glenmoormax Posted October 6, 2010 Share Posted October 6, 2010 MY 2008 5eat has a part throttle chatter. This has just started since I changed the ATF to amsoil and changed the filters. I have read both sides that amsoil has worked great for some, others say only subaru fluids. Has anyone else experienced this? I have searched everywhere and just want some better clarification. Clearly something is not right... Link to comment Share on other sites More sharing options...
TurboCool Posted November 28, 2013 Share Posted November 28, 2013 Can you describe the chatter a little more. I have an 05' 5EAT, and sometimes but not always, I get a chatter at around 2000 to 2500 RPMs under light load or throttle. Sounds like something is loose and rattling. But I can't tell if it's in the transmission, the engine, or what. The engine was replaced last year, and the driver side CV axle at the same time. Just replaced the passenger side axle a few weeks ago. I first noticed the chatter around the same time. The passenger side axle was a new FEQ brand and was causing vibration at stops. Had that swapped for a remanufactured one. Vibration is gone, but the chatter remains. So not sure if the chatter is associated with the tranny, engine, or that axle. Link to comment Share on other sites More sharing options...
