newbiesubi Posted May 8, 2014 Share Posted May 8, 2014 I'm not sure if anyone else has done this on here as I have not come across it in my travels. I retrofitted a projection housing into the high beam socket of my headlights. Due to state law where I live it is illegal to run HID's unless they are in a projection housing. The law extends further then that to go against it but it's difficult for them to prove whether or not the car came factory with HID's or not when there is a projection housing present. Anyhow, I attached a couple of pictures I took yesterday after installing them. They are not the best quality but you get the idea of it. The aftermarket projector has a shutter inside of it that can be powered if the projector was being used in a bixenon application. I added those shutters to my OEM projectors and wired my headlights up so when I am running low beam both the low and high beam are one as it would be if I had switched it to high beam under the factory set up. I wired the shutters to the high beam connection so when I flip the high beam the shutters come down in both housings causing a different cut off allowing more light. I can elaborate more if needed. Feel free to share your comments and opinions. Link to comment Share on other sites More sharing options...
12sechatch Posted May 9, 2014 Share Posted May 9, 2014 I wish that was a federal law Link to comment Share on other sites More sharing options...
newbiesubi Posted May 9, 2014 Author Share Posted May 9, 2014 12sechatch, I'm not sure if you are referring to not allowing the use of HID's in general unless factory or not allowing the use if not in a projection housing. If you are referring to the later or the two I agree with you completely. Some people will complain that they have a right to be able to see better at night but what they do not realize is putting those in a reflective based housing meant for an incandescent light bulb may increase their visibility but for oncoming traffic it does the complete opposite. Link to comment Share on other sites More sharing options...
Gex Posted May 9, 2014 Share Posted May 9, 2014 People have used the Lexus is300 housing if my memory serves right. Link to comment Share on other sites More sharing options...
newbiesubi Posted May 9, 2014 Author Share Posted May 9, 2014 Good to know for future reference Gex. I bought mine from the retrofitsource.com. Prices are fair and quality of great. Link to comment Share on other sites More sharing options...
MrTris Posted May 9, 2014 Share Posted May 9, 2014 People have used the Lexus is300 housing if my memory serves right. RX330 seems to be the one that I've read about here. I like the setup! Looks great, especially on another SWP! Link to comment Share on other sites More sharing options...
newbiesubi Posted May 9, 2014 Author Share Posted May 9, 2014 RX330 seems to be the one that I've read about here. I like the setup! Looks great, especially on another SWP! Thanks! Link to comment Share on other sites More sharing options...
PutnamCO Posted May 10, 2014 Share Posted May 10, 2014 Very interesting idea. I have an RX300 retrofit, and love them, but prefer bi-xenons. My low beams are great, but the highs aren't. Sounds like you've found a good solution. Link to comment Share on other sites More sharing options...
bluesuby Posted May 10, 2014 Share Posted May 10, 2014 I was thinking just the opposite. Low beams are terrible, no complaints about the highs. Link to comment Share on other sites More sharing options...
PutnamCO Posted May 11, 2014 Share Posted May 11, 2014 I was thinking just the opposite. Low beams are terrible, no complaints about the highs. Meant to say my low beams with the RX300 retrofit are excellent, but they make my brights seem weak. And yes, the stock low beams are unacceptably bad. Link to comment Share on other sites More sharing options...
wesleyCrowbar Posted March 9, 2016 Share Posted March 9, 2016 Bumping for interest. Any chance you can give some insight into how you mounted the new high beam? Link to comment Share on other sites More sharing options...
