iano81 Posted February 8, 2014 Share Posted February 8, 2014 Hello All, recently I purchased a set of projector fog lamps for my 09 legacy. I cut out a small hole where the OEM fog lights are usually mounted. I would prefer to wire these lights to my tail lamps, or corner lamps over mounting a new switch in the cabin. Could I wire it in a way that when the the switch on top of the steering council in turned on so do they? The lamps simply have the red and black wires coming out of them, nothing else. A. Can this be done? B. What way makes the most sense? C. Do the tail lamps work independently of the brake lights? Is there a fuse I could patch the red wire from the fogs to? Thank you for your help, I will post pics once its done. Link to comment Share on other sites More sharing options...
iano81 Posted February 9, 2014 Author Share Posted February 9, 2014 Bump..... Hello All, recently I purchased a set of projector fog lamps for my 09 legacy. I cut out a small hole where the OEM fog lights are usually mounted. I would prefer to wire these lights to my tail lamps, or corner lamps over mounting a new switch in the cabin. Could I wire it in a way that when the the switch on top of the steering council in turned on so do they? The lamps simply have the red and black wires coming out of them, nothing else. A. Can this be done? B. What way makes the most sense? C. Do the tail lamps work independently of the brake lights? Is there a fuse I could patch the red wire from the fogs to? Thank you for your help, I will post pics once its done. Link to comment Share on other sites More sharing options...
iano81 Posted February 9, 2014 Author Share Posted February 9, 2014 bump Link to comment Share on other sites More sharing options...
13fido13 Posted February 9, 2014 Share Posted February 9, 2014 Fog lights are not designed to work separate from your low beam headlamps. Research the proper way to hook them up. Link to comment Share on other sites More sharing options...
apexi Posted February 10, 2014 Share Posted February 10, 2014 This is a little outside my comfort zone, but the link below is the way that I would try to wire it. The only thing I would change is instead of running a wire from #85 on the relay to a switch, I would run a wire from #85 on the relay and use a vampire tap on the other end to the parking lights positive wire. http://www.classictruckshop.com/clubs/earlyburbs/projects/bosch/foglites.htm Link to comment Share on other sites More sharing options...
iano81 Posted February 13, 2014 Author Share Posted February 13, 2014 Thank you all, will update after I install this weekend! Link to comment Share on other sites More sharing options...
