Fitz Posted February 11, 2013 Share Posted February 11, 2013 Hey guys, Best way I can describe this is when driving the car it feels like someone its tapping the breaks, car seems to bog down at WOT in 4th or 5th at 55mph yet when I slow to 40mph and go to 3rd.... she hesitaes for a seconds then takes off to 13.5PSI full boost... and then shifts to 4th... hesitation... and pulling.... Plugs are new OEM replacements, only mod to the car is just installed a Glow Shift Boost controler... but the T on the V line going to the BPV.... Vid included in park to verify what I was feelling... help.... I'm thinking timing at this point, or miss fire? no check engine light http://www.youtube.com/watch?v=ZpqOF7R1wJs&feature=youtu.be Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted February 12, 2013 Share Posted February 12, 2013 OK in park isn't going to show us anything car will try to compensate with TGVs and throttle body.. you should clean the MAF and reset ecu. You on factory tune? May be intake leak? Spray some carb cleaner to look for leaks Link to comment Share on other sites More sharing options...
Fitz Posted February 12, 2013 Author Share Posted February 12, 2013 It shows the loppy idle going up and down, does this while im driving in any gear in sport mod, is alot more noticable in D.... I will try the MAF cleaning and look for leaks, and yes im Bone stock 100% besides my boost Gauge Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted February 12, 2013 Share Posted February 12, 2013 sounds like intake leak.. I know what your trying to show us, it sounds like a honda with a bad idle air control valve.. prolly have intake leak and vehicle is trying to compensate for it Link to comment Share on other sites More sharing options...
Fitz Posted February 13, 2013 Author Share Posted February 13, 2013 Ya u were right, when we hook up the Boost gauge, the T bracket hoses were a bit cold, so I put little sylicone around them and No more idle issue going down the road, also the new Cat back helped Link to comment Share on other sites More sharing options...
Fitz Posted February 17, 2013 Author Share Posted February 17, 2013 On a side not... the idle issue came back, but a CEL popped up finally... it was the Front o2... 170 bucks later running good as new :0 Link to comment Share on other sites More sharing options...
