Car revs like in neutral in drive
trans going bye-bye. aka. its failing
Is there any certain part of the trans that would cause this? If its something that needs rebuilding then I'm stuck with buying used auto trans...Or I'm thinking of trying to find a donor vehicle that is a 5 speed. Would you know by chance what's needed for a swap? I'm guessing trans, flywheel/pressure plate/clutch, shifter/pedal assembly, clutch master cylinder? Is the drive shaft different? Will my current front diff work with a manual?
i cant answer any questions related to converting to a manual. Never done it. As far as the auto, usually a full rebuild is suggested anytime you have problems. Its a "while your there" thing. as in, while your there, might as well do it.
