subie3429 Posted February 17, 2011 Share Posted February 17, 2011 I just bought a vag-com cable, I downloaded LV, Rom raider, and Ecuflash. LV view works, and ecuflash works. When i try to log with romraider, the logs cut out everytime and says connecting to ecu. When the car is at idle it has no problem reading the data. I have turned the baud down to 4800. What am i missing? Link to comment Share on other sites More sharing options...
subie3429 Posted February 19, 2011 Author Share Posted February 19, 2011 bump Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted February 20, 2011 Share Posted February 20, 2011 My VAGCOM cable has never given me a consisten log either. Always cuts out mid range or cuts out after 5500. bump. I think im just going to buy a tactrix 1.3 Link to comment Share on other sites More sharing options...
subie3429 Posted February 20, 2011 Author Share Posted February 20, 2011 ^really? I have had this problem berfore, even with a tactrix 2.0 cable. Link to comment Share on other sites More sharing options...
Code Posted February 20, 2011 Share Posted February 20, 2011 It's pretty common with the vag com. Some work, some don't. I don't recall hearing of this happening with the tactrix 2.0 "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
subie3429 Posted February 20, 2011 Author Share Posted February 20, 2011 I dont think its the cable, since i was having problems with a brand new tactrix. Some people said to clean the ground wires. I ended up find that one of the wires were cut in half, i fixed it but i am still having the problem. Link to comment Share on other sites More sharing options...
wpgspecb Posted February 21, 2011 Share Posted February 21, 2011 if you have one wire buggered you probably have more Link to comment Share on other sites More sharing options...
subie3429 Posted February 21, 2011 Author Share Posted February 21, 2011 if you have one wire buggered you probably have more That is what im thinking. The one that i repaired i just used some automotive wiring, wasnt the same wire as stock. Would that be a problem? Would getting an aftermarket grounding kit be better? Link to comment Share on other sites More sharing options...
subie3429 Posted February 22, 2011 Author Share Posted February 22, 2011 Also where does the ground on lower passenger side frame rail go to? I didnt see a spot for it, so i ran the wire along the lower rad support, to the driver side, and grounded it with the other frame rail ground on the bottom of the motor. Link to comment Share on other sites More sharing options...
TurboBrett Posted March 1, 2011 Share Posted March 1, 2011 Add another one to the list with vag-com issues. I had read on nabisco about others having this issue and some were successful in adding ferrite choke cores over the OBD-II cable just before the port connector but it hasn't resolved the issue for me (I added 3). http://www.romraider.com/forum/viewtopic.php?f=15&t=6566 http://forums.nasioc.com/forums/showthread.php?t=1917776 http://forums.nasioc.org/forums/showthread.php?p=31097123 http://forums.nasioc.com/forums/showthread.php?p=29431819 Link to comment Share on other sites More sharing options...
subie3429 Posted March 3, 2011 Author Share Posted March 3, 2011 Add another one to the list with vag-com issues. I had read on nabisco about others having this issue and some were successful in adding ferrite choke cores over the OBD-II cable just before the port connector but it hasn't resolved the issue for me (I added 3). http://www.romraider.com/forum/viewtopic.php?f=15&t=6566 http://forums.nasioc.com/forums/showthread.php?t=1917776 http://forums.nasioc.org/forums/showthread.php?p=31097123 http://forums.nasioc.com/forums/showthread.php?p=29431819 Im gonna try that soon. if that doesnt work i have no idea what else to try. Link to comment Share on other sites More sharing options...
TurboBrett Posted March 22, 2011 Share Posted March 22, 2011 I got a new super pricey tactrix 2.0 cable and it completely fixed my issue. My timing marks in the log file are never more than 250 (ms?) apart, unlike with the VAG-COM. Expensive fix unfortunately. Link to comment Share on other sites More sharing options...
