OCDetails Posted July 7, 2011 Share Posted July 7, 2011 I am sensitive to the challenges of maintaining your vehicle when you don’t have a garage. I bought a garage with a house attached to it back in 2004 and for a couple years before that I had one that you could barely open the car doors in, but before that I was a proud Apartment Dweller trying to keep my car looking good under the carport. So the purpose of this article is to document some of my methods for keeping things looking good even without the advantage of having a hose nearby and a spacious garage to work in. Keep in mind that everybody’s situation will be different. Some of you get to park right in front of your building and others have to park in BFE. Some will have access to water and others won’t. Take these suggestions for what they are worth and feel free to ask me any questions if you think I can help. This article isn't meant to pimp any products or anything like that. It is meant to help you with some ideas on the process of maintaining your car. I've made a couple specific product recommendations just because they worked really well for me and are available off the shelf, but I want you to use whatever works best for you. Find what you like and then use it often. Washing: This is something most Appartment Dwellers can’t do easily. Many apartment communities don’t allow you to wash your car in the carport. The last one I lived in wouldn’t even let you pop your hood for more time than it took to refill your wiper fluid. I got reported for changing a flat tire in my carport once, so I know all about intolerant apartment management. However, with that being said, it is possible to wash your car in some complexes. Check with the apartment manager before you try though. The biggest trick to washing in the complex is access to the water. Sometimes they have a shed somewhere on the property where they keep the landscaping equipment and it may have a faucet nearby. Check around the buildings near the parking lot for something within hose reach to your car as well. It is different everywhere, but if you ask the apartment manager about washing, they can usually direct you to the right spot. Just remember to get it rinsed off and dried before the sun creates waterspots. That is where the California Waterblade will come in handy. If you can’t wash in your complex then that leaves you with two options. Either find a friend/relative with a driveway (in which case you can pretty much stop reading now since you won’t be operating as an AD if you have a garage you can use) or you can go to a coin op car wash. The only problem with coin op car washes is that the high pressure doesn’t always get the paint clean. Bring a wash mitt with you and give the car a wipe down before you risne it if you are concerned about it not getting the waterspots off or other grime. Just be careful with that want. The water that shoots out of there can peel the skin off your hand and is very painful. You could always use the brush in the car wash, but I wouldn’t recommend it. Using a brush in a coin op car wash is like using a hooker. Do you really want to be the next guy to use that? You don’t really know where it has been. The last thing that brush scrubbed could have been an oily tanker or some 4x4 that just game back from the desert and was covered in greasy clay and dirt. Even if you spray the brush off with the wand first there could still be oils and grit stuck to the bristles from perhaps YEARS of people not spraying it off first. Using a brush is a sure fire way to add some swirls and scratches to your paint. In the winter there really aren’t a whole lot of options and I just chalk it up to the repair I’m going to have to do in the spring anyway, but in the summer I avoid the brushes like the plague. Don’t bother with the wax or other products that the coin op will provide you. Just stick with a wash and rinse. Use your own products for wheel/tire cleaning and bug/tar removal. Oh, and be cautious of degreasing your engine at these places too. Most of them won’t allow you to do it. The waste water has to be tested before disposal and if it has too much grease and oil in it then they have to pay more for hazardous waste disposal. Degreasing your engine is a good way to add more of the stuff which will cost them more money, so they generally won’t allow you to do it. Using high pressure water like that isn’t my favorite thing to subject my engine to anyway. Maybe just around the perimeter where there aren’t any electrical connections, but definitely avoid any wires with that thing. You could really do some damage if the pressure is high enough. Something you might want to look into is doing a bucket wash AT the coin op place. If you can find one with a dead stall (usually spotted because they move the trash cans in front of the entrances) then you could pull in and just fill your bucket at the sink and wash away in the comfort of a shaded stall. Then just pull into the next one to rinse it off and you are good to go. You could even go back to the first one to do the waxing and everything. If there is someone to get permission from on this then try to do that first, but otherwise I really don’t see how it hurts anybody. I actually had a deal with a coin op place near one of my jobs back when I first started detailing. They knew I was bringing several cars a