car_guy1 Posted October 21, 2009 Share Posted October 21, 2009 anybody ever had their ream main seal go out? mine has started leaking oil at an alarming rate. I'm just curious to see what this should cost me to replace. Link to comment Share on other sites More sharing options...
meier motor sports Posted October 21, 2009 Share Posted October 21, 2009 big bucks. the seal is maybe 20bucks but the trans needs to be droped so thats the majority of the cost and its "rear main seal" Link to comment Share on other sites More sharing options...
Max713 Posted October 21, 2009 Share Posted October 21, 2009 Are you sure its the rear main seal? Its much more common for the rear baffle plate to leak on our cars, which sits very close to the rear main. I had the rear baffle plate seal go out on me, quite spendy to fix. Link to comment Share on other sites More sharing options...
shutterbc Posted October 22, 2009 Share Posted October 22, 2009 Judging from the responses, it sounds like "ream" may be the proper word after all. I had the baffle plate go on my Impreza before because in 1998 they used a plastic one and it warped (high revs at low speed == melting). Good luck with whatever it happens to be, but I hope you can get it looked at soon. Link to comment Share on other sites More sharing options...
