bl6azn Posted November 16, 2012 Share Posted November 16, 2012 please help me. i have a check engine light (solid stay) with cruise light blinking. what can this mean. please help with proir exprience. Link to comment Share on other sites More sharing options...
SCASEYS Posted November 16, 2012 Share Posted November 16, 2012 OMG-CEL! Read the code, tell us the code I donated to LegacyGT.com which allows me to have this nifty signature. If anything SCASEYS posts ever becomes a sticky i'm gonna light this whole place on fire Link to comment Share on other sites More sharing options...
bl6azn Posted November 16, 2012 Author Share Posted November 16, 2012 sorry. i dont have a reader to read the code that is causeing the check engine light. is it normal to have a check engine light and a cruise light blink @ the same time ? Link to comment Share on other sites More sharing options...
Nrw Posted November 16, 2012 Share Posted November 16, 2012 yes. Get the code read, report back. Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted November 16, 2012 I Donated Too Share Posted November 16, 2012 negative ghost rider. mission abort! go to Autozone now and get it read Link to comment Share on other sites More sharing options...
BigBlack-V Posted November 16, 2012 Share Posted November 16, 2012 go to advanced auto parts or autozone and they will read the code for FREE then come back and post said code I was 0. And I'm still a zero. Link to comment Share on other sites More sharing options...
MrTris Posted November 16, 2012 Share Posted November 16, 2012 No, goto O'Reilly's. /devilsadvocate Link to comment Share on other sites More sharing options...
DocHolladay23 Posted November 16, 2012 Share Posted November 16, 2012 Here are the things that may have caused that, I suggest you go through every one of them. P0031 - Front oxygen (A/F) sensor heater circuit low inputP0032 - Front oxygen (A/F) sensor heater circuit high inputP0037 - Rear oxygen sensor heater circuit malfunctionP0038 - Rear oxygen sensor heater circuit high inputP0065 - Air assist injector solenoid valve malfunctionP0066 - Air assist injector solenoid valve circuit low inputP0067 - Air assist injector solenoid valve circuit high inputP0100 - Mass Air Flow Sensor Circuit MalfunctionP0101 - Mass Air Flow Sensor Circuit Range ProblemP0102 - Mass Air Flow Sensor Circuit Low InputPO103 - Mass Air Flow Sensor Circuit High InputP0105 - Pressure Sensor Circuit MalfunctionP0106 - Pressure Sensor Circuit Range ProblemPO107 - Pressure Sensor Circuit Low InputPO108 - Pressure Sensor Circuit High InputP0111 - Intake air temperature sensor circuit range/performance problemP0112 - Intake air temperature sensor circuit low inputP0113 - Intake air temperature sensor circuit high inputP0115 - Engine Coolant Temperature Sensor CircuitP0116 - Engine Coolant Temp Sensor Circuit Low InputPO117 - Engine Coolant Temp Sensor Circuit Low InputPO118 - Engine Coolant Temp Sensor Circuit High InputP0120 - Throttle Position Sensor Circuit MalfunctionP0121 - Throttle Position Sensor Circuit Range ProblemPO122 - Throttle Position Sensor Circuit Range ProblemPO123 - Throttle Position Sensor Circuit High InputP0125 - Insufficient Coolant Temperature for Closed LoopP0128 - Thermostat malfunctionP0130 - Front Oxygen Sensor Circuit MalfunctionP0131 - Front oxygen (A/F) sensor circuit range/performance problem (low input)P0132 - Front oxygen (A/F) sensor circuit range/performance problem (high input)P0133 - Front Oxygen Sensor Circuit Slow ResponseP0135 - Front Oxygen Sensor Heater