Navigation - DIY using in dash cubby slot and $10 in parts!
This is my first DIY so bear with me! ;) This worked perfectly with the Garmin Nuvi 255w, the ball socket clip, a random chunk of plastic, and a couple small screws!
First off props to Scooby Fan... this was his idea, I just changed it slightly and made it available for everybody. I collected info from a few souces and added my own ideas to make this work.
Also props to Jazzy Engineering for the great instruction manual on how to take apart the center console and dash.
You should get it if you want to make this install of your nav easier:
http://www.jazzyengineering.com/Installation_Manual_1-2.pdf
So first I pulled the cubby/vent unit out of the dash using a flathead with a cloth on it. It just pops right out if you carefully pry out the bottom. It only came out a few inches but that was enough for reaching behind it.
Then I used the flathead to pry the side hinges of the cubby door out of their respective sockets and pulled the door out of the cubby hole and removed the springs. Ok, door is off, and vents are out of the dash:
http://i150.photobucket.com/albums/s120/rytoe/LGT%20nav/P2200011.jpg
Next I followed Jazzy Engineerings instructions on how to take the center console out:
http://i150.photobucket.com/albums/s120/rytoe/LGT%20nav/P2200013.jpg
http://i150.photobucket.com/albums/s120/rytoe/LGT%20nav/P2200014.jpg
Next I cut a slot in the bottom of the armrest storage using my Dremel, so I could feed the 12v power cable for the Garmin through it. By you have guessed that I am utilizing the 12v plug in the armrest storage. I did this for easy unplugging:
http://i150.photobucket.com/albums/s120/rytoe/LGT%20nav/P2200016.jpg
Next I routed the cable under the center console and up the side of the head unit. It was a bit easier to pull the head unit out several inches so I could keep feeding the cable up the dash:
http://i150.photobucket.com/albums/s120/rytoe/LGT%20nav/P2200015.jpg
I ran the cable under the shifter trim and along the right side of the head unit and up into the cubby.
Using a 7/8" Drill bit I drilled a hold in the back of the cubby to bring the 12v wire in:
http://i150.photobucket.com/albums/s120/rytoe/LGT%20nav/P2200017.jpg
Here's what the inside of the armrest store looks like:
http://i150.photobucket.com/albums/s120/rytoe/LGT%20nav/P2200018.jpg
Now for the mounting plate. I bought a large cup holder made by Bell at Kragen Auto. It was black plastic and was nice and smooth. I mutiliated it and only used the large flat bottom part for my mounting plate:
http://i150.photobucket.com/albums/s120/rytoe/LGT%20nav/P2200028.jpg
I cut the flat plastic part to be VERY tighton the sides. I cut it 6 7/8" wide. If you do this your plate will litteraly snap in and be a rock solid pressure fit. Height was 3 1/8" (I think? :confused:)
I drilled a 1 1/8" hole in the lower center (make sure to test it to see where to drill your hole) and used a small through bolt and small screw to fasten the Garmin clip to the plastic plate and I drilled a hole to accomodate the power plug that goes into the Nuvi:
http://i150.photobucket.com/albums/s120/rytoe/LGT%20nav/P2200019.jpg
Back view:
http://i150.photobucket.com/albums/s120/rytoe/LGT%20nav/P2200020.jpg
Then I popped the Nuvi into the clip and plugged it in, and slid the plate into the opening. It snapped in and fit perfectly:
http://i150.photobucket.com/albums/s120/rytoe/LGT%20nav/P2200022.jpg
Here's the plate without the Nuvi:
http://i150.photobucket.com/albums/s120/rytoe/LGT%20nav/P2200021.jpg
And that's it! The Garmin Nuvi custom fitted into the dash! :cool:
If you leave the Garmin Nuvi always plugged in, it comes on when you turn the key to "on" and when you turn the car off the Nuvi senses that the power on the car is off and has an automatic shutdown with a timer of 30 seconds. So you dont have to worry about turning it off and on all the time!
Here's the finished product:
http://i150.photobucket.com/albums/s120/rytoe/LGT%20nav/P2200023.jpg
http://i150.photobucket.com/albums/s120/rytoe/LGT%20nav/P2200024.jpg
http://i150.photobucket.com/albums/s120/rytoe/LGT%20nav/P2200027.jpg
Complete with custom Subie startup screen I made in Photoshop!
Fin
Thanks! It took me like 6 hours!:eek: I was flying by the seat of my pants the whole time. It should really only take about 2 hours. I also have never taken the dash apart, or any dash for that matter...
No because it isnt completely inside the cubby. Its more recessed than anything. It aquires signal in seconds and functions exactly the same as when I used the suction mount on the winshield
great work, thanks for the idea, i got mine finished up and installed this afternoon!
No Prob. What did you use for your plastic plate? I was Going to use Plexiglass and paint it, but went with black colored plastic
What about the subaru nav? I heard the older ones werent that great... you should have some options with the 5gen
5th genners get a Metra dash installation kit so they can install any receiver they like! Lucky... :mad:
As far as this install.... I might actually try it, and that's blasphemy for me to say that. I usually hate navigation that uses a suction cup or clips onto your dash, but this looks quite clean.
I've been humming and hawing about this..
Can it fit further in so it looks lodged in? I imagine that it's going to be tight.. I have the same model Garmin as well, and I'd just leave it so it looks like it doesn't come out so the crazy thieves won't break my window...
It CAN go in further but there is no way the clip will fit in there too. the garmin by itself is a super tight fit vertically. You would have to figure out a way to fasten it inside the cubby. I'm not sure about satellite signal too if in inside the cubby.
I did the exact same thing you did almost. When I was at auto zone i picked up one of those cup holders for 6.99. Cut it apart and stuck it in. This goes for the person wanting to maybe have it set in more. the top part where the plastic opens for the door to slide up will hold the plate in place and if you trim the rounded edge of the plate on the bottom to have "L" bends in them inverse to the way the rubber stick mat in there fits. Also, I cut the width a little shorter than what was suggested and put some standard auto weather stripping on the sides to seal it off and get a better hold.
Nice job. What you did is very creative. I've been looking unsuccessfully for a suitable mount for my iphone. Something like this would be great.
I'm just wondering how you deal with thieves. In my neck of the woods, they break into cars even if they see the outline of a suction cup on the windshield. I think the empty clip on the door might cause them to do the same thing if they think the device is stowed somewhere inside the car. When I leave my car after charging my phone, I even hide the loose charger cord so it's not visible. Sounds paranoid, but I've heard too many break-in stories.