week over there to wash and detail, so they would let me use a permanently dead stall on the end whenever I wanted. It’s just always nice to ask permission before squatting at someone’s business. Polish/Waxing: This is the part you may find difficult. They don’t typically put easily accessible outlets at coin op car washes, and you may not find them at your complex either, so running your polisher could prove to be a challenge. However, I’ll be honest… I didn’t even own a PC until I moved into my first garage, so I can promise you that you can still maintain your vehicle just fine without one. You just have to learn to live with swirls or get really good at not getting them in the first place. There really isn’t a product which removes swirls by hand that I’ve found. There is only one person I’ve ever seen get swirls out by hand and he looks like a power lifter with massive shoulders, so that is what I reckon it takes to do the job. I don’t even try because I know I’d never be able to do it on the whole car. I’m getting off track… Anyway, if you can get an extension cord long enough to reach your car port, then it is possible you can polish there. Polishers make a lot of noise and I’d wager anything that you’ll get shut down pretty quick if you do it in your complex. You may be able to pull it off at the coin op, but plugs are hard to find at those places. Waxing is another story. You can easily wax your car in your carport or in the empty bay at the coin op. It is quiet and only requires some shade to do well. No problems there. Getting out of the sun is the big part. It isn’t that the sun itself is bad for wax, but rather it heats up the surface too much and the wax won’t dry or bond. If the paint is too hot to touch, then it is definitely too hot to wax. It is just going to smear around and you won’t get a good durable coat. Always try and wax in the shade or on a cool (relative) surface. Interior: Coin op vacuums SUCK! And I don’t mean that in a good way. They are very often poorly maintained and clogged, so you don’t get the suction you need. The heads can crack which causes them to leak suction and make them much less effective. So it is hit and miss with those. However, when you find one that works you will be happy. The ones that work do the job very well. I had one near my apartment that could suck the lines off the road. I actually used a cereal box and duct tape to fashion an adapter which allowed me to use the attachments of a shop vac. I bought a detailing kit for a Craftsman shop vac at Sears and it worked out great. In fact, because the coin op vacs have so much suction, it made the modification ridiculously effective because it was now coming out a smaller hose. It was awesome. Everything else on the interior is pretty easy to do. You can wash your floor mats in the complex Laundromat if you aren’t able to use an extractor on them. Just don’t dry them and you’ll be fine. Hang them on your balcony railing (if you have one) to drip dry and that should do it. Everything else can be done just as you would anywhere else. Final Detailing: The final detail is pretty easy to do in an apartment complex too. Just be careful that you aren’t spraying stuff all over everybody else’s car in the process. Also be aware that having your hood popped open and you leaning inside makes it look like you are doing maintenance on your vehicle which could be a violation of the tenant agreement. Nosy neighbors could just report you without knowing what you are really doing, so I would do all of your engine detailing at the coin op place. Apartment Dweller Kit: These are the products I would say you should keep in a box in your trunk for your detailing needs: Microfiber towelsDrying towel & California Water BladeWax applicators/ Leather conditioner applicatorsQuick DetailerInterior DetailerWheel/Tire Cleaner & Tire Shine with applicatorEngine degreaser & CD2 Engine DetailerMeguiar’s Ultimate Car Wax (really some of the best stuff off the shelf right now)Invisible GlassAerospace 303 protectantTuff Stuff (gets the really tough spills and stuff of your center console or carpet) with carpet brush With those products you should be able to handle anything outside of the actual washing and vacuuming of the vehicle. You should be able to get all of that to fit in a box or rubber maid tub in your trunk for easy transport. However, if you are in a really hot climate, I would probably recommend you NOT keep this stuff in your trunk. I had to clean a trunk that had car care products explode in it once due to the heat, so I would just be careful. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
sgt Posted July 10, 2011 Share Posted July 10, 2011 Great tips as always! Right now I live in an apt where I can't do any washing and all of the local coin ops are ADAMANT about no bucket washing =( At least I have a garage with an outlet so I can use my PC. I usually wash the car before and after using clay, but do you think I can get away with just washing before and wipe down after clay then wax? Link to comment Share on other sites More sharing options...
Magic Marker Posted July 11, 2011 Share Posted July 11, 2011 Great advice. I live in a townhouse with no garage. So I have to wash/ wax my car in the AM or after work. 2011 Volvo S60T6 & 2013 Volvo XC60T6 Polestar Link to comment Share on other sites More sharing options...
