Andyjo Posted November 17, 2013 Share Posted November 17, 2013 On some 05+ 5MT vehicles the cruise control will randomly turn off, usually after ~30 minutes or so. You can see why here: http://legacygt.com/forums/showthread.php/root-cause-cruise-control-failure-30814.html This is how you can fix it: 1) Jack up the car, throw a stand under it (it's always a pain when you drop a car on yourself, so the stand is a good thing) 2) Find the sensor, it's the one furthest to the back: http://i1148.photobucket.com/albums/o568/Andyjo07/NPS_Location_zpsc23f0d03.jpg http://i1148.photobucket.com/albums/o568/Andyjo07/2174_zps07e08020.jpg 3) Unplug the connector, it's red in my car: http://i1148.photobucket.com/albums/o568/Andyjo07/2180_zpse2d5ec50.jpg 4) Remove sensor, it's somewhere in the 19-21mm range, i just used an adjustable wrench, you can get to it from 'above'ish the transmission mount, because if you try to get to it from below you run into the transmission housing w/ the wrench. 5) Make washer thinner, file it, turn it on a lathe, sand it (it would take forever), buy a new one that's thinner... http://i1148.photobucket.com/albums/o568/Andyjo07/2176_zps4308e5b5.jpg http://i1148.photobucket.com/albums/o568/Andyjo07/2177_zpsa5d0e3bf.jpg I actually found the file worked the best, couldn't get a good grip on it in the lathe... 6) Install back in car http://i1148.photobucket.com/albums/o568/Andyjo07/2179_zpscb181bdf.jpg I looked on mcmaster, didn't see anything the correct size.. http://www.mcmaster.com/#standard-crush-washers/=pf3tav http://i1148.photobucket.com/albums/o568/Andyjo07/crush_washers_zpsddd83d1a.jpg It looks like the 16mm one MIGHT work.. but you'd need to buy 10 of them to find out The washer i took out, prior to 'modification' had the following specs: 14mm ID 21mm OD 2mm Thickness I filed it down to 1.285mm (~0.0505") Link to comment Share on other sites More sharing options...
