Manchildlgt07 Posted November 9, 2014 Share Posted November 9, 2014 I've been looking for a transmission for my 07 legacy, but it's very hard to come by... I had found a transmission off a 2000 2.5rs. I was wandering is there any downfall to using this tranny.. Is there anything that would need to be changed as well? Thanx for the help Link to comment Share on other sites More sharing options...
thisisthenewsic Posted November 10, 2014 Share Posted November 10, 2014 Find a stock legacy trans. It will not work with the front axles. Rear diff is most likely a different ratio and rs trans is no where near as stock Link to comment Share on other sites More sharing options...
Manchildlgt07 Posted November 10, 2014 Author Share Posted November 10, 2014 The rear diff is the same ratio.. I wasn't sure about the front axles. I also found one from a 99 legacy with also the same final drive Link to comment Share on other sites More sharing options...
Manchildlgt07 Posted November 10, 2014 Author Share Posted November 10, 2014 The tranny code ty754vcaab Link to comment Share on other sites More sharing options...
whitetiger Posted November 10, 2014 Share Posted November 10, 2014 the 2000 RS trans is weaker than the the modern 4th gen 5mt. you dont want to use it Link to comment Share on other sites More sharing options...
thisisthenewsic Posted November 10, 2014 Share Posted November 10, 2014 the 2000 rs trans had stubs coming out of the trans. which u cannot remove without taking the trans apart. the sti 6 speed stubs can be removed easily. the lgt does not have stubs and the axle inserts into the trans. what is the issue with your trans. you would be better off spending $$ to rebuild it if its got issues. Link to comment Share on other sites More sharing options...
Manchildlgt07 Posted November 11, 2014 Author Share Posted November 11, 2014 I broke a shift fork and syncros n a shop is telling me my casing is messed up and saying I will need all new gears and syncros. Basically saying I will need a new tranny and is trying to charge me 3100 to fix Link to comment Share on other sites More sharing options...
Manchildlgt07 Posted November 11, 2014 Author Share Posted November 11, 2014 So I'm trying to just find a tranny to put in without spending a arm n leg Link to comment Share on other sites More sharing options...
Max Capacity Posted November 13, 2014 Share Posted November 13, 2014 car-part.com that's where I found my current 5mt. I also had Moore Performance Blast Plates installed. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