OCDetails Posted July 11, 2011 Author Share Posted July 11, 2011 Great tips as always! Right now I live in an apt where I can't do any washing and all of the local coin ops are ADAMANT about no bucket washing =( At least I have a garage with an outlet so I can use my PC. I usually wash the car before and after using clay, but do you think I can get away with just washing before and wipe down after clay then wax? It depends on the type of clay lube you use. If you are using real clay lube, then that shouldn't be a problem. If you are using soapy water, then I really would suggest you wash it again before waxing unless you are using something with cleaners and possibly light abrasives like NXT or something. Soap clay lubes leave a nice soap film on the car that doesn't always wipe off when you wax, so you get left with streaks under your wax that take a long time to wear off. It compromises the durability of the product as well, so it is always a good idea to make sure the surface is totally clean before you wax/seal. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
sgt Posted July 11, 2011 Share Posted July 11, 2011 Is quick detailer an acceptable clay lube or is there something that works better? Link to comment Share on other sites More sharing options...
OCDetails Posted July 11, 2011 Author Share Posted July 11, 2011 That actually works really well. Kinda spendy for clay lube since soapy water works just as well, but if you can't wash after you clay, then QD is a good choice. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
sgt Posted July 11, 2011 Share Posted July 11, 2011 Was just curious as that is what is typically supplied with clay bar kits (macguires, mothers, etc) Thanks! Link to comment Share on other sites More sharing options...
OCDetails Posted July 11, 2011 Author Share Posted July 11, 2011 The problem I've had with that is I can usually get one car detailed with the amount of lube which is supplied with the Clay Magic kit. However, they give me enough clay to do several cars and no real outlet for a refill of the lube. This lead me to believe that it wasn't really that important to use their particular formula. You just need something slicker than water, so most QDs will work. Just use one that doesn't have wax in it or anything like that. The burgundy bottle of Meguiar's QD is actually perfect. And you can buy it in huge bottles, so it will last for all of your normal QD needs too. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
Magic Marker Posted July 11, 2011 Share Posted July 11, 2011 That actually works really well. Kinda spendy for clay lube since soapy water works just as well, but if you can't wash after you clay, then QD is a good choice. I use soapy water for claying, but then rinse off the car again to ensure there isn't any residue. Using QD for claying gets expensive IMO. 2011 Volvo S60T6 & 2013 Volvo XC60T6 Polestar Link to comment Share on other sites More sharing options...
sgt Posted July 11, 2011 Share Posted July 11, 2011 True, but water is about as expensive around here :\ Link to comment Share on other sites More sharing options...
soloz2 Posted July 11, 2011 Share Posted July 11, 2011 I usually just buy the Mothers clay kits. 2 clay bars and a bottle of QD for under $20. I'm moving at the end of the month and the worst part of the new place is no outside water spicket and a gravel parking area... No maintenance for me. However, one of my co-workers lives next door and I made a deal to buy them a new hose so I can wash my car. :-) Current: 16 Crosstrek Premium w/ Eyesight & 05 Outback XT 5MT Past Subies: 14 FXT Premium, 14 WRX hatch, 06 Legacy 2.5i SE 5MT, 98 Outback wagon Link to comment Share on other sites More sharing options...
Magic Marker Posted July 11, 2011 Share Posted July 11, 2011 I usually just buy the Mothers clay kits. 2 clay bars and a bottle of QD for under $20. I'm moving at the end of the month and the worst part of the new place is no outside water spicket and a gravel parking area... No maintenance for me. However, one of my co-workers lives next door and I made a deal to buy them a new hose so I can wash my car. :-) Not a bad deal on purchasing a hose in order to use their water. 2011 Volvo S60T6 & 2013 Volvo XC60T6 Polestar Link to comment Share on other sites More sharing options...
mwiener2 Posted July 11, 2011 Share Posted July 11, 2011 http://www.griotsgarage.com/product/garage+sale/spray-on+car+wash+starter+kit+special.do?search=basic&keyword=waterless&sortby=newArrivals&page=1 if nothing else, you get some really really nice towels My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
MatsuDano Posted July 11, 2011 Share Posted July 11, 2011 OCDetails post without pics makes me sad But thanks for the excellent write up, as always! I'm sure i could find a way to use it as I'm neither in an apartment or a house. Link to comment Share on other sites More sharing options...