Circuit MalfunctionP0136 - Rear Oxygen Sensor Circuit MalfunctionP0139 - Rear Oxygen Sensor Circuit Slow ResponseP0141 - Rear Oxygen Sensor Heater Circuit MalfunctionP0170 - Fuel Trim MalfunctionP0171 - Fuel trim malfunction (A/F too lean)P0172 - Fuel trim malfunction (A/F too rich)PO181 - Fuel Temperature Sensor A Range ProblemPO182 - Fuel Temperature Sensor A Circuit Low InputPO183 - Fuel Temperature Sensor A Circuit High InputP0201 - Fuel Injector Circuit Malfunction - #1P0202 - Fuel Injector Circuit Malfunction - #2P0203 - Fuel Injector Circuit Malfunction - #3P0204 - Fuel Injector Circuit Malfunction - #4P0244 - Wastegate control solenoid valve malfunction (high input)P0245 - Wastegate control solenoid valve circuit low inputP0246 - Wastegate control solenoid valve circuit high inputPO261 - Fuel Injector Circuit Low Input - #1PO262 - Fuel Injector Circuit High Input - #1PO264 - Fuel Injector Circuit Low Input - #2PO265 - Fuel Injector Circuit High Input - #2PO267 - Fuel Injector Circuit Low Input - #3PO268 - Fuel Injector Circuit High Input - #3PO270 - Fuel Injector Circuit Low Input - #4PO271 - Fuel Injector Circuit High Input - #4P0301 - Cylinder 1 Misfire DetectedP0302 - Cylinder 2 Misfire DetectedP0303 - Cylinder 3 Misfire DetectedP0304 - Cylinder 4 Misfire DetectedP0325 - Knock Sensor Circuit MalfunctionP0327 - Knock sensor circuit low inputP0328 - Knock sensor circuit high inputP0335 - Crankshaft Position Sensor Circuit MalfunctionPO336 - Crankshaft Position Sensor Circuit Range ProblemP0340 - Camshaft Position Sensor Circuit MalfunctionPO341 - Camshaft Position Sensor Circuit Range ProblemP0400 - Exhaust Gas Recirculation Flow MalfunctionP0403 - Exhaust Gas Recirculation Circuit MalfunctionPO420 - Catalyst System Efficiency Below ThresholdPO440 - Evaporative Emission Control System MalfunctionP0441 - Evap System Incorrect Purge FlowP0442 - Evaporative emission control system malfunctionP0443 - Evap System Purge Control Valve CircuitPO443 - EVAP System Purge Control Valve Circuit Low InputP0444 - Evaporative emission control system purge control valve circuit low inputP0445 - Evaporative emission control system purge control valve circuit high inputPO446 - EVAP System Vent Control Low InputP0447 - Evaporative emission control system vent control low inputP0448 - Evaporative emission control system vent control high inputPO451 - EVAP Pressure Sensor Range ProblemPO452 - EVAP Pressure Sensor Low InputPO453 - EVAP Pressure Sensor High InputP0456 - Evaporative emission control system malfunctionPO461 - Fuel Level Sensor Circuit Range/Performance ProblemPO462 - Fuel Level Sensor Circuit Low InputPO463 - Fuel Level Sensor Circuit High InputP0464 - Fuel level sensor intermittent inputP0480 - Cooling Fan Relay 1 Circuit Low InputP0483 - Cooling Fan Function ProblemP0500 - Vehicle Speed Sensor MalfunctionP0505 - Idle Control System MalfunctionP0506 - Idle Control System RPM Lower Than ExpectedP0507 - Idle Control System RPM Higher Than ExpectedP0509 - Idle control system circuit high inputP0512 - Starter switch circuit high inputP0545 - Exhaust gas temperature sensor circuit low inputP0546 - Exhaust gas temperature sensor circuit high inputP0600 - Serial Communication Link MalfunctionP0601 - Internal Control Module Memory Checksum ErrorP0604 - Internal control module memory check sum errorP0703 - Brake Switch Input MalfunctionP0705 - Transmission Range Sensor Circuit MalfunctionP0710 - Transmission Fluid Temperature Sensor CircuitP0715 - Torque Converter Turbine Speed Sensor Circuit MalfunctionP0720 - Output Speed Sensor Circuit MalfunctionP0725 - Engine Speed Input Circuit MalfunctionP0731 - Gear 1 Incorrect RatioP0732 - Gear 2 Incorrect RatioP0733 - Gear 3 Incorrect RatioP0734 - Gear 4 Incorrect RatioP0740 - Torque Converter Clutch System MalfunctionP0741 - Torque converter clutch system malfunctionP0743 - Torque Converter Clutch System ElectricalP0748 - Pressure Control Solenoid ElectricalP0753 - Shift Solenoid A ElectricalP0758 - Shift Solenoid B ElectricalP0760 - Shift Solenoid C MalfunctionP0763 - Shift Solenoid C ElectricalP0778 - 2-4 brake pressure control solenoid valve (2-4 brake duty solenoid) circuit malfunctionP0785 - 2-4 brake timing control solenoid valve (2-4 brake timing solenoid) circuit malfunctionP1086 - Tumble generator valve #2 (LH) position sensor circuit low inputP1087 - Tumble generator valve #2 (LH) position sensor circuit high inputP1088 - Tumble generator valve #1 (RH) position sensor circuit low inputP1089 - Tumble generator valve #1 (RH) position sensor circuit high inputP1090 - Tumble generator valve #1 (RH) malfunction (stuck open)P1091 - Tumble generator valve #1 (RH) malfunction (stuck close)P1092 - Tumble generator valve #2 (LH) malfunction (stuck open)P1093 - Tumble generator valve #2 (LH) malfunction (stuck close)P1094 - Tumble generator valve circuit #1 (open circuit)P1095 - Tumble generator valve circuit #1 (over current)P1096 - Tumble generator valve circuit #2 (open circuit)P1097 - Tumble generator valve circuit #2 (over current)P1100 - Starter Switch Circuit MalfunctionP1101 - Neutral Position Switch Circuit High Input (A/T)P1101 - Neutral Position Switch Circuit Malfunction (M/T)P1102 - Pressure Sources Solenoid Valve Circuit MalfunctionP1103 - Pressure Sources Switching Solenoid Valve CircuitP1104 - Engine Torque Control Signal Circuit MalfunctionP1106 - Engine Torque Control Signal 2 Circuit MalfunctionP1110 - Atmospheric pressure sensor low inputP1111 - Atmospheric pressure sensor high inputP1112 - Atmospheric pressure sensor range/performance problemP1115 - Engine Torque Control Cut Signal Circuit High InputP1116 - Engine Torque Control Cut Signal Circuit Low InputP1120 - Starter Switch High InputP1121 - Neutral Position Switch Circuit High Input [MT Vehicles]P1121 - Neutral Position Switch Circuit Low Input [AT Vehicles]P1122 - Pressure Sources Switching Valve Circuit High InputP1124 - TCS Signal Circuit High InputP1130 - Front oxygen sensor circuit malfunction (open circuit)P1131 - Front oxygen sensor circuit malfunction (short circuit)P1134 - Front oxygen (A/F) sensor microcomputer problemP1137 - Front oxygen (A/F) sensor circuit range/performance problemP1139 - Front oxygen (A/F) sensor #1 heater circuit performance/range problemP1141 - Mass Air Flow Sensor Circuit High InputP1142 - Mass Air Flow Sensor Circuit Low InputP1143 - Pressure Sensor Circuit Low InputP1144 - Pressure Sensor Circuit High InputP1146 - Pressure sensor circuit range/performance problem (high input)P1150 - Front Oxygen Sensor Heater Circuit High InputP1151 - Rear Oxygen Sensor Heater Circuit High InputP1230 - Fuel pump control unit malfunctionP1244 - Wastegate control solenoid valve malfunction (low input)P1245 - Wastegate control solenoid valve malfunction (fail-safe)P1301 - Fire due to increased exhaust temperatureP1312 - Exhaust temperature sensor malfunctionP1325 - Knock Sensor Circuit Low InputP1400 - Fuel Tank Pressure Control Solenoid Low InputP1420 - Fuel Tank Pressure Control Solenoid High InputP1421 - Exhaust Gas Recirculation Circuit High InputP1422 - EVAP Purge