brett12018 Posted December 7, 2012 Share Posted December 7, 2012 I have a 2005 subaru legacy gt 5 speed with about 110k miles. When im in nutral or pulling iut in first if I give it a little gas and then let off the throtle my rpms drop theb rise back up. And one have the same problem? Any suggestions on how to fix it? Link to comment Share on other sites More sharing options...
ripemeat Posted December 7, 2012 Share Posted December 7, 2012 vacuum leak, dirty throttle body plate, i dunno Link to comment Share on other sites More sharing options...
brett12018 Posted December 7, 2012 Author Share Posted December 7, 2012 Had my vacume leaks fixed, it helped but did not completely get ride of the problem. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 7, 2012 Share Posted December 7, 2012 Try a can of seafoam in the gas tank or B12, that was talked about the other day, It may help clean the injectors. You can even suck some in through the small hose on the BOV. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
brett12018 Posted December 7, 2012 Author Share Posted December 7, 2012 Thanks! Im going ti try and clean my idle control valve. And seafoam my car Link to comment Share on other sites More sharing options...
ripemeat Posted December 7, 2012 Share Posted December 7, 2012 you don't have an idle (air) control valve. Link to comment Share on other sites More sharing options...
brett12018 Posted December 7, 2012 Author Share Posted December 7, 2012 I didnt think so but my friends was insisting I do Link to comment Share on other sites More sharing options...
ripemeat Posted December 7, 2012 Share Posted December 7, 2012 lol, your friends don't understand the setup of your engine I guess. Link to comment Share on other sites More sharing options...
brett12018 Posted December 7, 2012 Author Share Posted December 7, 2012 Well he had an older gen then mine I guess thats why haha Link to comment Share on other sites More sharing options...
20lgt06 Posted December 7, 2012 Share Posted December 7, 2012 Boost leak tester will determine if you have an easy fit. Link to comment Share on other sites More sharing options...
