siren173 Posted November 20, 2013 Share Posted November 20, 2013 I have an 05 legacy gt wagon and i am in the middle of doing my TSK3 throw out bearing kit. The clutch disk is getting pretty low and i dont want to put it back together just to have to do a clutch in a couple months, that being said I have a competition stage 2 clutch in there now and i am wondering if i can put an act clutch disc in the competition clutch pressure plate? The biggest reason i ask is that the comp clutch disc is 10 inches in diameter and the act is only 9 inches. thank you for your imput. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 20, 2013 Share Posted November 20, 2013 Personally I would not recommend that. Do it right or don't do it at all. You can pay now or pay later when the smaller disc wears out sooner. The flywheel should be resurfaced too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Xplosivo1 Posted November 21, 2013 Share Posted November 21, 2013 Personally I would not recommend that. Do it right or don't do it at all. You can pay now or pay later when the smaller disc wears out sooner. The flywheel should be resurfaced too. +1 There is nothing worse than pulling things apart a second time because you thought you could get away with something the first time. Link to comment Share on other sites More sharing options...
