In the bottom right side of this picture, above the inlet tube, you can see the black ground cable I made for the race car attached to the frame. http://i185.photobucket.com/albums/x40/92Si/DSCF0259.jpg Here's a better picture. http://i185.photobucket.com/albums/x40/92Si/DSCF0756.jpg 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted June 2, 2013 Share Posted June 2, 2013 Here are the wires I made the other day, http://i185.photobucket.com/albums/x40/92Si/DSCN5218_zps47b42c1c.jpg http://i185.photobucket.com/albums/x40/92Si/DSCN5215_zps4651c6e9.jpg 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JmP6889928 Posted June 4, 2013 Share Posted June 4, 2013 Is this an issue if one or both of the ground straps are torn? I just cut and reconnected the driver side but the other is completely gone. Will this lead to electrical interference or engine codes? You can develop noise in your radio from the straps being broken. Link to comment Share on other sites More sharing options...
zactek Posted October 7, 2013 Share Posted October 7, 2013 Does anyone know if the bolts that hold the straps on are M6 or M8? Thanks, Zack K. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 7, 2013 Share Posted October 7, 2013 6mm for the two on the bottom of the heads. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GTTuner Posted October 7, 2013 Share Posted October 7, 2013 Is this an issue if one or both of the ground straps are torn? I just cut and reconnected the driver side but the other is completely gone. Will this lead to electrical interference or engine codes? Possible electrolysis in the cooling system as well as RFI interference. Link to comment Share on other sites More sharing options...
