Piratefm Posted March 18, 2012 Share Posted March 18, 2012 Can anyone help, With the fuse under the hood removed it appears to still be in 2wd mode, lots front wheel spin on takeoff even with light gas pedal, where do i look for the likely cause??? Andy Link to comment Share on other sites More sharing options...
FundamentalyConfused Posted March 18, 2012 Share Posted March 18, 2012 I'm still a Subaru noob but I'd suggest checking the DCCD solenoid and looking for bad wires. Link to comment Share on other sites More sharing options...
Piratefm Posted March 18, 2012 Author Share Posted March 18, 2012 where do i find the dccd solenoid ?? Link to comment Share on other sites More sharing options...
Piratefm Posted March 19, 2012 Author Share Posted March 19, 2012 where do i find the dccd solenoid ?? Link to comment Share on other sites More sharing options...
Piratefm Posted March 19, 2012 Author Share Posted March 19, 2012 I dont have a manual or wiring diagram to know where the DCCD solenoid is. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted March 19, 2012 Share Posted March 19, 2012 Check the passenger side strut tower. There should be a small box on there labeled FWD with a fuse in it if it's in FWD mode. It should tell you on your gauge cluster if you're in FWD though. Also these cars have a 90/10 front to rear split until it realizes there's a bit of slip, then it transfers. Your front wheels will spin before your back wheels kick in. A DCCD is a driver controlled center differential and I'm not sure any of the US ones had it, but if they do I want it lol Link to comment Share on other sites More sharing options...
FundamentalyConfused Posted March 20, 2012 Share Posted March 20, 2012 Sorry Pirate I'm just a noob still but if there's no fuse in the holder then you should definatly be in AWD. What kind of transmission is in it? Link to comment Share on other sites More sharing options...
FundamentalyConfused Posted March 20, 2012 Share Posted March 20, 2012 Check out this link for wiring diagrams and service manuals. From my observations the Liberty is very similar to the Legacy. http://www.main.experiencetherave.com/subaru_manual_scans/ Link to comment Share on other sites More sharing options...
Legacy Wagon Posted March 20, 2012 Share Posted March 20, 2012 That's what I've always heard so I figure the stuff is probably in the same spot. Link to comment Share on other sites More sharing options...