Control Valve Circuit High InputP1423 - EVAP Vent Control High InputP1440 - Fuel Tank Pressure Control System Low InputP1441 - Fuel Tank Pressure Control System High InputP1442 - Fuel Level Sensor Circuit Range/PerfP1443 - EVAP Control System Vent Control Function ProblemP1480 - Cooling fan relay 1 circuit high inputP1500 - Radiator Fan Relay 1 Circuit MalfunctionP1501 - Idle Control System Malfunction (Fail Safe)P1502 - Radiator Fan Function ProblemP1507 - Idle Control System Malfunction (Fail Safe)P1510 - Idle Air Control Solenoid Signal 1 Circuit Low InputP1511 - Idle Air Control Solenoid Signal 1 Circuit High InputP1512 - Idle Air Control Solenoid Signal 2 Circuit Low InputP1513 - Idle Air Control Solenoid Signal 2 Circuit High InputP1514 - Idle Air Control Solenoid Signal 3 Circuit Low InputP1515 - Idle Air Control Solenoid Signal 3 Circuit High InputP1516 - Idle Air Control Solenoid Signal 4 Circuit Low InputP1517 - Idle Air Control Solenoid Signal 4 Circuit High InputP1518 - Starter switch circuit low inputP1520 - Radiator Fan Relay 1 Circuit High InputP1540 - Vehicle Speed Sensor Malfunction 2P1544 - High exhaust temperature detectedP1560 - Back-Up Voltage Circuit MalfunctionP1590 - Neutral position switch circuit high inputP1591 - Neutral position switch circuit low inputP1592 - Neutral position switch circuit (MT model)P1594 - Automatic transmission diagnosis input signal circuit malfunctionP1595 - Automatic transmission diagnosis input signal circuit low inputP1596 - Automatic transmission diagnosis input signal circuit high inputP1698 - Engine torque control cut signal circuit low inputP1699 - Engine torque control cut signal circuit high inputP1700 - Throttle Position Sensor Circuit Malfunction (A/T)P1701 - Cruise Control Set Signal Circuit Malfunction (A/T)P1702 - Auto Trans Diagnosis Input Signal CircuitP1703 - Low clutch timing control solenoid valve circuit malfunctionP1704 - 2-4 Brake Timing Solenoid Valve Circuit MalfunctionP1705 - 2-4 Brake Pressure Solenoid Valve (Solenoid D) CircuitP1711 - Engine torque control signal 1 circuit malfunctionP1712 - Engine torque control signal 2 circuit malfunctionP1722 - Auto Trans Diagnosis Input Signal High InputP1742 - Auto Trans Diagnosis Input Signal Malfunction [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
Lucid Posted November 16, 2012 Share Posted November 16, 2012 Yes, the cruise control light usually blinks with a CEL, and the cruise will be disabled. Nobody here can help you unless we know the code for your CEL, as there are many many possible reasons. Link to comment Share on other sites More sharing options...
bl6azn Posted November 16, 2012 Author Share Posted November 16, 2012 thank u all for your help. i will get the code and reply back for more help. Link to comment Share on other sites More sharing options...
BigBlack-V Posted November 16, 2012 Share Posted November 16, 2012 Here are the things that may have caused that, I suggest you go through every one of them. P0031 - Front oxygen (A/F) sensor heater circuit low inputP0032 - Front oxygen (A/F) sensor heater circuit high inputP0037 - Rear oxygen sensor heater circuit malfunctionP0038 - Rear oxygen sensor heater circuit high inputP0065 - Air assist injector solenoid valve malfunctionP0066 - Air assist injector solenoid valve circuit low inputP0067 - Air assist injector solenoid valve circuit high inputP0100 - Mass Air Flow Sensor Circuit MalfunctionP0101 - Mass Air Flow Sensor Circuit Range ProblemP0102 - Mass Air Flow Sensor Circuit Low InputPO103 - Mass Air Flow Sensor