dark_thorns Posted November 21, 2012 Share Posted November 21, 2012 This may be a stupid question but is there some special way you're supposed to pull off the crankshaft sprocket? i looked in the service manual and it says to just pull it off but mine isn't budging. and there aren't any threaded holes to use a puller. is mine just stuck? it wouldn't surprise me considering i pulled the motor out of a junkyard car. Link to comment Share on other sites More sharing options...
johnegg Posted November 21, 2012 Share Posted November 21, 2012 it is supposed to just come off, but 15 - 20 years will change that a bit, sometimes. the first time i did it i ''tapped'' threads into the 2 holes on the pulley and then used a puller i borrowed from autozone. since then i have managed to get them off without going through all that. i usually , carefully tap on the center section of the pulley with a hammer to ''break'' the seal and it slides off. use some spray lube . careful not to damage the vanes on the outer edge of the pulley Link to comment Share on other sites More sharing options...
twisty Posted November 22, 2012 Share Posted November 22, 2012 I used a timing puller from auto zone that had thin hooks. I had to take the U shaped part off the center bolt of the puller for it to work tho Link to comment Share on other sites More sharing options...
