legacy604 Posted April 12, 2016 Share Posted April 12, 2016 The Pinch Weld on my car is deformed due to using Jack stand. Should I try to bend it back or just leave it? I am also planning to touching it up with paint to avoid rust. Are there any drain hole on the pinch weld that I should be aware of ? Thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted April 12, 2016 Share Posted April 12, 2016 I vote for touching up the paint only. Take a look at the other side and see if there's a drain hole looking thingy... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
legacy604 Posted April 13, 2016 Author Share Posted April 13, 2016 I vote for touching up the paint only. Take a look at the other side and see if there's a drain hole looking thingy... I did checked. Because both sides are deformed, I can't really tell for sure. They can be either drain holes or just layers of pinch weld splitting. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 13, 2016 Share Posted April 13, 2016 How about the two in the rear ? What do those look like ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
outahere Posted April 13, 2016 Share Posted April 13, 2016 I always use a short piece of 2x4 lumber on a jack stand or hydraulic jack, as a cushion. So far, no damaged pinch welds. Link to comment Share on other sites More sharing options...
Polo08816 Posted April 13, 2016 Share Posted April 13, 2016 Would these issues be mitigated by the use of something like this: http://www.burgertuning.com/mini_cooper_countryman_paceman_pinch_weld_floor_jack_adapter.html? Link to comment Share on other sites More sharing options...
theflystyle Posted April 14, 2016 Share Posted April 14, 2016 I use a hockey puck between my jack and car. Works like a charm. Link to comment Share on other sites More sharing options...