Circuit High InputP0105 - Pressure Sensor Circuit MalfunctionP0106 - Pressure Sensor Circuit Range ProblemPO107 - Pressure Sensor Circuit Low InputPO108 - Pressure Sensor Circuit High InputP0111 - Intake air temperature sensor circuit range/performance problemP0112 - Intake air temperature sensor circuit low inputP0113 - Intake air temperature sensor circuit high inputP0115 - Engine Coolant Temperature Sensor CircuitP0116 - Engine Coolant Temp Sensor Circuit Low InputPO117 - Engine Coolant Temp Sensor Circuit Low InputPO118 - Engine Coolant Temp Sensor Circuit High InputP0120 - Throttle Position Sensor Circuit MalfunctionP0121 - Throttle Position Sensor Circuit Range ProblemPO122 - Throttle Position Sensor Circuit Range ProblemPO123 - Throttle Position Sensor Circuit High InputP0125 - Insufficient Coolant Temperature for Closed LoopP0128 - Thermostat malfunctionP0130 - Front Oxygen Sensor Circuit MalfunctionP0131 - Front oxygen (A/F) sensor circuit range/performance problem (low input)P0132 - Front oxygen (A/F) sensor circuit range/performance problem (high input)P0133 - Front Oxygen Sensor Circuit Slow ResponseP0135 - Front Oxygen Sensor Heater Circuit MalfunctionP0136 - Rear Oxygen Sensor Circuit MalfunctionP0139 - Rear Oxygen Sensor Circuit Slow ResponseP0141 - Rear Oxygen Sensor Heater Circuit MalfunctionP0170 - Fuel Trim MalfunctionP0171 - Fuel trim malfunction (A/F too lean)P0172 - Fuel trim malfunction (A/F too rich)PO181 - Fuel Temperature Sensor A Range ProblemPO182 - Fuel Temperature Sensor A Circuit Low InputPO183 - Fuel Temperature Sensor A Circuit High InputP0201 - Fuel Injector Circuit Malfunction - #1P0202 - Fuel Injector Circuit Malfunction - #2P0203 - Fuel Injector Circuit Malfunction - #3P0204 - Fuel Injector Circuit Malfunction - #4P0244 - Wastegate control solenoid valve malfunction (high input)P0245 - Wastegate control solenoid valve circuit low inputP0246 - Wastegate control solenoid valve circuit high inputPO261 - Fuel Injector Circuit Low Input - #1PO262 - Fuel Injector Circuit High Input - #1PO264 - Fuel Injector Circuit Low Input - #2PO265 - Fuel Injector Circuit High Input - #2PO267 - Fuel Injector Circuit Low Input - #3PO268 - Fuel Injector Circuit High Input - #3PO270 - Fuel Injector Circuit Low Input - #4PO271 - Fuel Injector Circuit High Input - #4P0301 - Cylinder 1 Misfire DetectedP0302 - Cylinder 2 Misfire DetectedP0303 - Cylinder 3 Misfire DetectedP0304 - Cylinder 4 Misfire DetectedP0325 - Knock Sensor Circuit MalfunctionP0327 - Knock sensor circuit low inputP0328 - Knock sensor circuit high inputP0335 - Crankshaft Position Sensor Circuit MalfunctionPO336 - Crankshaft Position Sensor Circuit Range ProblemP0340 - Camshaft Position Sensor Circuit MalfunctionPO341 - Camshaft Position Sensor Circuit Range ProblemP0400 - Exhaust Gas Recirculation Flow MalfunctionP0403 - Exhaust Gas Recirculation Circuit MalfunctionPO420 - Catalyst System Efficiency Below ThresholdPO440 - Evaporative Emission Control System MalfunctionP0441 - Evap System Incorrect Purge FlowP0442 - Evaporative emission control system malfunctionP0443 - Evap System Purge Control Valve CircuitPO443 - EVAP System Purge Control Valve Circuit Low InputP0444 - Evaporative emission control system purge control valve circuit low inputP0445 - Evaporative emission control system purge control valve circuit high inputPO446 - EVAP System Vent Control Low InputP0447 - Evaporative emission control system vent control low inputP0448 - Evaporative emission control system vent control high inputPO451 - EVAP Pressure Sensor