systdow666 Posted September 25, 2012 Share Posted September 25, 2012 hate for my first post to be a trouble shoot but im at a loss car is a 2000 legacy gt prior to my owning it passenger side hit.upon my taking ownership it had a grind in 3rd and 5th was harder to shift into after rebuild (new linkage) and 5th originally was hard to shift into has seemed to loosen up but reverse is next to impossible almost like reverse over to far to the right also after getting it into reverse it becomes hard to shift out and occassionally locks out other gears any ideas or similiar experiences thanks in advance Link to comment Share on other sites More sharing options...
whitetiger Posted September 25, 2012 Share Posted September 25, 2012 make sure the clutch is disengaging properly. bleed the system and check for proper movement. Link to comment Share on other sites More sharing options...
systdow666 Posted September 25, 2012 Author Share Posted September 25, 2012 was bled prior to use after install all other gears appear to smoothly shift so not thinking clutch as an issue trans rebuilder claimed reverses collar meshed kinda tight and noted there was no stop on the shaft for it so thought it maybe normal operation anyone with experience internally with these transmissions ? Link to comment Share on other sites More sharing options...
GTTuner Posted September 25, 2012 Share Posted September 25, 2012 A bent shift shaft is a possibility. Is the condition present with the engine not running? Link to comment Share on other sites More sharing options...
systdow666 Posted September 25, 2012 Author Share Posted September 25, 2012 condition is present running and not running .... can trans mounts play a role here ? Link to comment Share on other sites More sharing options...
systdow666 Posted September 26, 2012 Author Share Posted September 26, 2012 ok so here it is the 5th hub assembly apparently is binding to the point at engagement it actually sticks which is why it becomes a popping shift to break the bind or force it in this is from our rebuilder not me to my eye it looks normal but to touch its sticky as hell will post pic of part later Link to comment Share on other sites More sharing options...
Max Capacity Posted September 26, 2012 Share Posted September 26, 2012 If the rebuilder is good he'll be able to fix it and get you back on your way. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
systdow666 Posted September 27, 2012 Author Share Posted September 27, 2012 forgot to post this the 5th hub assembly is cracked this was overlooked by the rebuilder.... obviously this would create a bind lol will post pic of part as soon as i can get it off my phone Link to comment Share on other sites More sharing options...
