G5892 Posted April 19, 2013 Share Posted April 19, 2013 As the title states, I'm trying to figure out what psi spring(s) I have in my tial 38mm MVS. It seems like the EWG opens up early (around 6-8psi). When I had everything installed, I was told I had a 1 bar psi spring(s) put in (~14). Is there anyway I can tell me spring pressure without disassembling everything? Link to comment Share on other sites More sharing options...
Gex Posted April 19, 2013 Share Posted April 19, 2013 No way to really tell unless you crack it open and find out. http://www.amsperformance.com/cart/images/D/WasteGateSpringChart.jpg Link to comment Share on other sites More sharing options...
G5892 Posted April 19, 2013 Author Share Posted April 19, 2013 No way to really tell unless you crack it open and find out. I think that chart is for the older wastegates. Link to comment Share on other sites More sharing options...
ibr_adam09 Posted April 19, 2013 Share Posted April 19, 2013 Cant just log with wastegate pressure ? Link to comment Share on other sites More sharing options...
G5892 Posted April 19, 2013 Author Share Posted April 19, 2013 Cant just log with wastegate pressure ? What do you mean? Link to comment Share on other sites More sharing options...
ibr_adam09 Posted April 19, 2013 Share Posted April 19, 2013 Use a laptop with rom-riader, cobb accesport, or a boost gauge. Cap off the boost solenoid by directly running your wg line into your turbo nipple inlet. Your car should only build boost by what your spring will allow. Link to comment Share on other sites More sharing options...
G5892 Posted April 21, 2013 Author Share Posted April 21, 2013 Use a laptop with rom-riader, cobb accesport, or a boost gauge. Cap off the boost solenoid by directly running your wg line into your turbo nipple inlet. Your car should only build boost by what your spring will allow. Could I just unplug the EBCS? Should I look for the psi where the EWG opens, or the max psi that the car hits to determine the spring? Thanks. Link to comment Share on other sites More sharing options...
G5892 Posted April 26, 2013 Author Share Posted April 26, 2013 bump Link to comment Share on other sites More sharing options...
ibr_adam09 Posted April 26, 2013 Share Posted April 26, 2013 Yes plug the ebcs. And route the at line to the turbo nipple. Whatever max boost you hit is your pressure spring. Link to comment Share on other sites More sharing options...
