mikesubie13 Posted February 6, 2014 Share Posted February 6, 2014 Just wanted to see if anyone knew off the top of there head if a 06 07 wrx cobb short ram would fit and work on at 05 legacy gt ? reason why i ask is just had a wrx traded in at my dealer and i was able to take the intake. from what i have found the main think i would need to know if the maf sensor mounting points r the same or not. intake it else looks same for both models in all pictures i could find to compare. thanks mike Link to comment Share on other sites More sharing options...
idiot4hire Posted February 6, 2014 Share Posted February 6, 2014 Sell it you don't need a intake until your in the 300whp range Link to comment Share on other sites More sharing options...
mikesubie13 Posted February 7, 2014 Author Share Posted February 7, 2014 planing to be in that range this year with other mods in near future. just want to know if it will work on a lgt. bump bump Link to comment Share on other sites More sharing options...
Mike07LGT Posted February 8, 2014 Share Posted February 8, 2014 Sell it you don't need a intake until your in the 300whp range I agree 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
mikesubie13 Posted February 10, 2014 Author Share Posted February 10, 2014 So drop in panel filter? K&n ? I seen a few other brands as well. Also anything with the tune after the maf to turbo inlet ? Link to comment Share on other sites More sharing options...
idiot4hire Posted February 10, 2014 Share Posted February 10, 2014 A clean paper filter is the best selection. I've used a spectre drop in on my wrx without issue Link to comment Share on other sites More sharing options...
Max Capacity Posted February 11, 2014 Share Posted February 11, 2014 Sell it you don't need a intake until your in the 300whp range Correction, 400WHP range. the stock cold air intake is hard to beat. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
idiot4hire Posted February 12, 2014 Share Posted February 12, 2014 Correction, 400WHP range. the stock cold air intake is hard to beat. I stand corrected. I assume you don't have a intake on your legacy's Link to comment Share on other sites More sharing options...
Max Capacity Posted February 12, 2014 Share Posted February 12, 2014 Correct. both stock with panel filters, the wagon has a Perrin since Aug 2004 and Spec a K&N since last April. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
idiot4hire Posted February 12, 2014 Share Posted February 12, 2014 I have a kstech if nothing else it makes changing headlights easier Link to comment Share on other sites More sharing options...