Range ProblemPO452 - EVAP Pressure Sensor Low InputPO453 - EVAP Pressure Sensor High InputP0456 - Evaporative emission control system malfunctionPO461 - Fuel Level Sensor Circuit Range/Performance ProblemPO462 - Fuel Level Sensor Circuit Low InputPO463 - Fuel Level Sensor Circuit High InputP0464 - Fuel level sensor intermittent inputP0480 - Cooling Fan Relay 1 Circuit Low InputP0483 - Cooling Fan Function ProblemP0500 - Vehicle Speed Sensor MalfunctionP0505 - Idle Control System MalfunctionP0506 - Idle Control System RPM Lower Than ExpectedP0507 - Idle Control System RPM Higher Than ExpectedP0509 - Idle control system circuit high inputP0512 - Starter switch circuit high inputP0545 - Exhaust gas temperature sensor circuit low inputP0546 - Exhaust gas temperature sensor circuit high inputP0600 - Serial Communication Link MalfunctionP0601 - Internal Control Module Memory Checksum ErrorP0604 - Internal control module memory check sum errorP0703 - Brake Switch Input MalfunctionP0705 - Transmission Range Sensor Circuit MalfunctionP0710 - Transmission Fluid Temperature Sensor CircuitP0715 - Torque Converter Turbine Speed Sensor Circuit MalfunctionP0720 - Output Speed Sensor Circuit MalfunctionP0725 - Engine Speed Input Circuit MalfunctionP0731 - Gear 1 Incorrect RatioP0732 - Gear 2 Incorrect RatioP0733 - Gear 3 Incorrect RatioP0734 - Gear 4 Incorrect RatioP0740 - Torque Converter Clutch System MalfunctionP0741 - Torque converter clutch system malfunctionP0743 - Torque Converter Clutch System ElectricalP0748 - Pressure Control Solenoid ElectricalP0753 - Shift Solenoid A ElectricalP0758 - Shift Solenoid B ElectricalP0760 - Shift Solenoid C MalfunctionP0763 - Shift Solenoid C ElectricalP0778 - 2-4 brake pressure control solenoid valve (2-4 brake duty solenoid) circuit malfunctionP0785 - 2-4 brake timing control solenoid valve (2-4 brake timing solenoid) circuit malfunctionP1086 - Tumble generator valve #2 (LH) position sensor circuit low inputP1087 - Tumble generator valve #2 (LH) position sensor circuit high inputP1088 - Tumble generator valve #1 (RH) position sensor circuit low inputP1089 - Tumble generator valve #1 (RH) position sensor circuit high inputP1090 - Tumble generator valve #1 (RH) malfunction (stuck open)P1091 - Tumble generator valve #1 (RH) malfunction (stuck close)P1092 - Tumble generator valve #2 (LH) malfunction (stuck open)P1093 - Tumble generator valve #2 (LH) malfunction (stuck close)P1094 - Tumble generator valve circuit #1 (open circuit)P1095 - Tumble generator valve circuit #1 (over current)P1096 - Tumble generator valve circuit #2 (open circuit)P1097 - Tumble generator valve circuit #2 (over current)P1100 - Starter Switch Circuit MalfunctionP1101 - Neutral Position Switch Circuit High Input (A/T)P1101 - Neutral Position Switch Circuit Malfunction (M/T)P1102 - Pressure Sources Solenoid Valve Circuit MalfunctionP1103 - Pressure Sources Switching Solenoid Valve CircuitP1104 - Engine Torque Control Signal Circuit MalfunctionP1106 - Engine Torque Control Signal 2 Circuit MalfunctionP1110 - Atmospheric pressure sensor low inputP1111 - Atmospheric pressure sensor high inputP1112 - Atmospheric pressure sensor range/performance problemP1115 - Engine Torque Control Cut Signal Circuit High InputP1116 - Engine Torque Control Cut Signal Circuit Low InputP1120 - Starter Switch High InputP1121 - Neutral Position Switch Circuit High Input [MT Vehicles]P1121 - Neutral Position Switch Circuit Low Input [AT Vehicles]P1122 - Pressure Sources Switching Valve Circuit High InputP1124 - TCS Signal Circuit High