subiewag97 Posted February 26, 2014 Share Posted February 26, 2014 I have a 97 legacy wagon problem with it is that the threads for the sparks are shot. I have drilled and rethreaded it but it keeps blowing the plugs outs. So need to knw if it would be better to upgrade to a ej25, or rebuild the ej22 and put new heads on the motor Link to comment Share on other sites More sharing options...
SomethingWittyAsAUsername Posted February 26, 2014 Share Posted February 26, 2014 Did you just run a tap through the spark plug hole and try to redo the threads or did you properly use a heli-coil? Link to comment Share on other sites More sharing options...
subiewag97 Posted February 26, 2014 Author Share Posted February 26, 2014 I got the thread kit which comes with the tap and the heli coils. When I put the heli coil in, it didn't want to hold to the threads even with the plug in, it still blew eveything out. I even put loctite on the coil put it in let dry for about 6 hrs and still blew out the plug with the coil Link to comment Share on other sites More sharing options...
johnegg Posted February 26, 2014 Share Posted February 26, 2014 maybe you used the wrong size helicoil??? but since that didn't work, i would replace the head. on an ej22 you don't even have to remove the valve cover. it only 6 bolts more than a timing belt job, plus the used head and gasket = $150. was there any damage to the plug when it cam out? maybe the piston is hitting it? too weird to be true. Link to comment Share on other sites More sharing options...
subiewag97 Posted February 27, 2014 Author Share Posted February 27, 2014 No damage to the plug and I used the coils tht came in the 14mm 1.25. If I put new head on it wht other things can I do to the motor to get more power. As I have found there's hardly any performance parts for tht motor. Link to comment Share on other sites More sharing options...
