JoshNZL Posted May 20, 2016 Share Posted May 20, 2016 Hi guys, Is this a normal sounding start for a 2.0L auto legacy? Been sluggish like this ever since I bought it - I figured it was just how they are but a few things lately have me a bit worried about it. I don't think the battery is soft I had a good 15 second swing on it with the fuel pump disconnected, holds over 9.5V and doesn't seem to deteriorate. Though not ruled out, will see how it goes jumped with a good battery when I can. Engine is an EJ20 https://youtu.be/Pw3Og0HcD10 Link to comment Share on other sites More sharing options...
PearlBlueGT Posted May 20, 2016 Share Posted May 20, 2016 I noticed our 05 LGT has sluggish start, almost like its lacking battery power at the start. I even bought brand new battery with highest cranking amps, it still does the same. I posted on here a while ago and supposedly subarus are normal to crank like that. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 20, 2016 Share Posted May 20, 2016 After owning Legacy GT's since 1998, I don't recall ever thinking they are slow cranking. I can't watch your video here at work. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DonnyJagaru Posted May 20, 2016 Share Posted May 20, 2016 My first guess is corroded high-current lead or connections myself. A battery will fully charge with barely passable wires, but a starter will slow down if things aren't 100%. In my experience if the battery posts or big cables look iffy, they are! Link to comment Share on other sites More sharing options...
Max Capacity Posted May 20, 2016 Share Posted May 20, 2016 Yep clean the terminals. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
