thesavo Posted September 20, 2014 Share Posted September 20, 2014 2004 USDM Legacy L-s wagon. While trying to make life easier, I made it harder. I did this while working on the front tie rod. I sheared off the middle brake shield bolt. I was more careful/lucky with the top and bottom bolts. http://i1344.photobucket.com/albums/p659/thesavo/Legacy_G3-Ssuspension/IMG_20140920_120523_224_zpsb4z1ft7m.jpg Has anyone else had this issue? How should I do to go about fixing it? Drill/tap - for smaller bolt. Zip tie - probably not smart Leave it? The other two put up a fight but came out OK. I wonder if trying to recover the remains is even possible without a torch. Link to comment Share on other sites More sharing options...
orndog Posted September 20, 2014 Share Posted September 20, 2014 You can try an extractor, or drill it out. btw, do you park that thing in the ocean? Link to comment Share on other sites More sharing options...
thesavo Posted September 20, 2014 Author Share Posted September 20, 2014 Nope. The wonders of a decade-ian in new York/ new England. That's just what call surface rust. It's a bit like a "flesh wound" In Hollywood. I already broke a GRAB-IT off it. It's my own fault for trying to remove it after hassling with the tie rods. ;-) Link to comment Share on other sites More sharing options...
hobo2701 Posted September 21, 2014 Share Posted September 21, 2014 i rock with no dust shields but had to cut a spacer the same with as the shield as so the brakes still had the same geometry. Link to comment Share on other sites More sharing options...
thesavo Posted September 21, 2014 Author Share Posted September 21, 2014 i rock with no dust shields but had to cut a spacer the same with as the shield as so the brakes still had the same geometry. Spacer? How is that needed? Link to comment Share on other sites More sharing options...
Max Capacity Posted September 21, 2014 Share Posted September 21, 2014 I hope you put a cotter pin in that tie rod end ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
thesavo Posted September 21, 2014 Author Share Posted September 21, 2014 Thanks for the observation. That was taken before I replaced the tie rod ends. The new one had a nylon lock nut. Link to comment Share on other sites More sharing options...