Magic Marker Posted July 11, 2011 Share Posted July 11, 2011 http://www.griotsgarage.com/product/garage+sale/spray-on+car+wash+starter+kit+special.do?search=basic&keyword=waterless&sortby=newArrivals&page=1 if nothing else, you get some really really nice towels Just ordered....Never bought from them before so hoping for a good experience. 2011 Volvo S60T6 & 2013 Volvo XC60T6 Polestar Link to comment Share on other sites More sharing options...
mwiener2 Posted July 11, 2011 Share Posted July 11, 2011 I like all the Griot's Garage stuff. I'm having some issues with their foam pads, but it may be related to living in the mountains more than anything. They're products all work as advertised and I started using their stuff professionally too. I have 5 gallons of their Quick Detailer I have to disagree with OCDetails about engine cleaning at car washes. It may be a regional thing, but most of the coin-op washes around here have Engine Cleaner as an option on the soap dial. Usually the cleaner doesn't work well and the high pressure spray is not the best for the engine, but engine cleaning is allowed. If I have a really gunky engine bay, I'll take the car to the car wash and use some of my own cleaner, but use their rinse. That way I don't get the area around MY shop all nasty. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
OCDetails Posted July 12, 2011 Author Share Posted July 12, 2011 In some states it is not allowed to do any engine cleaning in the wash bays. Florida, for example, is one of them. California is another. Utah is one that I've seen the signs in various locations, but I'm not sure of the law. It is because the water has to go through the same treatment as the gutter water and if it is too toxic then it has to be treated differently. This is also why it is technically illegal in many areas to wash your car at all if the soap is going to run into the city sewer. Even pros have to reclaim their water and process it before disposing of it. Damn EPA... I'd love to see them enforce it though. In most cases it is just the federal law which would cause an issue, but many states and cities have local statues and ordinances which would preclude you from washing your car in the driveway at all unless the water is channeled into the lawn. (because somehow contaminated water draining into the lawn and straight to the water supply is safer than contaminated water going into the sewer which will be processed and treated before anyone sees it again) _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
kateviliams Posted July 23, 2011 Share Posted July 23, 2011 these are very nice tips. thanks for this sharing. Link to comment Share on other sites More sharing options...
bakabakablah Posted July 23, 2011 Share Posted July 23, 2011 Kind of surprised you didn't mention anything about using Optimum No Rinse... I love that stuff. Link to comment Share on other sites More sharing options...
OCDetails Posted July 24, 2011 Author Share Posted July 24, 2011 I was trying to stick to 'off the shelf' type products. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
ThatVAguy Posted July 24, 2011 Share Posted July 24, 2011 OCD thoughts on the touch free washes for keeping an obp shiney but using a house/driveway for serious washes? Link to comment Share on other sites More sharing options...
OCDetails Posted July 24, 2011 Author Share Posted July 24, 2011 I don't have a problem with the coin op car washes during the summer. The problem is that they don't really do a great job of scrubbing the paint like a wash mitt does, so if you have water spots or something like that on the car then it will likely be in the 'serious washes' category. But for when it has been a couple weeks and it is just in need of a wash, the coin op places work fine. I'm sure you could just use a waterless wash or quick detailer when the car is just really dusty, but the more contact you have with the paint means the more chances you have at creating swirls. I'd rather not wipe the car down with a towel that just gets dirtier and dirtier as you go, so QD is only used for getting bird shit and things like that off the paint. Everything else goes through a wash. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
ThatVAguy Posted August 1, 2011 Share Posted August 1, 2011 i hand wash about every 2-3 weeks but ill hit the touch free rinse for $5 every week Link to comment Share on other sites More sharing options...
mkeGT Posted September 8, 2011 Share Posted September 8, 2011 It is extremely dusty in my under ground garage. Any tips on just keeping the dust off the car? No electric outlets, no water. Safe to just use a microfiber cloth? Not looking for full on wash/wax in the garage, just to keep the dust from attaching like a magnet :/ Link to comment Share on other sites More sharing options...
OCDetails Posted September 9, 2011 Author Share Posted September 9, 2011 Klasse is somewhat of an antistatic. Most sealants are better at not attracting dust after they cure. While they cure there is a chemical reaction taking place and it gets a little charged, but after that they are much better. Waxes are oily and attract dust like crazy. So that might be one suggestion. Other than that, I really don't know how to keep dust off a car short of covering it. To get the dust off you can use a microfiber and some quick detailer. That is a fairly safe way to go. Just remember that anytime you make contact with your paint with anything you are increasing the chances of creating swirls. Definitely keep a good couple coats of sealant on there so that the swirls are just in the sealant and just melt away. Microswirls aren't anything to worry about when they are just in the wax or sealant, but any deeper than that and you are going to be irritated and have to polish it every other day. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
