oxymoron36 Posted May 28, 2011 Share Posted May 28, 2011 My 1997 legacy 2.5L engine is misfiring. I replaced the coil pack, plugs and wires, and an O2 sensor and it is still misfiring. Anyone else have an idea of what could be causing this? Thanks for your help! Link to comment Share on other sites More sharing options...
nmd003 Posted May 28, 2011 Share Posted May 28, 2011 Did your spark plug threads have oil on them? Bad spark plug tube seals will cause oil to leak from the valve cover onto them and cause misfire. Low compression can cause it too. Is it just one cylinder missing or multiple? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 29, 2011 I Donated Share Posted May 29, 2011 Is your check engine light on? What codes come up? A bad Mass Air Flow Sensor, a bad upstream o2 sensor (before cats), vacuum leaks, low compression or other head problems, fuel injectors, bad gas and many more things can cause a misfire. Diagnosing a misfire sucks sometimes -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Baddog Posted May 29, 2011 Share Posted May 29, 2011 What brand of plugs? Link to comment Share on other sites More sharing options...
bigdadi Posted May 29, 2011 Share Posted May 29, 2011 Clean the MAF with CRC MAF cleaner $8 to $10 and see if it helps... Autozone, Advanced Auto Parts carry it. http://ecx.images-amazon.com/images/I/41fX171WA3L._SS500_.jpg Link to comment Share on other sites More sharing options...
ampped88 Posted July 11, 2011 Share Posted July 11, 2011 i have this same situation cel is on and i get codes p0301,p0302 ,and most common p0304 Link to comment Share on other sites More sharing options...
subydrift Posted July 15, 2011 Share Posted July 15, 2011 I had a CEL for a misfire come on and the behavior of the car didn't change at all. It came on when I was cruising, 3 different occasions, but I never lost power or had a rough idle or anything. I narrowed it down to Maverik's gas. For 3 different trips I had the misfire CEL come on while cruising 65-70 and all 3 trips I filled up at Maverik before. Now I use Chevron and haven't seen the CEL since. I've also heard you should only use the Subaru factory spark plugs. I have some Bosch Platinums in mine but plan to change them out soon. Link to comment Share on other sites More sharing options...
