ztrain727 Posted July 29, 2014 Share Posted July 29, 2014 Hello folks - Got a 1997 Legacy Wagon with an EJ22. I've been losing coolant over the past year, maybe a quart every couple months, but recently a bit faster. Got a new head gasket, water pump within the past 5k miles. I was trying to diagnose today, so I had revved my engine (retrospectively, probably a little much) to try to get the radiator fans to kick on, and I discovered that coolant had sprayed/splashed onto the hoses/block under the air intake and dripped down onto the pavement (see pictures). It's almost dead center but a bit driver's side where it collected most, but looks like it sprayed with quite some pressure. Any ideas what might be leaking? I assume it's a hose, but none are obviously saturated with coolant at the crimps. I was going to get an autozone pressure tester and hope it fits. If it's a hose, I assume I have to drain my coolant to not introduce air? Thanks for any suggestions! Link to comment Share on other sites More sharing options...
johnegg Posted July 30, 2014 Share Posted July 30, 2014 there two small coolant hose that go to the throttle body. the other end connects to the coolant crossover pipe. Link to comment Share on other sites More sharing options...
ztrain727 Posted August 2, 2014 Author Share Posted August 2, 2014 Thanks! There was some residue there. I found the primary leak is actually a hose leading to the heater core, but the coolant had dripped down under so it wasn't easy to see. Once the engine started heating up, if I squeezed the hose it would shoot a jet of coolant all over the bottom of the air intake and throttle body, hence the assumption it was coming from that area. It's the hose with the upside-down A on it in the picture. Anyone know the size (it has 69 written on it)? http://s30.postimg.org/vk232zokt/photo_2_1.jpg http://s16.postimg.org/wd6vwb1hd/photo_1_1.jpg There is also quite a bit of residue on the metal connector for the driver side throttle coolant hose. If it's easy enough to get too, I'll replace that one too while the plastic air intake is off, maybe the one with the crimp too since it doesn't look too good. Link to comment Share on other sites More sharing options...
Stevo F Posted August 3, 2014 Share Posted August 3, 2014 Look like one of your heater hoses is leaking. Actually I'm thinking of putting new ones on my '98 tomorrow- it looks like they are fairly easy to get to, unlike my son's Honda Accord. Link to comment Share on other sites More sharing options...
elcuerno Posted August 13, 2014 Share Posted August 13, 2014 I had a similer problem on my 98 gt. more on the passenger side though. It was a small pinhole in a metal supply line for the air idle control valve. I had to take the intake off to get to it. But I got one from a junkyard and it fixed it. There were 2 small hoses going to it. Coolant could shoot anywhere under there. Link to comment Share on other sites More sharing options...
jus2phast4uLGT Posted November 8, 2014 Share Posted November 8, 2014 Same issue here, i recently replaced the radiator on a 05 lgt. Couple drives later found coolant leaking from where the water pump area is. Problem is that i'd have to take off the timing belt cover. Never done it before and kinda apprehensive about it. Kinda inclined to tow it to the stealership to have them take of it :/ Link to comment Share on other sites More sharing options...