InputP1130 - Front oxygen sensor circuit malfunction (open circuit)P1131 - Front oxygen sensor circuit malfunction (short circuit)P1134 - Front oxygen (A/F) sensor microcomputer problemP1137 - Front oxygen (A/F) sensor circuit range/performance problemP1139 - Front oxygen (A/F) sensor #1 heater circuit performance/range problemP1141 - Mass Air Flow Sensor Circuit High InputP1142 - Mass Air Flow Sensor Circuit Low InputP1143 - Pressure Sensor Circuit Low InputP1144 - Pressure Sensor Circuit High InputP1146 - Pressure sensor circuit range/performance problem (high input)P1150 - Front Oxygen Sensor Heater Circuit High InputP1151 - Rear Oxygen Sensor Heater Circuit High InputP1230 - Fuel pump control unit malfunctionP1244 - Wastegate control solenoid valve malfunction (low input)P1245 - Wastegate control solenoid valve malfunction (fail-safe)P1301 - Fire due to increased exhaust temperatureP1312 - Exhaust temperature sensor malfunctionP1325 - Knock Sensor Circuit Low InputP1400 - Fuel Tank Pressure Control Solenoid Low InputP1420 - Fuel Tank Pressure Control Solenoid High InputP1421 - Exhaust Gas Recirculation Circuit High InputP1422 - EVAP Purge Control Valve Circuit High InputP1423 - EVAP Vent Control High InputP1440 - Fuel Tank Pressure Control System Low InputP1441 - Fuel Tank Pressure Control System High InputP1442 - Fuel Level Sensor Circuit Range/PerfP1443 - EVAP Control System Vent Control Function ProblemP1480 - Cooling fan relay 1 circuit high inputP1500 - Radiator Fan Relay 1 Circuit MalfunctionP1501 - Idle Control System Malfunction (Fail Safe)P1502 - Radiator Fan Function ProblemP1507 - Idle Control System Malfunction (Fail Safe)P1510 - Idle Air Control Solenoid Signal 1 Circuit Low InputP1511 - Idle Air Control Solenoid Signal 1 Circuit High InputP1512 - Idle Air Control Solenoid Signal 2 Circuit Low InputP1513 - Idle Air Control Solenoid Signal 2 Circuit High InputP1514 - Idle Air Control Solenoid Signal 3 Circuit Low InputP1515 - Idle Air Control Solenoid Signal 3 Circuit High InputP1516 - Idle Air Control Solenoid Signal 4 Circuit Low InputP1517 - Idle Air Control Solenoid Signal 4 Circuit High InputP1518 - Starter switch circuit low inputP1520 - Radiator Fan Relay 1 Circuit High InputP1540 - Vehicle Speed Sensor Malfunction 2P1544 - High exhaust temperature detectedP1560 - Back-Up Voltage Circuit MalfunctionP1590 - Neutral position switch circuit high inputP1591 - Neutral position switch circuit low inputP1592 - Neutral position switch circuit (MT model)P1594 - Automatic transmission diagnosis input signal circuit malfunctionP1595 - Automatic transmission diagnosis input signal circuit low inputP1596 - Automatic transmission diagnosis input signal circuit high inputP1698 - Engine torque control cut signal circuit low inputP1699 - Engine torque control cut signal circuit high inputP1700 - Throttle Position Sensor Circuit Malfunction (A/T)P1701 - Cruise Control Set Signal Circuit Malfunction (A/T)P1702 - Auto Trans Diagnosis Input Signal CircuitP1703 - Low clutch timing control solenoid valve circuit malfunctionP1704 - 2-4 Brake Timing Solenoid Valve Circuit MalfunctionP1705 - 2-4 Brake Pressure Solenoid Valve (Solenoid D) CircuitP1711 - Engine torque control signal 1 circuit malfunctionP1712 - Engine torque control signal 2 circuit malfunctionP1722 - Auto Trans Diagnosis Input Signal High InputP1742 - Auto Trans Diagnosis Input Signal Malfunction please explain each of these to me, i dont get it I was 0. And I'm still a zero. Link to comment Share on other sites More sharing options...
