Zestymac Posted May 5, 2006 Share Posted May 5, 2006 Going to the beach for two weeks on Hatteras Island. Lots o beach driving on Hatteras and Ocracoke to get to good fishing / beaching spots......Looking at lightweight emergency tow straps...ie 20ft with loop ends and various break strengths...So what will work 6000 pounds...7000 lbs ???any rule of thumb by vehicle weight? Not expecting to use it, BUT, with a few hot dry days the sand gets treacherous outside the 'tracks'... Cheers, Rick Link to comment Share on other sites More sharing options...
Sponge Posted May 5, 2006 Share Posted May 5, 2006 Any 4 or 5 inch HD nylon strap will work...stay away from hooked ends its a good way to kill yourself or someone else when it breaks or slips. Just go to Walmart for what your needs would be. My vB Gallery Link to comment Share on other sites More sharing options...
Zestymac Posted May 5, 2006 Author Share Posted May 5, 2006 http://cgi.ebay.com/ebaymotors/20-X-2-Tow-Strap-Sling-Heavy-Duty-6-600-LB-CAP_W0QQcmdZViewItemQQcategoryZ40022QQitemZ4591230137QQrdZ1 This is what I'm looking at.... 2X20' loop ends. 6600lbs strength / poly Link to comment Share on other sites More sharing options...
subbiedoobie Posted May 6, 2006 Share Posted May 6, 2006 ....when you get back post some pics of the 'ru on those awesome beaches Link to comment Share on other sites More sharing options...
gargleblaster Posted May 7, 2006 Share Posted May 7, 2006 ....when you get back post some pics of those awesome beach babesFixored. Founder - The Harry F. Johnson Memorial Fund Link to comment Share on other sites More sharing options...
Sponge Posted May 7, 2006 Share Posted May 7, 2006 Make sure you figure out your tow points before you leave...it'll be easier to do that before your buried My vB Gallery Link to comment Share on other sites More sharing options...
Zestymac Posted May 7, 2006 Author Share Posted May 7, 2006 I'll use the hitch in the back the front is s ?? right now...Still liooking for the right capacity in Lbs strength? any one venture a guess. Will likely go with 11,000... That should be enough???? Thanks, Rick Will take photos... Link to comment Share on other sites More sharing options...
aldouse Posted May 7, 2006 Share Posted May 7, 2006 what you need tow straps for? looking to get stuck in the sand/mud? or planning on fishing for logs and rocks? -- yay for the sig! -- my garage! Link to comment Share on other sites More sharing options...
subbiedoobie Posted May 8, 2006 Share Posted May 8, 2006 Fixored. I figured he was going with his wife..... Link to comment Share on other sites More sharing options...
subbiedoobie Posted July 5, 2006 Share Posted July 5, 2006 I'll use the hitch in the back the front is s ?? right now...Still liooking for the right capacity in Lbs strength? any one venture a guess. Will likely go with 11,000... That should be enough???? Thanks, Rick Will take photos... Are there any good photos to share? Link to comment Share on other sites More sharing options...
LGTFan 88 Posted July 5, 2006 Share Posted July 5, 2006 +1 I'm interested in seeing pics as well. I've got an LGT, but we take the wife's Pathfinder on the sand. I'd love to dump the Pathfinder and get her an XT, but one of the beaches we hit on Martha's Vineyard has very deep sand, and wonder how well the Outback would do (no low range, etc..) The ground clearance seems more than adequate - I'm more concerned with having enough low end power. Also, they make everyone deflate their tires to 15psi, and wonder how that might impact the Subie's ability in the deep sand... Link to comment Share on other sites More sharing options...
Zestymac Posted July 5, 2006 Author Share Posted July 5, 2006 I have a few static pics I cant seem to post them, but I will send them to someones Email addy to post. I experimented with pressures starting at 20 and finally settled at 22 lbs. They seemed to work fine, even in the softest stuff. There is much less sidewall with a 55 aspect tire, so even 22 was not great on the pavement.... I was very conservative with where I went on the beach, but really had no troubles, I could feel the plastic undertray hitting once in a while.. Cheers, Rick Link to comment Share on other sites More sharing options...
Garandman Posted July 5, 2006 Share Posted July 5, 2006 I'll use the hitch in the back the front is s ?? right now...Still liooking for the right capacity in Lbs strength? any one venture a guess. Will likely go with 11,000... That should be enough???? Thanks, Rick Will take photos... In the Army our rule of thumb was 2X vehicle weight for towing, 3x vehicle weight for lifting. So 6,000-6,600 should be adequate. Who Dares Wins スバル Link to comment Share on other sites More sharing options...
NutBucket Posted July 6, 2006 Share Posted July 6, 2006 +1 I'm interested in seeing pics as well. I've got an LGT, but we take the wife's Pathfinder on the sand. I'd love to dump the Pathfinder and get her an XT, but one of the beaches we hit on Martha's Vineyard has very deep sand, and wonder how well the Outback would do (no low range, etc..) The ground clearance seems more than adequate - I'm more concerned with having enough low end power. Also, they make everyone deflate their tires to 15psi, and wonder how that might impact the Subie's ability in the deep sand... My gf has taken her uncle's '98 or so Forester onto the soft sand at Pismo, CA and it did well with about 10psi in the tires. I'd imagine the XT would be fine in the sand. Link to comment Share on other sites More sharing options...
SBT Posted July 6, 2006 Share Posted July 6, 2006 Snatching/towing minimum 2x towed vehicle weight. Make it long enough so you can double it for the front end (left and right side attachment) or, singled-up, the snatch vehicle can be far enough away not to kill your car with spun debris. I would think that TP @ 18-23 psi would be optimal. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
subbiedoobie Posted July 18, 2006 Share Posted July 18, 2006 I have a few static pics I cant seem to post them, but I will send them to someones Email addy to post. Cheers, Rick I'll try to post them. Ken Link to comment Share on other sites More sharing options...
harrydog Posted July 24, 2006 Share Posted July 24, 2006 I keep a nylon tow strap in my Outback as part of my "emergency" kit. It's rated at 17,000 lbs and wasn't much more expensive than the lesser ones. I'm pretty sure I got it at either Home Depot or Lowes. Link to comment Share on other sites More sharing options...