DocHolladay23 Posted November 16, 2012 Share Posted November 16, 2012 http://okocasopis.sk/wp-content/uploads/2012/01/Challenge-Accepted.png P0031 -You have a problem, get it fixed. P0032 - You have a problem, get it fixed.P0037 - You have a problem, get it fixed. P0038 - You have a problem, get it fixed. P0065 - You have a problem, get it fixed. P0066 - You have a problem, get it fixed. P0067 - You have a problem, get it fixed. P0100 - You have a problem, get it fixed. P0101 - You have a problem, get it fixed. P0102 - You have a problem, get it fixed P0108 -You have a problem, get it fixed. P0109 - You have a problem, get it fixed.P0110 - You have a problem, get it fixed. P0111 - You have a problem, get it fixed. P0112 - You have a problem, get it fixed. P0113 - You have a problem, get it fixed. P0115 - You have a problem, get it fixed. P0116 - You have a problem, get it fixed. P0117 - You have a problem, get it fixed. P0118 - You have a problem, get it fixed P0119 -You have a problem, get it fixed. P0120 - You have a problem, get it fixed.P0121 - You have a problem, get it fixed. P0122 - You have a problem, get it fixed. P0123 - You have a problem, get it fixed. P0124 - You have a problem, get it fixed. P0125 - You have a problem, get it fixed. P0126 - You have a problem, get it fixed. P0127 - You have a problem, get it fixed. P0128 - You have a problem, get it fixed P0129 -You have a problem, get it fixed. P0130 - You have a problem, get it fixed.P0131 - You have a problem, get it fixed. P0132 - You have a problem, get it fixed. P0133 - You have a problem, get it fixed. P0134 - You have a problem, get it fixed. P0135 - You have a problem, get it fixed. P0136 - You have a problem, get it fixed. P0137 - You have a problem, get it fixed. P0138 - You have a problem, get it fixed P0139 -You have a problem, get it fixed. P0140 - You have a problem, get it fixed.P0141 - You have a problem, get it fixed. P0142 - You have a problem, get it fixed. P0145 - You have a problem, get it fixed. P0146 - You have a problem, get it fixed. P0147 - You have a problem, get it fixed. P0148 - You have a problem, get it fixed. P0149 - You have a problem, get it fixed. P0150 - You have a problem, get it fixed P0151 -You have a problem, get it fixed. P0152 - You have a problem, get it fixed.P0153 - You have a problem, get it fixed. P0154 - You have a problem, get it fixed. P0156 - You have a problem, get it fixed. P0157 - You have a problem, get it fixed. P0158 - You have a problem, get it fixed. P0159 - You have a problem, get it fixed. P0160 - You have a problem, get it fixed. P0161 - You have a problem, get it fixed That should get you started. [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted November 16, 2012 I Donated Too Share Posted November 16, 2012 Link to comment Share on other sites More sharing options...
frank_ster Posted November 16, 2012 Share Posted November 16, 2012 05 legacy will also tell you the code with out code reader ... search and the search will tell you how to do that. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Strizzy Posted November 17, 2012 Share Posted November 17, 2012 I'll make it easy: http://legacygt.com/forums/showthread.php/reading-ess-dtc-codes-171935.html My bad luck build Link to comment Share on other sites More sharing options...
bl6azn Posted November 18, 2012 Author Share Posted November 18, 2012 so i found out that it is my intake manifold that is cause the CEL 2 show. i think it's because i had 2 use Regular gas (no name brand). I usually use premium but since i live in NY and we had hurricane Sandy it cause ppl 2 only be able 2 use reg. if that is not the prob. what do you guys think the problem might be? i just wanna have a back up plan 2 look into if that is not the problem. Link to comment Share on other sites More sharing options...
ehsnils Posted November 18, 2012 Share Posted November 18, 2012 And what was the code then? "intake manifold" is not saying anything. It can be the MAF, it can be the MAP or a few other things related to the manifold. Link to comment Share on other sites More sharing options...
bl6azn Posted November 18, 2012 Author Share Posted November 18, 2012 And what was the code then? "intake manifold" is not saying anything. It can be the MAF, it can be the MAP or a few other things related to the manifold. oh ok. cause that is what they told me and they didnt really give me a code. i guess then i will have 2 wait till it shows again. thank u. Link to comment Share on other sites More sharing options...
relative4 Posted May 21, 2018 Share Posted May 21, 2018 Bump from the dead cause this thread was awesome. Link to comment Share on other sites More sharing options...
JmP6889928 Posted May 22, 2018 Share Posted May 22, 2018 Was it ever. All that information. Wow! Link to comment Share on other sites More sharing options...
